    [Plugin] triangulateFaces.rb v1.2 20101120
    97 Posts 21 Posters 110.6k Views 21 Watching
      CPhillips
      I finally figured out how to triangulate any face without the side effect of filling holes.
      def triangulateFace(face)
          mesh=face.mesh(1)
          faces=mesh.polygons
          verts=mesh.points
          uvs=mesh.uvs(true)
          outmesh = Geom;;PolygonMesh.new
          faces.each{|f|
              outmesh.add_polygon(verts[f[0].abs-1],verts[f[1].abs-1],verts[f[2].abs-1])
          ents=Sketchup.active_model.active_entities
          mat=face.material
          face.erase!
          grp = ents.add_group
          grp.entities.add_faces_from_mesh(outmesh)
          grp.entities.each{|e|
              if(e.class==Sketchup;;Edge)
                  e.smooth=false
                  e.soft=false
              elsif(e.class==Sketchup;;Face && mat!=nil)
                     #handle materials and uvs.
                  uva=verts.index(e.vertices[0].position)
                  uvb=verts.index(e.vertices[1].position)
                  uvc=verts.index(e.vertices[2].position)
                  e.material=mat
                  e.position_material(mat,[verts[uva],uvs[uva],verts[uvb],uvs[uvb],verts[uvc],uvs[uvc]],true)
          grp.explode
        Coronel
        Could you please clarify for a 3D newie the purpose of triangulation in this case?
        Does it means the model will be correct or will work better or is merely a way of get more detail?
          If you have a mesh that's rectangular it won't deform consistently. If you triangulate the faces they will... etc.
            CPhillips
            I needed the triangulation to prepare a model for export.
            Thanks for incorporating it into your script TIG! Why is it that back facing UV's didn't work?
              CPhillips
              There is only a method to 'place material textures on a face' - and that assumes a 'front_face' - there's no 'back_face' method...
              Do you mean position_material? It takes a bool for front or back material
              http://code.google.com/apis/sketchup/docs/ourdoc/face.html#position_material
              • I Offline
                ideas_arte
                Thanx really useful!
                where download? 😳
                  Jim
                  @ideas_arte said:
                  where download?
                  That's a valid question; it is not clear which version is the latest, and it is harder than necessary to locate the download.
                  The download is about 5 posts before this one.
                    There is only a method to 'position material textures on a face' - and that assumes a 'front_face' - there's no 'back_face' method ? ...
                      Duh! 😳 I'll adjust the code and re-post...
                        There's something afoot... What I posted before worked - on keeping the front face texture mapping but not on the back_face... Now when I try it it fails to map both faces ? Any ideas - CPhillips's idea worked fine in tests but now seems to fail...
                          CPhillips
                          Post the code and I'll have a look. It might be the face.mesh(1). I think you need to use a different number when you want back uv's as well.
                          • honoluludesktopH Offline
                            honoluludesktop
                            Hi TIG, Any way to convert this kind of mesh into its component triangles?
                            Drapery05.skp
                              I wrote an example script a few weeks ago to do something like this... http://forums.sketchucation.com/viewtopic.php?p=186068#p186068 ❓
                                honoluludesktop
                                TIG, Thanks for the link, it works. Now I can make small edits to the (mesh?).
                                • jeff hammondJ Offline
                                  @tig said:
                                  Result: it triangulates a face... front Texture UVs are kept.
                                  hey TIG,
                                  if i run the script on this sphere, the UVs go haywire.
                                  am i misunderstanding or misusing the script?
                                  thanks
                                  [edit] ok, wait.. i just read the rest of the thread and i guess this hasn't been sorted out ?
                                  sorry about the size.. i guess i could of used a smaller texture πŸ™‚
                                    hey TIG,
                                    thanks
                                    It's broken... the UV mapping was CJP's but it still needs fixing...
                                      ah, ok..
                                      too bad πŸ˜„
                                      [fwiw - i can manually triangulate the sphere using and everything turns out ok.. i guess this script is doing something other than just drawing lines to cut quads in half?]
                                        ah, ok..
                                        too bad πŸ˜„
                                        It triangulates the quads and tries to fix the UV mapping - obviously very badly !!!! CJP help! ❗
                                          See this new script just for selected quad faces - it keeps UV mapping etc...
                                          http://forums.sketchucation.com/viewtopic.php?p=201025#p201025
                                            @tig said:
                                            Known Issues: Back Materials are kept, but these Texture UVs cannot be re-used;
                                            there's a Ruby Console warning message if this problem is found...
                                            Solution: use the front faces only for textures IF you might be triangulating later.
                                            Why is it that you can't preserve the UVs of the backfaces?
                                            • 3 / 5
