    Lines cannot be intersected?
    15 Posts 6 Posters 1.7k Views 6 Watching
      dmatho
      Sorry Edson, I was distracted and it's my mistake: it's From Contours (not from scratch).
      Cheers,
      • Diego -
      • boofredlayB
        boofredlay
        I would just take a couple min. and "connect the dots" as it were. Go around your mass and draw the lines where they intersect. It will be faster than trying to find some plugin or closing in your contours.
          dmatho
          The process is actually easier done than explained πŸ˜‰
          See attached.
          Cheers,
          • Diego -
          Erase_extra_contourlines.skp
          • EdsonE
            Edson
            @diego: i already have a surface generated from the contours. intersecting the box and the TIN is a piece of cake. what i really wanted is to extract a part of the contour lines with the box.
            @elisei: zorro 2 did the trick. i got what i wanted with it. thanks.
            @eric: as as said above, zorro 2 solved this problem but i will keep ypur method for future situations.
            http://www.mahfuz.arq.br
            • ely862meE
              ely862me
              I used whaat s knife subdivide from Subdivide&Smooth but i think zorro works too πŸ˜‰
              OK is good u did it πŸ‘
              Elisei
              Elisei (sketchupper)
              Come and See EliseiDesign
              • EdsonE
                Edson
                See attached.
                Cheers,
                • Diego -
                i got you now. after you run from contours and intersect it with a cutter shape the contour lines get trimmed, whereas if you try to do it without the surface it does not happen. thanks for the help.
                • daleD
                  dale
                  Could you not use the Sandbox stamp tool?
                    EDson, I just tried intersecting contours with the sides of a box like you showed in the beginning. I selected the contours and the box and then used Intersect>Intersect Selected. For the example, I had no groups or components. If your contours are inside either a group or component, put the box inside with the contours before doing the intersect.
                    • EdsonE
                      Edson
                      as i understand it, the stamp tool works only on surfaces.
                      • EdsonE
                        Edson
                        strange, because this exactly what i did (or al least I think i did). perhaps one of the two elements was still a group. thanks anyway.
