    DC Door Builder
    Scheduled Pinned Locked Moved Dynamic Components
    11 Posts 7 Posters 7.8k Views 7 Watching
    • H Offline
      Howard leslie
      DC Door Builder - Animated
      See attached
      NOTE:
      Dynamic Components can be USED by ALL SketchUp Users - Free & Pro
      Release Log:
      V1 2009-08-22 first public release.
      V1.1 2009-08-23 (Current Version) user instructions in dialog updated
      Users can enter variables in any units eg millimetres, feet and inches etc
      Door can be set to any size / angle.
      Door opens / closes when clicked.
      Set the door open angle eg to 45 degrees. Click Apply
      To open and close the door to the angle set, use the magic finger on the dynamic components toolbar.
      Turn Layers On / Off as required eg (2d) DoorSwing, Origin etc
      To reverse the door position...
      Pull the scale handles out until the VCB (Measure Box) reads -1 (pull the door inside out)
      Keep the <Ctrl> key pressed while doing this in order to keep the door in its original location (if required). (Scale about Centre).
      This is all standard SU - except that only 1 set of Scale Handles can be used (the remainder are hidden).
      The Scenes (Pages) shown in the *.skp file eg ISO / Elevation / Plan etc can be used to help Export out the data to 2D CAD (eg Autocad) if Reqd.
      Modelled doors can be easily adjusted by changing parameters in the white text boxes shown in the DC dialog box.
      Any probs / suggestions / improvements / feedback etc - giz a shout
      Enjoy
      Howard L'
      Keywords: DC Dynamic Component Door Doors Animated Animation On-Click
      DC_DoorBuilder_V1_1.skp
        dylan
        Thanks Howard 👍
        Do you have ideas for other Dynamic components?
        http://dmdarchitecture.co.uk/
        • halroachH Offline
          halroach
          suggestion/question:
          Can you make the door component cut an opening in other geometry?
          FlexTools - Super Quick Windows, Doors, Slats...
            JGA
            Thanks very much for sharing.
            Regards,
            JGA
              dylan
              Have you had a go creating any ???'
              I have to admit Howard, no I haven't 😳
              I should, because I am positive I would use them if I worked them out and took the time to study them!
                Jim
                Well executed DC, Howard. One comment - it may be possible to get even more out of them.
                My thought is that it should be possible have a library of only the Door sub-components as DC's, and be able to swap them out as desired.
                When designing the DC's, whereever you need to reference an attribute in the parent component - use the word 'parent' instead of the actual name of the parent component.
                For example, from a sub-component you can reference the LenX of the parent by using:
                =parent!LenX
                By using this idiom, you could potentially design various door style sub-components which can easily be swapped in to the parent "frame" DC - without needing to know the specific name of the parent component. The Doors can be stored on file as needed.
                Hope that makes sense.
                • H Offline
                  Howard leslie
                  Jim,
                  That sounds good, using the parent! reference - thanks very much for the tip.
                  However how, using this method, could you set up combo boxes (list boxes) with choices for the user on the parent ??? (as the parent doesn't actually exist until you import the finished DC component into another *.skp file ???
                  Regards
                  Howard L'
                  • facerF Offline
                    facer
                    Howard,
                    Thank you for dc door, it has potential.
                    I have not been unable to "reverse the door swing".
                    Could you add to your instructions or post a video on youtube
                    to illustrate how this is done.
                    Would it be possible to add this as a component option?
                    Adding hardware like door levers, closers etc appears to be
                    the next step.
                    Naming of "door types" as Fire Door 1 etc will assist in assigning doors.
                    Keep up the good work.
                    • H Offline
                      Howard leslie
                      Facer,
                      See the first post of this thread.
                      A Graphic (jpg) shows how to reverse the door position.
                      Essentially you mirror the door using the scale tool and the VCB box (key-in -1)
                      This is standard SU functionality
                      Hope this helps
                      Regards
                      Howard L'
                      • H Offline
                        Howard leslie
                        Door Builder now updated to V1.1
                        Dylan,
                        I create DC's for jobs I'm working on at the time to help speed things up.
                        (Obviously there is the time to create them in the first place....!!!)
                        Any I create that I think others will find useful (the more generic DCs) I'll post here.
                        DC Staircase Builder here:
                        http://forums.sketchucation.com/viewtopic.php?f=289&t=18545
                        Regards
                        Howard L'
                          jpin
                          Thanks Howard,
                          Your door builder made my day.
                          Thanks for sharing and devising it so well. It was breeze customizing it to specific needs.
