    [Plugin] Sculpt Tools v 1.0...
    100 Posts 51 Posters 137.0k Views 50 Watching
    • EarthMoverE Offline
      EarthMover
      Attaboy! Can't wait to give it a try. I think BTM stands for Break The Mold...cause that is what you did with this ruby! I hope all the polygons it creates doesn't break my machine. LOL
      EDIT - Had a quick play and everything seems to be working. What I've noticed -
      1. Turning off "display edges" helps to speed it up
      2. Turning on use sun for shading and playing with the light and dark sliders will help see what your sculpting
      3. It's a little unresponsive when dragging across a mesh.
      4. Mesh needs a decent amount of subdivision to generate smooth sculpting.
      5. Using Simple Loft works well to make a base sculpting mesh because you can set your subdivisions. Sandbox from scratch also works well.
      Since BTM doesn't have time to do a video, maybe as a community we can put together our observations, or if we have some good success, we can make a quick video for him.
      BTM, this could go down as one of the all time greatest plugins...it's a shame you couldn't better document it. Perhaps when you get more time.
      Content Creator at Skapeup
        MrWip
        Thanks BTM, that's seems very promissing !
        But, I'm a bit sad, because I get the same problem than Kwistenbiebel. The beta version whas working really fine on my sketchup 6.4 Pro, but now, with the latest one, nothing happened.
        I can see the icons, adjust the settings, but when it comes to use a tool, I can't see the blue radius, and my clics does not creates any movements on my triangulated shape...
        I've check the Ruby console, and It give me this :
        C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:86
        Error: #<NoMethodError: undefined method `pick' for nil:NilClass>
        ... I guess that the !NilClass! is not something good... do anyone have any idea what's wrong there ?
        http://www.wip-archi.com
          BTM
          I think it involves the first @model.start_operation line of the scripts; in SU6, the second param is different from SU7.
          Try This: when it says @model.start_operation "Sculpt Bulge", false, true
          set it to: @model.start_operation "Sculpt Bulge", true
          if that doesn't work, then get rid of the , true part altogether.
          http://code.google.com/apis/sketchup/docs/ourdoc/model.html#start_operation
          • CadFatherC Offline
            CadFather
            Thanks BTM - hope you have a 'smoove' holiday round the corner.. looks amazing..
            EDIT: i've just noticed it conflicts with 'soap skin' - the latter will not work properly (on PC)
              CADAddict
              I am using it with SketchUp Pro 6 and don't seem to work. The plugin appears on Plugins Sculpt, but when i try to sue it nothing happens...Maybe I am doing something wrong...
              http://www.cad-addict.com/
              • EdsonE Offline
                Edson
                hi BTM,
                what does "PC friendly" means? that it won't work on mac?
                http://www.mahfuz.arq.br
                  CadFather
                  i think BTM writes his plugins on a mac - so he probably means it will not have unknown bugs on pc which he can't always foresee
                  • EdsonE Offline
                    Edson
                    max,
                    well thought of. otherwise, why would one working on a PC worry about producing something PC-friendly? thanks.
                      MrWip
                      Thanks BTM for your quick reply.
                      First of all I've try the plugin on my (bugging) sketchup 7, and it works just fine.
                      Then I've try to do the changes you've recommended on each ruby script :
                      (@model.start_operation "Sculpt Bulge", true) or (@model.start_operation "Sculpt Bulge")
                      But, I always ended with an error message at the startup, about a syntaxe problem:
                      C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:4: syntax error
                      Copyright 2009, btmsketchup@hotmail.com
                      C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:6: syntax error
                      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
                      C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:7: syntax error
                      IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
                      C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:10: Illegal octal digit
                      Created by •BTM on 23/07/09.
                      C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:12: syntax error
                      Name: Bulge (sculpt tools)
                      C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:13: syntax error
                      Version: 1.0
                      C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:14: syntax error
                      Description: Bulges geometry on a mesh, in a way similar to 'brushing' on the mesh.
                      C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:15: syntax error
                      Usage: Set the settings of the tool with the Sculpt Tools Dialog, and use it by 'brushing' on the mesh, with the left mouse button held down.
                      C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:16: syntax error
                      C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:43: syntax error
                      @entities.each do |e|
                      C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:55: syntax error
                      @apns.each do |p|
                      C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:56: syntax error
                      @sculptlocks.each do |l|
                      C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:69: syntax error
                      I've checked the previous version (beta) which was working on skp 6, and there was no 'false, true', just as you said... but sadly the same trick does not seems to work anymore...
                      ...I guess the other users reporting problems have encounter the same bug ...
                      I really hope there will be a way to solve it, because that's a really great script !
                        CADAddict
                        Ok, the plugin works fine with Sketchup 7 Free version, so I guess there is some issue with version 6.
                        • mitcorbM Offline
                          mitcorb
                          Thanks, -BTM,
                          I will check out the latest release, mindful of the current feedback.
                          • Chris FullmerC Offline
                            I made some changes so that it should work in version 6 now. I've already changed the file in the first post. Someone who uses 6 want to download it and see if ti working better in v6 now? It should still work just the same in version 7.
                            • urgenU Offline
                              urgen
                              ...In SU5 the plugin works well 👍....thanks!
                              --pupil forever...------
                                kwistenbiebel
                                Thanks BTM and Chris for the update.
                                works well in SU6 now 👍
                                  MrWip
                                  Just Perfect on Su 6 now, thanks a lot you two !
                                  • mitcorbM Offline
                                    mitcorb
                                    This latest version seems to work well in SU6 on my machine, even though it is an older unit (processing/reaction time is slow).
                                    Question-- Is the "lagline" setting in the dialog a selection of a visual cue? If it is, I have not seen it.
                                    mitcorb
                                      dacad
                                      Thanks a lot for this .BTM 😄
                                      Right now i can't fully play with it because i've got a lot of work to do but as soon as i get time i'll be back to sculpting and post something (if it turns out i'm a good sculptor and is woth posting...😛).
                                      Again Thanks!!
                                      David
                                        chango70
                                        Wow this works very well! Great effort and great idea. Now I have to think about how I am going to use this new feature.
                                          silver_shadow
                                          can i make a suggestion...if its possible
                                          can you maybe look into if one press the right mouse button and drag it, that the brush size gets resized. I am not sure if this is possible, but it would be awesome if you can. Great job on what you have achieved in this. Without all these plugins, where would we ever be. Great job.
                                            justry
                                            Amazing plugin, really!! You guys are taking sketchup to another level!!
                                            I was just wondering, is there a tutorial of a help file maybe, because I'm not really sure what all the tools do or how exactly they work so... a help file would be really useful!!
                                            Thanks and keep up the awesome work!!
                                            • 1 / 5
