    [Plugin] Sculpt Tools v 1.0...
    100 Posts 51 Posters 142.0k Views 50 Watching
      kwistenbiebel
      Thank you BTM 👍
      I can't get it to work properly though...
      After triangulating a cube 4 times (SDS) and selecting the geometry, the tools remain unresponsive. I tried to adjust the radius but that didn't solve it.
      Any chance of giving us a little walkthrough on how to use it?
      Cheers,
      Kwistenbiebel
        BTM
        @kwistenbiebel said:
        Thank you BTM 👍
        Cheers,
        Kwistenbiebel
        Most tools should work by left-clicking, hold, and dragging across the surface. As to a walkthrough, I'll have no time in the near future 😳 . Also, by unresponsive, do you mean waiting-time, or no effect at all? Do you see the radius circle (blue)? Also, open up the ruby console, to see if there are any errors.
        • EarthMoverE Offline
          EarthMover
          Attaboy! Can't wait to give it a try. I think BTM stands for Break The Mold...cause that is what you did with this ruby! I hope all the polygons it creates doesn't break my machine. LOL
          EDIT - Had a quick play and everything seems to be working. What I've noticed -
          1. Turning off "display edges" helps to speed it up
          2. Turning on use sun for shading and playing with the light and dark sliders will help see what your sculpting
          3. It's a little unresponsive when dragging across a mesh.
          4. Mesh needs a decent amount of subdivision to generate smooth sculpting.
          5. Using Simple Loft works well to make a base sculpting mesh because you can set your subdivisions. Sandbox from scratch also works well.
          Since BTM doesn't have time to do a video, maybe as a community we can put together our observations, or if we have some good success, we can make a quick video for him.
          BTM, this could go down as one of the all time greatest plugins...it's a shame you couldn't better document it. Perhaps when you get more time.
          Content Creator at Skapeup
            MrWip
            Thanks BTM, that's seems very promissing !
            But, I'm a bit sad, because I get the same problem than Kwistenbiebel. The beta version whas working really fine on my sketchup 6.4 Pro, but now, with the latest one, nothing happened.
            I can see the icons, adjust the settings, but when it comes to use a tool, I can't see the blue radius, and my clics does not creates any movements on my triangulated shape...
            I've check the Ruby console, and It give me this :
            C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:86
            Error: #<NoMethodError: undefined method `pick' for nil:NilClass>
            ... I guess that the !NilClass! is not something good... do anyone have any idea what's wrong there ?
            http://www.wip-archi.com
              BTM
              I think it involves the first @model.start_operation line of the scripts; in SU6, the second param is different from SU7.
              Try This: when it says @model.start_operation "Sculpt Bulge", false, true
              set it to: @model.start_operation "Sculpt Bulge", true
              if that doesn't work, then get rid of the , true part altogether.
              http://code.google.com/apis/sketchup/docs/ourdoc/model.html#start_operation
              • CadFatherC Offline
                CadFather
                Thanks BTM - hope you have a 'smoove' holiday round the corner.. looks amazing..
                EDIT: i've just noticed it conflicts with 'soap skin' - the latter will not work properly (on PC)
                  CADAddict
                  I am using it with SketchUp Pro 6 and don't seem to work. The plugin appears on Plugins Sculpt, but when i try to sue it nothing happens...Maybe I am doing something wrong...
                  http://www.cad-addict.com/
                  • EdsonE Offline
                    Edson
                    hi BTM,
                    what does "PC friendly" means? that it won't work on mac?
                    http://www.mahfuz.arq.br
                      CadFather
                      i think BTM writes his plugins on a mac - so he probably means it will not have unknown bugs on pc which he can't always foresee
                      • EdsonE Offline
                        Edson
                        max,
                        well thought of. otherwise, why would one working on a PC worry about producing something PC-friendly? thanks.
                          MrWip
                          Thanks BTM for your quick reply.
                          First of all I've try the plugin on my (bugging) sketchup 7, and it works just fine.
                          Then I've try to do the changes you've recommended on each ruby script :
                          (@model.start_operation "Sculpt Bulge", true) or (@model.start_operation "Sculpt Bulge")
                          But, I always ended with an error message at the startup, about a syntaxe problem:
                          C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:4: syntax error
                          Copyright 2009, btmsketchup@hotmail.com
                          C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:6: syntax error
                          THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
                          C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:7: syntax error
                          IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
                          C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:10: Illegal octal digit
                          Created by •BTM on 23/07/09.
                          C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:12: syntax error
                          Name: Bulge (sculpt tools)
                          C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:13: syntax error
                          Version: 1.0
                          C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:14: syntax error
                          Description: Bulges geometry on a mesh, in a way similar to 'brushing' on the mesh.
                          C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:15: syntax error
                          Usage: Set the settings of the tool with the Sculpt Tools Dialog, and use it by 'brushing' on the mesh, with the left mouse button held down.
                          C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:16: syntax error
                          C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:43: syntax error
                          @entities.each do |e|
                          C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:55: syntax error
                          @apns.each do |p|
                          C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:56: syntax error
                          @sculptlocks.each do |l|
                          C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:69: syntax error
                          I've checked the previous version (beta) which was working on skp 6, and there was no 'false, true', just as you said... but sadly the same trick does not seems to work anymore...
                          ...I guess the other users reporting problems have encounter the same bug ...
                          I really hope there will be a way to solve it, because that's a really great script !
                            CADAddict
                            Ok, the plugin works fine with Sketchup 7 Free version, so I guess there is some issue with version 6.
                            • mitcorbM Offline
                              mitcorb
                              Thanks, -BTM,
                              I will check out the latest release, mindful of the current feedback.
                              • Chris FullmerC Offline
                                I made some changes so that it should work in version 6 now. I've already changed the file in the first post. Someone who uses 6 want to download it and see if ti working better in v6 now? It should still work just the same in version 7.
                                • urgenU Offline
                                  urgen
                                  ...In SU5 the plugin works well 👍....thanks!
                                  --pupil forever...------
                                    kwistenbiebel
                                    Thanks BTM and Chris for the update.
                                    works well in SU6 now 👍
                                      MrWip
                                      Just Perfect on Su 6 now, thanks a lot you two !
                                      • mitcorbM Offline
                                        mitcorb
                                        This latest version seems to work well in SU6 on my machine, even though it is an older unit (processing/reaction time is slow).
                                        Question-- Is the "lagline" setting in the dialog a selection of a visual cue? If it is, I have not seen it.
                                        mitcorb
                                          dacad
                                          Thanks a lot for this .BTM 😄
                                          Right now i can't fully play with it because i've got a lot of work to do but as soon as i get time i'll be back to sculpting and post something (if it turns out i'm a good sculptor and is woth posting...😛).
                                          Again Thanks!!
                                          David
                                            chango70
                                            Wow this works very well! Great effort and great idea. Now I have to think about how I am going to use this new feature.
                                            • 1 / 5
