    Lines cannot be intersected?
    15 Posts 6 Posters 1.6k Views 6 Watching
    • EdsonE Offline
      Edson
      @ely862me said:
      I thing i just found something..go to parallel projection then select the top view ,take waat*s knife subdivide tool and cut from corner to corner all the lines of the rectangular ,then take the select tool and select with care(i advice u to make selection from right to left)all the inside lines which u don t need, and delete them.
      I tried with simple lines hope it works with urs..
      Cheers!
      Elisei
      elisei,
      are you talking about whaat's zorro plugin?
      http://www.mahfuz.arq.br
      • EdsonE Offline
        Edson
        @dmatho said:
        Hi Edson,
        The lines need to be turned into surfaces, for which I'd suggest the quickest way is to use the Sandbox' From Scratch... thereafter you can trim away.
        Cheers,
        • Diego -
        hi dmatho,
        i do not understand what you suggest. how can i apply from scratch to 3D lines? would care to tell me which steps to take?
          dmatho
          Sorry Edson, I was distracted and it's my mistake: it's From Contours (not from scratch).
          Cheers,
          • Diego -
          • boofredlayB Offline
            boofredlay
            I would just take a couple min. and "connect the dots" as it were. Go around your mass and draw the lines where they intersect. It will be faster than trying to find some plugin or closing in your contours.
              dmatho
              The process is actually easier done than explained πŸ˜‰
              See attached.
              Cheers,
              • Diego -
              Erase_extra_contourlines.skp
              • EdsonE Offline
                Edson
                @diego: i already have a surface generated from the contours. intersecting the box and the TIN is a piece of cake. what i really wanted is to extract a part of the contour lines with the box.
                @elisei: zorro 2 did the trick. i got what i wanted with it. thanks.
                @eric: as as said above, zorro 2 solved this problem but i will keep ypur method for future situations.
                • ely862meE Offline
                  ely862me
                  I used whaat s knife subdivide from Subdivide&Smooth but i think zorro works too πŸ˜‰
                  OK is good u did it πŸ‘
                  Elisei
                  Elisei (sketchupper)
                  Come and See EliseiDesign
                  • EdsonE Offline
                    Edson
                    See attached.
                    Cheers,
                    • Diego -
                    i got you now. after you run from contours and intersect it with a cutter shape the contour lines get trimmed, whereas if you try to do it without the surface it does not happen. thanks for the help.
                    • daleD Offline
                      dale
                      Could you not use the Sandbox stamp tool?
                        EDson, I just tried intersecting contours with the sides of a box like you showed in the beginning. I selected the contours and the box and then used Intersect>Intersect Selected. For the example, I had no groups or components. If your contours are inside either a group or component, put the box inside with the contours before doing the intersect.
                        • EdsonE Offline
                          Edson
                          as i understand it, the stamp tool works only on surfaces.
                          • EdsonE Offline
                            Edson
                            strange, because this exactly what i did (or al least I think i did). perhaps one of the two elements was still a group. thanks anyway.
