    Lines cannot be intersected?
    15 Posts 6 Posters 1.6k Views 6 Watching
    • EdsonE
      Edson
      i have these contour lines which i would like to trim to work on the section contained in the box. i ran intersect with context and intersect selected but it did not work. it seems that edges cannot be intersected.
      would anyone have any suggestion about how to manage what i want?
      http://www.mahfuz.arq.br
      • ely862meE
        ely862me
        I thing i just found something..go to parallel projection then select the top view ,take waat*s knife subdivide tool and cut from corner to corner all the lines of the rectangular ,then take the select tool and select with care(i advice u to make selection from right to left)all the inside lines which u don t need, and delete them.
        I tried with simple lines hope it works with urs..
        Cheers!
        Elisei
        Elisei (sketchupper)
        Come and See EliseiDesign
          dmatho
          Hi Edson,
          The lines need to be turned into surfaces, for which I'd suggest the quickest way is to use the Sandbox' From Scratch... thereafter you can trim away.
          Cheers,
          • Diego -
          • EdsonE
            Edson
            Cheers!
            Elisei
            elisei,
            are you talking about whaat's zorro plugin?
            • EdsonE
              Edson
              @dmatho said:
              Hi Edson,
              Cheers,
              • Diego -
              hi dmatho,
              i do not understand what you suggest. how can i apply from scratch to 3D lines? would care to tell me which steps to take?
                dmatho
                Sorry Edson, I was distracted and it's my mistake: it's From Contours (not from scratch).
                Cheers,
                • Diego -
                • boofredlayB
                  boofredlay
                  I would just take a couple min. and "connect the dots" as it were. Go around your mass and draw the lines where they intersect. It will be faster than trying to find some plugin or closing in your contours.
                    dmatho
                    The process is actually easier done than explained 😉
                    See attached.
                    Cheers,
                    • Diego -
                    Erase_extra_contourlines.skp
                    • EdsonE
                      Edson
                      @diego: i already have a surface generated from the contours. intersecting the box and the TIN is a piece of cake. what i really wanted is to extract a part of the contour lines with the box.
                      @elisei: zorro 2 did the trick. i got what i wanted with it. thanks.
                      @eric: as as said above, zorro 2 solved this problem but i will keep ypur method for future situations.
                      • ely862meE
                        ely862me
                        I used whaat s knife subdivide from Subdivide&Smooth but i think zorro works too 😉
                        OK is good u did it 👍
                        Elisei
                        • EdsonE
                          Edson
                          See attached.
                          Cheers,
                          • Diego -
                          i got you now. after you run from contours and intersect it with a cutter shape the contour lines get trimmed, whereas if you try to do it without the surface it does not happen. thanks for the help.
                          • daleD
                            dale
                            Could you not use the Sandbox stamp tool?
                              EDson, I just tried intersecting contours with the sides of a box like you showed in the beginning. I selected the contours and the box and then used Intersect>Intersect Selected. For the example, I had no groups or components. If your contours are inside either a group or component, put the box inside with the contours before doing the intersect.
                              • EdsonE
                                Edson
                                as i understand it, the stamp tool works only on surfaces.
                                • EdsonE
                                  Edson
                                  strange, because this exactly what i did (or al least I think i did). perhaps one of the two elements was still a group. thanks anyway.
