    [Plugin] SectionCutFace
    569 Posts 171 Posters 505.5k Views 170 Watching
      dylan
      Thanks TIG
      http://dmdarchitecture.co.uk/
      • simon le bonS Offline
        simon le bon
        Dear TIG,
        The white sheet becomes black with the thanks we give you at each new script you offer to the community!!
        I had used this one with a total pleasure here: Modeling] A PoorFlatEllipsoidIndian Bowl into this video: SketchUp/PotterSC_S&S_Quarter2(sorry to advertise this way my own products: I have presently nothing better done with SectionCutFace to show)
        +++simon
        • broomstickB Offline
          broomstick
          I absolutely looooove this plugin 😄
            AcesHigh
            I am sorry, what exactly does this plugin do? Its like a Zorro?
              No.
              To see what most scripts do you can download them and if they don't have a separate readme or pdf then open the .rb file with a plain text editor (NotePad.exe etc) and read the first part which is almost always a description and helpful notes...
              Basically SectionCutFace is a tool that lets you fill in the faces of a section cut, coloured etc as desired...
              SectionCutFace adds a right-click context-menu item 'Add Section-Cut Face' that becomes available if you have selected one (active) section-plane. It opens a dialog and you can then set options - the cut's face colour, the section-cut's colour+width, the cut's layer, if its un-faced edges are kept and if all its edges are finally hidden etc... On 'OK' it adds a group to the model that is placed on* the section-cut plane (*actually it's 0.2mm inside so you still see it !). This group contains faces on what should be the solid parts of the section: it is coloured and setup as you've specified, put on its own layer as you might want it 'switched-off' in other views... It isn't foolproof - you can invent a section with ambiguous areas of solid/void but if it guesses the faced/unfaced areas wrongly then you can simply edit the group and fix them.
                cyan.archnet
                really GREAT plugin, THANKS A LOT!
                • I Offline
                  ideas_arte
                  Thank you very much....!
                    drewpoeppel
                    Thank you so much for this! I just had a project where I spent half the day trying to create what your .rb did in 5 secs. Essential for all architects.
                    • utilerU Offline
                      utiler
                      TIG, I have a request for this great little script.
                      Generally when i as a section cut, I only want it in the current scene; I assume most others would also.
                      Is it possible to edit the script to view the cut layer active only in the current scene?
                      [Just like Jim's [Add hidden Layer" does]
                      Just Curious...
                        Here's v2.3 28/07/09 CUT-x's layer now only 'on' in current page/scene.
                        http://forums.sketchucation.com/viewtopic.php?p=172583#p172583
                        • utilerU Offline
                          utiler
                          You're the man, TIG!!!!
                          Thank you sooo much....
                          Just Curious...
                            rhankc
                            Many thanks Tig. Have a great day!
                            Hank
                            • massimoM Offline
                              massimo Moderator
                              Sorry TIG, I got this error with the 2.3 version with a simple box model
                              Error: #<NoMethodError: undefined methodset_visibility' for nil:NilClass>
                              C:/Programmi/Google/Google SketchUp 6/Plugins/SectionCutFace.rb:383:in face' C:/Programmi/Google/Google SketchUp 6/Plugins/SectionCutFace.rb:451 C:/Programmi/Google/Google SketchUp 6/Plugins/SectionCutFace.rb:451:in call'`
                              and i don't understand how the plug works with the scene/page transition. Draw a cube, add two scenes, in second scene make a section and add "section cut face". Is the below result the expected one?
                              Thanks.
                              Massimo.
                              scene 1
                              scene 2
                                Here's v2.4
                                404 Not Found
                                (forums.sketchucation.com)
                                Trapped layer visibility setting error if no pages/scenes set...
                                  Thanks.
                                  Massimo.
                                  Do you have any 'Pages' [Scenes] ?
                                  EDIT: see next message for fixing update...
                                  • massimoM Offline
                                    massimo Moderator
                                    No error now, thanks. Real time plugins... 😄 But about the result?
                                    • massimoM Offline
                                      massimo Moderator
                                      This is the situation after the cut with no scenes added, but if i add a scene before the cut no error occurs.
                                      EDIT: TIG answered with the 2.4 version before my reply 😄
                                        dimario
                                        this is just a fab plugin.
                                        thank you a lot. very helpful!!! saves a lot of time...
                                        kind regards...
                                          Works really cool, thanks, TIG! 👍
                                          (And now... If only the section cut face would also move when I make a section animation/transition between two scenes! But sigh... I know, I know...) 😉
                                          • massimoM Offline
                                            massimo Moderator
                                            That's exactly the result I was looking for, Gaieus. 😄
                                            • 28
                                            • 29
                                            • 1 / 29
