    [Plugin] GhostComp - v1.4a - 31 Oct 18
    101 Posts 52 Posters 225.7k Views 52 Watching
    • StinkieS Offline
      Stinkie
      Oooh, this one's going to come in very handy indeed. Thanks!
      • W Offline
        wsms
        it works really good!
        this function shall be put in a new version of su
        • erikBE Offline
          erikB
          Thanks Fredo for this very handy pluging.
          Much appreciated ! 👍
          greetings, erikB
            DJMX1
            je poste mon petit pack d'icônes pour GHOSTCOMP. J'ai fait ça pour moi et je partage.
            http://img2.pict.com/16/93/89/1543527/0/ghostcompv1.png
            prendre les icônes et les copiées dans le dossier "IMAGES_Standard" du plugin GHOSTCOMP
            http://www.box.net/shared/gv8ooblvog
            • fredo6F Offline
              prendre les icônes et les copier dans le dossier "IMAGES_Standard" du plugin GHOSTCOMP
              Thanks a lot.
              Actually, the best is to create a subfolder IMAGES_DJMX1 in the folder GHOSTCOMP_DIR_10 and put the icons there. Then in the Default Parameters dialog box for GhostComp you can enable these icons. This way, you are sure that they won't be overwritten in a next release of GhostComp.
                DJMX1
                amazing! DJMX1 in a plugin of Fredo, I'm too happy! thank you
                • E Offline
                  Ecuadorian
                  This is excellent for preparing renderings with tons of 3D vegetation, Thank you very much!
                  An option to have just wireframes of the two bounding boxes options (recursive and simple) would be cool for the next version. ☀
                  -Miguel Lescano
                  • troyhomeT Offline
                    troyhome
                    You're some kind of SketchUp Santa Claus! Thank You
                    IOviz.com
                    SU Pro 2024 PC
                      stegagG
                      What is the message in SU7 :
                      Loading file error GhostCompAlgo.rb
                      uninitialized constant GhostComp::T6Errore di caricamento del file GhostCompLoader.rb
                      • fredo6F Offline
                        It looks like a problem of installation, most probably your Unzip programs not reconstructing the folder hierarchy.
                        Check out the footprint of files and folder in the post and in the documentation.
                        It seems that some users have this type of problem.
                        By curiosity, which utility do you use to unzip the files?
                          stegagG
                          Sorry, but I have dome an error of unzip
                          Hi.
                            latence
                            Fredo THANK YOU for all your great work!
                            • fredo6F Offline
                              The script is now translated to Chinese, thanks to the effort of the CLT Team at SketchupBar.
                              see main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=21469&hilit=plugin#p180536
                                aea
                                No working GHOSTCOMP ?
                                • Chris FullmerC Offline
                                  Perhaps you have a group selected instead of a component?
                                    Ruturaj
                                    Hi Fredo,
                                    Thanks you very much ................... 😍
                                    Thanks,
                                    RuturaJ
                                      aea
                                      YES , WORKING , THANKS .
                                      • X Offline
                                        xrok1
                                        a perfect companion to fur. 😄 no? 😕
                                        • X Offline
                                          xrok1
                                          is there a reason this plug hides the geometry as well as the layer? if it just hid the layer one could use wireframe ghost but still render it, but with the geometry being hidden too it doesn't work that way. 😢 any work around for this?
                                            Magnus123
                                            Hi Fredo thanks for this awesome plugin! i have a question.... first mi render motor is vray, when i turn a component into a ghost, when i render the components it just a cube a surface or anything depending of the component, theres no way to render the original component being a ghost? the case is that i dont want to render the geometry that the plugins does, only the original component....thank you very much!
                                            • 2 / 6
