    [Plugin] Import OBJ with Materials v2.1 20131118
    279 Posts 87 Posters 448.6k Views 87 Watching
    • K
      Khai
      hmm a suggestion for a future release would be the option to swap the Z and Y axis on import.
      • Chris FullmerC
        And thanks!
        • CadFatherC
          CadFather
          another very useful gem TIG - ThankYou.....
          • EarthMoverE
            EarthMover
            Thanks TIG, this will come in very handy! Thanks to Jim as well for his initial contribution.
            Content Creator at Skapeup
            • MALAISEM
              MALAISE
              Thanks TIG, to enhance Jim's plugin
              Quite useful when having OBJ library.
              MALAISE 👍 👍
                richcat
                Thanks TIG 👍 & Jim 👍
                  Here's v1.1
                  http://forums.sketchucation.com/viewtopic.php?p=172790#p172790
                  Existing Materials re-used/make variant option added.
                  Swap Y & Z axes ? Yes/No, option added.
                  • Chris FullmerC
                    I'm confused Bagatelo. What are you asking? This is a plugin that will import .obj into SU. The inverse would be an .obj exporter.
                    • K
                      Khai
                      @tig said:
                      Here's v1.1
                      thank you!!!!!!!!
                      • K
                        Khai
                        okies the Swap Z/Y is working perfectly 😄
                        the sizing is not atm 😞 (tried importing OBJ's from trueSpace, UVmapper and Hexagon) it's almost there tho...
                        Edit
                        Thanks to the notes inside the Ruby I was able to reset my units to Metres and now things are coming in the right size 😄
                        • W
                          Whaat
                          Hi TIG,
                          I can't quite tell from your description if your script imports UVs correctly. If you are looking to add this feature, I was working on an OBJ importer awhile ago that imported materials and UVs. If you would like the code, let me know and you can have it. I don't think I'll ever get around to releasing it officially.
                          Thanks for another great script!
                            @whaat said:
                            Hi TIG,
                            I can't quite tell from your description if your script imports UVs correctly. If you are looking to add this feature, I was working on an OBJ importer a while ago that imported materials and UVs. If you would like the code, let me know and you can have it. I don't think I'll ever get around to releasing it officially.
                            My tool imports materials and textures. It doesn't deal with UVs as most of the example OBJs I have didn't have that info in their MTLs. Thus any imported material has it's colour and opacity set correctly, AND also has the correct texture added BUT without any UVs scaling etc - it uses the default 10" square version... However if you already have a pre-existing material with a matching name that has UVs set etc it asks if you want to use it or make a new variant - if you answer Yes it uses the existing material...
                            Am I right in understanding you, that some OBJ/MTLs have UV mapping info ? SUp exported OBJ/MTLs don't seem to ? Please PM me your half-baked UV code and I'll look at incorporating it [with credit to you, as appropriate]... Thanks for the offer.
                            • K
                              Khai
                              yup UV information is a core part of the OBJ Format.. makes it very useful for transfering between programs, such as Maya to trueSpace to Max....
                                Where is it stored in the files ?
                                • K
                                  Khai
                                  I think it's stored as the VT entries.
                                  ah yes here we go
                                  http://local.wasp.uwa.edu.au/~pbourke/dataformats/obj/ - Full OBJ Format Spec
                                  vt u v w
                                  Vertex statement for both polygonal and free-form geometry.
                                  Specifies a texture vertex and its coordinates. A 1D texture
                                  requires only u texture coordinates, a 2D texture requires both u
                                  and v texture coordinates, and a 3D texture requires all three
                                  coordinates.
                                  u is the value for the horizontal direction of the texture.
                                  v is an optional argument.
                                  v is the value for the vertical direction of the texture. The
                                  default is 0.
                                  w is an optional argument.
                                  w is a value for the depth of the texture. The default is 0.
                                  • bagateloB
                                    bagatelo
                                    Yes, I mistake. I have think about EXPORT model with obj file types. But .3ds is very good.
                                    I try to import this model ( http://www.evermotion.org/modelshop/show_product/sculpture-01-am34/1806/0/0/ ) into sketchup and the plugin don't work properly. Export with 3ds Files from MAX result crash in Sketchup.
                                    FBX files maybe can be de very best option.
                                      ah yes here we go
                                      vt u v w
                                      coordinates.
                                      default is 0.
                                      Thanks - I see it now... wait for update...
                                        Since I'm not going to pay $35 for a model of a small statue I can't see how the actual file is structured - looks like it might be very complex though !!! The current OBJ Importersare quite limited...
                                          avariant
                                          Cool, thanks TIG. I've been using Jim's importer for a long time.
                                          One thing I've encountered with materials. You are assuming that the 'd' tag comes after the Kd tag, but it doesn't necessarily. It can show up anywhere in the list. The obj format doesn't require a specific order. So, if 'd' comes first, the plugin is crashing.
                                            Thanks for the info... I'm looking at uv mapping to so a fix might be soon...
                                            I also need to trap mtl's with a texture but no colour [using texture.average_color if no Kd ?]... I am looking at various fixes and other improvements... Please check out the Ruby Forum over the coming days...
                                            • 13
                                            • 14
                                            • 1 / 14
