    [Plugin] CameraControls
    36 Posts 15 Posters 28.5k Views 15 Watching
      RickW
      Announcing CameraControls! (PC only for now - working on the Mac version)
      CameraControls provides tighter user control over camera positioning by providing sliders and direct numeric entry for pan, tilt, and roll, through a webDialog.
      The dialog also responds real-time to changes in the view (activating a scene tab or using the SketchUp-native camera manipulation tools).
      To use CameraControls, select Camera Controls from the Camera menu in SketchUp. CameraControls is also compatible with Organizer.
      RickW
      www.smustard.com
      • Chris FullmerC Offline
        Cool, thanks Rick. I'll be looking at it shortly!
          autarchos
          this is fantastic! (i was just looking for a script like this yesterday in fact.) so i know it will come in handy on future projects. many thanks.
          pete
            Hey Rick, its not working for me. It just gives constant errors to the console. This is the first of them
            Error: #<NoMethodError: undefined method atan' for #<CameraControls:0x8e8fb98>> C:/Program Files/Google/Google SketchUp 7/Plugins/cameracontrols.rb:153:in set_angles'
            C:/Program Files/Google/Google SketchUp 7/Plugins/cameracontrols.rb:216:in `onViewChanged'
            • TIGT Online
              @chris fullmer said:
              ...its not working for me.:
              Chris:
              Strangely it works fine for me - although I can't find the script that's defining ' atan' as a Math function !
              Try adding Math:: in front of atan in line 153 - I did and it still works for me - so it might then work for you ?
              Also Rick: if you run the tool in 'parallel projection' then the 'fov' returns errors at lines 72/97/121 [linked to 79/104/139 as the optional 'perspective' and 'fov' are NOT applicable to pp] - it all shows in the Console - these can easily be trapped in the 3 locations... I have already 'fixed' mine...
              fov = @camera.fov if perspective
              if perspective
                 @view.camera = Sketchup;;Camera.new(@eye,newtarget,newup,perspective,fov)
              else
                 @view.camera = Sketchup;;Camera.new(@eye,newtarget,newup)
              end#if
              Thanks for another great tool by the way... 😄
                RickW
                TIG: Thanks for the note - I forgot about parallel projection 😳
                I'll also add Math::atan to (hopefully) fix Chris's problem.
                [EDIT] New version uploaded to Smustard
                RickW
                www.smustard.com
                  Khai
                  erm there's something on the camera controls page that kills my Firefox. something about a C library not loading correctly.
                    Ding!Ding!Ding!Ding!
                    We have a winner! That solved it all for me Tig, thanks!
                    Works great now Rick, very cool!
                      Jim
                      Rick,
                      Did you write the Javascript slider?
                        RickW
                        Yep. Thought about an out-of-the-box thing, but decided to go custom.
                        RickW
                        www.smustard.com
                          mike d
                          thanks rick
                          The grass is always GREENER on the roof.
                            RickW
                            Which page? The Smustard page or the webDialog?
                            RickW
                            www.smustard.com
                              Khai
                              the Smustard page
                              I had to use Chrome to get to it in the end...Fire fox complains about the loading and locks out.
                                My FireFox goes in just fine. I don't have any of those ad removel apps installed, just vanilla FireFox.
                                version 3.0.13
                                  Khai
                                  actually it wasn't an ad removal problem at all.. (btw the Firefox version is 3.5.2 the latest)
                                  it's Videolan, my video player. it's having a problem with the embedded video on that page.. working on it..
                                  • bagateloB Offline
                                    bagatelo
                                    Thank you very much for the tool! I loved.
                                    A thing that could be implemented would be the possibility to arise or to go down the camera, to change the zoom, or to alter the vision field, or Pan by slide.
                                      RickW
                                      Thanks for the suggestions. I'll see what might work.
                                      RickW
                                      www.smustard.com
                                        RickW
                                        Ah, sorry about that. I'll see about embedding a YouTube video instead.
                                        RickW
                                        www.smustard.com
                                          RickW
                                          John,
                                          The 90-degree issue is (I think) an internal SU thing due to the desire of the camera to not look straight down - you can see this when manually orbiting, and I suspect it carries over to dynamically moving the camera in Ruby. Either that, or it's a by-product of my (necessary) assumption that when looking straight down, the positive y-axis is zero roll. Not sure.
                                          As for the second issue you described in your model, I don't quite understand the issue - I didn't have any problem getting 90 degrees for the magenta(?) and green boxes. I'll try to get with you later to get more input.
                                          RickW
                                          www.smustard.com
                                          • PixeroP Offline
                                            Pixero
                                            I cant get it to work.
                                            I get a window with three sliders but nothing happens when I drag them.
                                            Should there be more things visible in that window?
                                            If not I suggest you make it a lot smaller.
                                            It takes up a great deal of space IMHO.
