    [Plugin] CameraControls
    36 Posts 15 Posters 29.9k Views 15 Watching
      autarchos
      this is fantastic! (i was just looking for a script like this yesterday in fact.) so i know it will come in handy on future projects. many thanks.
      pete
      • Chris FullmerC Offline
        Hey Rick, its not working for me. It just gives constant errors to the console. This is the first of them
        Error: #<NoMethodError: undefined method atan' for #<CameraControls:0x8e8fb98>> C:/Program Files/Google/Google SketchUp 7/Plugins/cameracontrols.rb:153:in set_angles'
        C:/Program Files/Google/Google SketchUp 7/Plugins/cameracontrols.rb:216:in `onViewChanged'
          @chris fullmer said:
          ...its not working for me.:
          Chris:
          Strangely it works fine for me - although I can't find the script that's defining ' atan' as a Math function !
          Try adding Math:: in front of atan in line 153 - I did and it still works for me - so it might then work for you ?
          Also Rick: if you run the tool in 'parallel projection' then the 'fov' returns errors at lines 72/97/121 [linked to 79/104/139 as the optional 'perspective' and 'fov' are NOT applicable to pp] - it all shows in the Console - these can easily be trapped in the 3 locations... I have already 'fixed' mine...
          fov = @camera.fov if perspective
          if perspective
             @view.camera = Sketchup;;Camera.new(@eye,newtarget,newup,perspective,fov)
          else
             @view.camera = Sketchup;;Camera.new(@eye,newtarget,newup)
          end#if
          Thanks for another great tool by the way... 😄
            RickW
            TIG: Thanks for the note - I forgot about parallel projection 😳
            I'll also add Math::atan to (hopefully) fix Chris's problem.
            [EDIT] New version uploaded to Smustard
            RickW
            www.smustard.com
              Khai
              erm there's something on the camera controls page that kills my Firefox. something about a C library not loading correctly.
                Ding!Ding!Ding!Ding!
                We have a winner! That solved it all for me Tig, thanks!
                Works great now Rick, very cool!
                  Jim
                  Rick,
                  Did you write the Javascript slider?
                    RickW
                    Yep. Thought about an out-of-the-box thing, but decided to go custom.
                    RickW
                    www.smustard.com
                      mike d
                      thanks rick
                      The grass is always GREENER on the roof.
                        RickW
                        Which page? The Smustard page or the webDialog?
                        RickW
                        www.smustard.com
                          Khai
                          the Smustard page
                          I had to use Chrome to get to it in the end...Fire fox complains about the loading and locks out.
                            My FireFox goes in just fine. I don't have any of those ad removel apps installed, just vanilla FireFox.
                            version 3.0.13
                              Khai
                              actually it wasn't an ad removal problem at all.. (btw the Firefox version is 3.5.2 the latest)
                              it's Videolan, my video player. it's having a problem with the embedded video on that page.. working on it..
                              • bagateloB Offline
                                bagatelo
                                Thank you very much for the tool! I loved.
                                A thing that could be implemented would be the possibility to arise or to go down the camera, to change the zoom, or to alter the vision field, or Pan by slide.
                                  RickW
                                  Thanks for the suggestions. I'll see what might work.
                                  RickW
                                  www.smustard.com
                                    RickW
                                    Ah, sorry about that. I'll see about embedding a YouTube video instead.
                                    RickW
                                    www.smustard.com
                                      RickW
                                      John,
                                      The 90-degree issue is (I think) an internal SU thing due to the desire of the camera to not look straight down - you can see this when manually orbiting, and I suspect it carries over to dynamically moving the camera in Ruby. Either that, or it's a by-product of my (necessary) assumption that when looking straight down, the positive y-axis is zero roll. Not sure.
                                      As for the second issue you described in your model, I don't quite understand the issue - I didn't have any problem getting 90 degrees for the magenta(?) and green boxes. I'll try to get with you later to get more input.
                                      RickW
                                      www.smustard.com
                                      • PixeroP Offline
                                        Pixero
                                        I cant get it to work.
                                        I get a window with three sliders but nothing happens when I drag them.
                                        Should there be more things visible in that window?
                                        If not I suggest you make it a lot smaller.
                                        It takes up a great deal of space IMHO.
                                          Ahh yes, agreed. The window initialy starts quite large for just the three sliders.
                                          Jan, is it giving errors to the webconsole? I had a problem described earlier in the thread where the atan function needed to be specified as Math::atan on line 153. Did you already fix that one Rick?
                                          • PixeroP Offline
                                            Pixero
                                            Ok. I added the Math::atan and now it works. Still the window is huge! 😲
                                            I really like the way it works in realtime but please make the window much more compact.
                                            It would also be nice with a small reset button for each slider.
                                            Also would it be possible to have these as well:
                                            Truck (left/right)
                                            Pedestal (up/down)
                                            Dolly (in/out)
                                            For these maybe some logarithmic/non linear curve for the slider so when sliding a little it would be small values and when sliding towards the extremes it would be larger/faster movement.
                                            Just a thought.
