    [Plugin] SectionCutFace
    567 Posts 171 Posters 440.2k Views 170 Watching
      *Click the button below to read its usage/documentation and download its RBZ from the 'SketchUcation PluginStore' http://sketchucation.com/resources/pluginstore?pln=SectionCutFace
      Or AutoInstall it from the 'SketchUcation Plugin Store' dialog, from within SketchUp itself...
      https://sketchucation.com/resources/plugin-store-download
      F 1 Reply Last reply Reply Quote 0
      • massimoM Offline
        massimo Moderator
        Now it works fine! 👍 Only a little thing: the edges are not included in the section cut group. Is that normal?
        Thank you.
        Massimo
          Massimo
          Yes it's quite normal in all versions up to v2.1: however I have just added two more options to the dialog with v2.2, one let's you keep un-faced edges (default=No) and the other let's you hide all edges (defaults=Yes)... get it here http://forums.sketchucation.com/viewtopic.php?p=172583#p172583
          • massimoM Offline
            massimo Moderator
            Now it's really good!! Thanks again.
            Massimo
              Ben Ritter
              Thank you TIG for the wonderful plugin.
              • boofredlayB Offline
                boofredlay
                Thanks TIG.
                • MALAISEM Offline
                  MALAISE
                  TIG the man who writes plugin faster than his shadow.... 👍 👍
                  MALAISE
                  • utilerU Offline
                    utiler
                    Legend......
                    Just Curious...
                      sepo
                      Cheers... I have been using this plugin from the day one.... 👍
                      • SektaS Offline
                        Sekta
                        Thanks TIG, I couldn't do without this plugin 👍 👍
                        SEKTA
                          dylan
                          Thanks TIG
                          http://dmdarchitecture.co.uk/
                          • simon le bonS Offline
                            simon le bon
                            Dear TIG,
                            The white sheet becomes black with the thanks we give you at each new script you offer to the community!!
                            I had used this one with a total pleasure here: Modeling] A PoorFlatEllipsoidIndian Bowl into this video: SketchUp/PotterSC_S&S_Quarter2(sorry to advertise this way my own products: I have presently nothing better done with SectionCutFace to show)
                            +++simon
                            • broomstickB Offline
                              broomstick
                              I absolutely looooove this plugin 😄
                                AcesHigh
                                I am sorry, what exactly does this plugin do? Its like a Zorro?
                                  No.
                                  To see what most scripts do you can download them and if they don't have a separate readme or pdf then open the .rb file with a plain text editor (NotePad.exe etc) and read the first part which is almost always a description and helpful notes...
                                  Basically SectionCutFace is a tool that lets you fill in the faces of a section cut, coloured etc as desired...
                                  SectionCutFace adds a right-click context-menu item 'Add Section-Cut Face' that becomes available if you have selected one (active) section-plane. It opens a dialog and you can then set options - the cut's face colour, the section-cut's colour+width, the cut's layer, if its un-faced edges are kept and if all its edges are finally hidden etc... On 'OK' it adds a group to the model that is placed on* the section-cut plane (*actually it's 0.2mm inside so you still see it !). This group contains faces on what should be the solid parts of the section: it is coloured and setup as you've specified, put on its own layer as you might want it 'switched-off' in other views... It isn't foolproof - you can invent a section with ambiguous areas of solid/void but if it guesses the faced/unfaced areas wrongly then you can simply edit the group and fix them.
                                    cyan.archnet
                                    really GREAT plugin, THANKS A LOT!
                                    • I Offline
                                      ideas_arte
                                      Thank you very much....!
                                        drewpoeppel
                                        Thank you so much for this! I just had a project where I spent half the day trying to create what your .rb did in 5 secs. Essential for all architects.
                                        • utilerU Offline
                                          utiler
                                          TIG, I have a request for this great little script.
                                          Generally when i as a section cut, I only want it in the current scene; I assume most others would also.
                                          Is it possible to edit the script to view the cut layer active only in the current scene?
                                          [Just like Jim's [Add hidden Layer" does]
                                          Just Curious...
                                            Here's v2.3 28/07/09 CUT-x's layer now only 'on' in current page/scene.
                                            • 28
                                            • 29
                                            • 1 / 29
