    [Plugin] triangulateFaces.rb v1.2 20101120
    97 Posts 21 Posters 113.3k Views 21 Watching
    • TIGT Online
      @kwistenbiebel said:
      Strange, I can't find it anywhere in my long long plugin list 😳 .
      Maybe it clashes with some other plugin? (I do have WxSU installed which caused me trouble with other plugins in the past).
      By the way, I am on SU6 Pro.
      If you have 2.1 open it in a text editor and read the last bit it should define the menu...
        CPhillips
        I finally figured out how to triangulate any face without the side effect of filling holes.
        def triangulateFace(face)
            mesh=face.mesh(1)
            faces=mesh.polygons
            verts=mesh.points
            uvs=mesh.uvs(true)
            outmesh = Geom;;PolygonMesh.new
            faces.each{|f|
                outmesh.add_polygon(verts[f[0].abs-1],verts[f[1].abs-1],verts[f[2].abs-1])
            ents=Sketchup.active_model.active_entities
            mat=face.material
            face.erase!
            grp = ents.add_group
            grp.entities.add_faces_from_mesh(outmesh)
            grp.entities.each{|e|
                if(e.class==Sketchup;;Edge)
                    e.smooth=false
                    e.soft=false
                elsif(e.class==Sketchup;;Face && mat!=nil)
                       #handle materials and uvs.
                    uva=verts.index(e.vertices[0].position)
                    uvb=verts.index(e.vertices[1].position)
                    uvc=verts.index(e.vertices[2].position)
                    e.material=mat
                    e.position_material(mat,[verts[uva],uvs[uva],verts[uvb],uvs[uvb],verts[uvc],uvs[uvc]],true)
            grp.explode
          Coronel
          Could you please clarify for a 3D newie the purpose of triangulation in this case?
          Does it means the model will be correct or will work better or is merely a way of get more detail?
          • TIGT Online
            If you have a mesh that's rectangular it won't deform consistently. If you triangulate the faces they will... etc.
              CPhillips
              I needed the triangulation to prepare a model for export.
              Thanks for incorporating it into your script TIG! Why is it that back facing UV's didn't work?
                CPhillips
                There is only a method to 'place material textures on a face' - and that assumes a 'front_face' - there's no 'back_face' method...
                Do you mean position_material? It takes a bool for front or back material
                http://code.google.com/apis/sketchup/docs/ourdoc/face.html#position_material
                • I Offline
                  ideas_arte
                  Thanx really useful!
                  where download? 😳
                    Jim
                    @ideas_arte said:
                    where download?
                    That's a valid question; it is not clear which version is the latest, and it is harder than necessary to locate the download.
                    The download is about 5 posts before this one.
                    • TIGT Online
                      There is only a method to 'position material textures on a face' - and that assumes a 'front_face' - there's no 'back_face' method ? ...
                      • TIGT Online
                        Duh! 😳 I'll adjust the code and re-post...
                        • TIGT Online
                          There's something afoot... What I posted before worked - on keeping the front face texture mapping but not on the back_face... Now when I try it it fails to map both faces ? Any ideas - CPhillips's idea worked fine in tests but now seems to fail...
                            CPhillips
                            Post the code and I'll have a look. It might be the face.mesh(1). I think you need to use a different number when you want back uv's as well.
                            • honoluludesktopH Offline
                              honoluludesktop
                              Hi TIG, Any way to convert this kind of mesh into its component triangles?
                              Drapery05.skp
                              • TIGT Online
                                I wrote an example script a few weeks ago to do something like this... http://forums.sketchucation.com/viewtopic.php?p=186068#p186068 ❓
                                  honoluludesktop
                                  TIG, Thanks for the link, it works. Now I can make small edits to the (mesh?).
                                  • jeff hammondJ Offline
                                    @tig said:
                                    Result: it triangulates a face... front Texture UVs are kept.
                                    hey TIG,
                                    if i run the script on this sphere, the UVs go haywire.
                                    am i misunderstanding or misusing the script?
                                    thanks
                                    [edit] ok, wait.. i just read the rest of the thread and i guess this hasn't been sorted out ?
                                    sorry about the size.. i guess i could of used a smaller texture πŸ™‚
                                    • TIGT Online
                                      hey TIG,
                                      thanks
                                      It's broken... the UV mapping was CJP's but it still needs fixing...
                                        ah, ok..
                                        too bad πŸ˜„
                                        [fwiw - i can manually triangulate the sphere using and everything turns out ok.. i guess this script is doing something other than just drawing lines to cut quads in half?]
                                        • TIGT Online
                                          ah, ok..
                                          too bad πŸ˜„
                                          It triangulates the quads and tries to fix the UV mapping - obviously very badly !!!! CJP help! ❗
                                          • TIGT Online
                                            See this new script just for selected quad faces - it keeps UV mapping etc...
                                            http://forums.sketchucation.com/viewtopic.php?p=201025#p201025
                                            • 2 / 5
