    [Plugin] SectionCutFace
    569 Posts 171 Posters 477.8k Views 170 Watching
      sepo
      Cheers... I have been using this plugin from the day one.... 👍
      • SektaS Offline
        Sekta
        Thanks TIG, I couldn't do without this plugin 👍 👍
        SEKTA
          dylan
          Thanks TIG
          http://dmdarchitecture.co.uk/
          • simon le bonS Offline
            simon le bon
            Dear TIG,
            The white sheet becomes black with the thanks we give you at each new script you offer to the community!!
            I had used this one with a total pleasure here: Modeling] A PoorFlatEllipsoidIndian Bowl into this video: SketchUp/PotterSC_S&S_Quarter2(sorry to advertise this way my own products: I have presently nothing better done with SectionCutFace to show)
            +++simon
            • broomstickB Offline
              broomstick
              I absolutely looooove this plugin 😄
                AcesHigh
                I am sorry, what exactly does this plugin do? Its like a Zorro?
                  No.
                  To see what most scripts do you can download them and if they don't have a separate readme or pdf then open the .rb file with a plain text editor (NotePad.exe etc) and read the first part which is almost always a description and helpful notes...
                  Basically SectionCutFace is a tool that lets you fill in the faces of a section cut, coloured etc as desired...
                  SectionCutFace adds a right-click context-menu item 'Add Section-Cut Face' that becomes available if you have selected one (active) section-plane. It opens a dialog and you can then set options - the cut's face colour, the section-cut's colour+width, the cut's layer, if its un-faced edges are kept and if all its edges are finally hidden etc... On 'OK' it adds a group to the model that is placed on* the section-cut plane (*actually it's 0.2mm inside so you still see it !). This group contains faces on what should be the solid parts of the section: it is coloured and setup as you've specified, put on its own layer as you might want it 'switched-off' in other views... It isn't foolproof - you can invent a section with ambiguous areas of solid/void but if it guesses the faced/unfaced areas wrongly then you can simply edit the group and fix them.
                    cyan.archnet
                    really GREAT plugin, THANKS A LOT!
                    • I Offline
                      ideas_arte
                      Thank you very much....!
                        drewpoeppel
                        Thank you so much for this! I just had a project where I spent half the day trying to create what your .rb did in 5 secs. Essential for all architects.
                        • utilerU Offline
                          utiler
                          TIG, I have a request for this great little script.
                          Generally when i as a section cut, I only want it in the current scene; I assume most others would also.
                          Is it possible to edit the script to view the cut layer active only in the current scene?
                          [Just like Jim's [Add hidden Layer" does]
                          Just Curious...
                            Here's v2.3 28/07/09 CUT-x's layer now only 'on' in current page/scene.
                            http://forums.sketchucation.com/viewtopic.php?p=172583#p172583
                            • utilerU Offline
                              utiler
                              You're the man, TIG!!!!
                              Thank you sooo much....
                              Just Curious...
                                rhankc
                                Many thanks Tig. Have a great day!
                                Hank
                                • massimoM Offline
                                  massimo Moderator
                                  Sorry TIG, I got this error with the 2.3 version with a simple box model
                                  Error: #<NoMethodError: undefined methodset_visibility' for nil:NilClass>
                                  C:/Programmi/Google/Google SketchUp 6/Plugins/SectionCutFace.rb:383:in face' C:/Programmi/Google/Google SketchUp 6/Plugins/SectionCutFace.rb:451 C:/Programmi/Google/Google SketchUp 6/Plugins/SectionCutFace.rb:451:in call'`
                                  and i don't understand how the plug works with the scene/page transition. Draw a cube, add two scenes, in second scene make a section and add "section cut face". Is the below result the expected one?
                                  Thanks.
                                  Massimo.
                                  scene 1
                                  scene 2
                                    Here's v2.4
                                    404 Not Found
                                    (forums.sketchucation.com)
                                    Trapped layer visibility setting error if no pages/scenes set...
                                      Thanks.
                                      Massimo.
                                      Do you have any 'Pages' [Scenes] ?
                                      EDIT: see next message for fixing update...
                                      • massimoM Offline
                                        massimo Moderator
                                        No error now, thanks. Real time plugins... 😄 But about the result?
                                        • massimoM Offline
                                          massimo Moderator
                                          This is the situation after the cut with no scenes added, but if i add a scene before the cut no error occurs.
                                          EDIT: TIG answered with the 2.4 version before my reply 😄
                                            dimario
                                            this is just a fab plugin.
                                            thank you a lot. very helpful!!! saves a lot of time...
                                            kind regards...
                                            • 28
                                            • 29
                                            • 1 / 29
