    [Plugin] Sculpt Tools v 1.0...
    100 Posts 51 Posters 142.0k Views 50 Watching
    • CadFatherC Offline
      CadFather
      Thanks BTM - hope you have a 'smoove' holiday round the corner.. looks amazing..
      EDIT: i've just noticed it conflicts with 'soap skin' - the latter will not work properly (on PC)
        CADAddict
        I am using it with SketchUp Pro 6 and don't seem to work. The plugin appears on Plugins Sculpt, but when i try to sue it nothing happens...Maybe I am doing something wrong...
        http://www.cad-addict.com/
        • EdsonE Offline
          Edson
          hi BTM,
          what does "PC friendly" means? that it won't work on mac?
          http://www.mahfuz.arq.br
            CadFather
            i think BTM writes his plugins on a mac - so he probably means it will not have unknown bugs on pc which he can't always foresee
            • EdsonE Offline
              Edson
              max,
              well thought of. otherwise, why would one working on a PC worry about producing something PC-friendly? thanks.
                MrWip
                Thanks BTM for your quick reply.
                First of all I've try the plugin on my (bugging) sketchup 7, and it works just fine.
                Then I've try to do the changes you've recommended on each ruby script :
                (@model.start_operation "Sculpt Bulge", true) or (@model.start_operation "Sculpt Bulge")
                But, I always ended with an error message at the startup, about a syntaxe problem:
                C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:4: syntax error
                Copyright 2009, btmsketchup@hotmail.com
                C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:6: syntax error
                THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
                C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:7: syntax error
                IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
                C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:10: Illegal octal digit
                Created by •BTM on 23/07/09.
                C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:12: syntax error
                Name: Bulge (sculpt tools)
                C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:13: syntax error
                Version: 1.0
                C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:14: syntax error
                Description: Bulges geometry on a mesh, in a way similar to 'brushing' on the mesh.
                C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:15: syntax error
                Usage: Set the settings of the tool with the Sculpt Tools Dialog, and use it by 'brushing' on the mesh, with the left mouse button held down.
                C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:16: syntax error
                C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:43: syntax error
                @entities.each do |e|
                C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:55: syntax error
                @apns.each do |p|
                C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:56: syntax error
                @sculptlocks.each do |l|
                C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:69: syntax error
                I've checked the previous version (beta) which was working on skp 6, and there was no 'false, true', just as you said... but sadly the same trick does not seems to work anymore...
                ...I guess the other users reporting problems have encounter the same bug ...
                I really hope there will be a way to solve it, because that's a really great script !
                http://www.wip-archi.com
                  CADAddict
                  Ok, the plugin works fine with Sketchup 7 Free version, so I guess there is some issue with version 6.
                  • mitcorbM Offline
                    mitcorb
                    Thanks, -BTM,
                    I will check out the latest release, mindful of the current feedback.
                    • Chris FullmerC Offline
                      I made some changes so that it should work in version 6 now. I've already changed the file in the first post. Someone who uses 6 want to download it and see if ti working better in v6 now? It should still work just the same in version 7.
                      • urgenU Offline
                        urgen
                        ...In SU5 the plugin works well 👍....thanks!
                        --pupil forever...------
                          kwistenbiebel
                          Thanks BTM and Chris for the update.
                          works well in SU6 now 👍
                            MrWip
                            Just Perfect on Su 6 now, thanks a lot you two !
                            • mitcorbM Offline
                              mitcorb
                              This latest version seems to work well in SU6 on my machine, even though it is an older unit (processing/reaction time is slow).
                              Question-- Is the "lagline" setting in the dialog a selection of a visual cue? If it is, I have not seen it.
                              mitcorb
                                dacad
                                Thanks a lot for this .BTM 😄
                                Right now i can't fully play with it because i've got a lot of work to do but as soon as i get time i'll be back to sculpting and post something (if it turns out i'm a good sculptor and is woth posting...😛).
                                Again Thanks!!
                                David
                                  chango70
                                  Wow this works very well! Great effort and great idea. Now I have to think about how I am going to use this new feature.
                                    silver_shadow
                                    can i make a suggestion...if its possible
                                    can you maybe look into if one press the right mouse button and drag it, that the brush size gets resized. I am not sure if this is possible, but it would be awesome if you can. Great job on what you have achieved in this. Without all these plugins, where would we ever be. Great job.
                                      justry
                                      Amazing plugin, really!! You guys are taking sketchup to another level!!
                                      I was just wondering, is there a tutorial of a help file maybe, because I'm not really sure what all the tools do or how exactly they work so... a help file would be really useful!!
                                      Thanks and keep up the awesome work!!
                                      • I Offline
                                        ideas_arte
                                        Many many thank you very much,
                                        SU7 tested on Mac OSX 10.5.7 and it works 100%
                                        Greetings! 😄
                                          CadFather
                                          Thank You BTM - i got some proper time to play with it.. this plugin is truly amazing... you get great organic stuff done and.. all in the old 'sketchup way' ..fantastic
                                          ..i made a pillow so good i could sleep on it tonight 😄
                                          [also confirm it still works with soap-skin]
                                          • McGyverM Offline
                                            McGyver
                                            This is one amazing plugin!!! This has to be one of the best ideas I've seen in a long time and has the potential to bring SketchUp to a new level of versatility!! I was recently talking to someone who had just tried SU for the first time and was telling them all the great things it can do and about the great rubies available, the only thing I said it CAN'T do is what this plugin of yours DOES do... Thank you for proving me wrong and for sharing this really wonderful tool!!! I've gotten it to work, but at the moment my efforts are hit and miss as I'm not sure what to do to get the results I want. I can see it does work and is a very powerful and infinitely useful tool! Any hints and tips more advanced users could provide would be greatly appreciated! Thank you BTM! And BTW the gargoyle looks great! 😍
                                            I don't know if this is of any help with your zip file issues, I am a Mac user also and have found YemuZip to be a reliable windows friendly archiver.... I use it for zipping up my freebie models on ShareCG and so far so good. you can get it here:
                                            http://www.yellowmug.com/yemuzip/
                                            and it's free too!
                                            Visit My ShareCG Freebie Gallery
                                            • 1 / 5
