    [Plugin] GhostComp - v1.4a - 31 Oct 18
    101 Posts 52 Posters 217.4k Views 52 Watching
    • W Offline
      Whaat
      Another winner Fredo! I had a similar idea once but never got to implementing it. I also wanted to mention that I have been using your Round Corner script lately and it is incredible! Great work!
      • fredo6F Offline
        Thanks Dale. It shows that the Google SU team should have a closer look to what they could do natively in the Sketchup application, as this could be a useful complement to their quest for high-poly support.
        • urgenU Offline
          urgen
          ...thanks FREDO!...briliant! 👍 👍 👍 😄
          --pupil forever...------
            Pg09
            Thank You!
            • StinkieS Offline
              Stinkie
              Oooh, this one's going to come in very handy indeed. Thanks!
              • W Offline
                wsms
                it works really good!
                this function shall be put in a new version of su
                • erikBE Offline
                  erikB
                  Thanks Fredo for this very handy pluging.
                  Much appreciated ! 👍
                  greetings, erikB
                    DJMX1
                    je poste mon petit pack d'icônes pour GHOSTCOMP. J'ai fait ça pour moi et je partage.
                    http://img2.pict.com/16/93/89/1543527/0/ghostcompv1.png
                    prendre les icônes et les copiées dans le dossier "IMAGES_Standard" du plugin GHOSTCOMP
                    http://www.box.net/shared/gv8ooblvog
                    • fredo6F Offline
                      prendre les icônes et les copier dans le dossier "IMAGES_Standard" du plugin GHOSTCOMP
                      Thanks a lot.
                      Actually, the best is to create a subfolder IMAGES_DJMX1 in the folder GHOSTCOMP_DIR_10 and put the icons there. Then in the Default Parameters dialog box for GhostComp you can enable these icons. This way, you are sure that they won't be overwritten in a next release of GhostComp.
                        DJMX1
                        amazing! DJMX1 in a plugin of Fredo, I'm too happy! thank you
                        • E Offline
                          Ecuadorian
                          This is excellent for preparing renderings with tons of 3D vegetation, Thank you very much!
                          An option to have just wireframes of the two bounding boxes options (recursive and simple) would be cool for the next version. ☀
                          -Miguel Lescano
                            troyhome
                            You're some kind of SketchUp Santa Claus! Thank You
                            IOviz.com
                            SU Pro 2024 PC
                              stegagG
                              What is the message in SU7 :
                              Loading file error GhostCompAlgo.rb
                              uninitialized constant GhostComp::T6Errore di caricamento del file GhostCompLoader.rb
                              • fredo6F Offline
                                It looks like a problem of installation, most probably your Unzip programs not reconstructing the folder hierarchy.
                                Check out the footprint of files and folder in the post and in the documentation.
                                It seems that some users have this type of problem.
                                By curiosity, which utility do you use to unzip the files?
                                  stegagG
                                  Sorry, but I have dome an error of unzip
                                  Hi.
                                    latence
                                    Fredo THANK YOU for all your great work!
                                    • fredo6F Offline
                                      The script is now translated to Chinese, thanks to the effort of the CLT Team at SketchupBar.
                                      see main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=21469&hilit=plugin#p180536
                                        aea
                                        No working GHOSTCOMP ?
                                        • Chris FullmerC Offline
                                          Perhaps you have a group selected instead of a component?
                                            Ruturaj
                                            Hi Fredo,
                                            Thanks you very much ................... 😍
                                            Thanks,
                                            RuturaJ
                                            • 2 / 6
