    Particle FX preview
    46 Posts 12 Posters 6.1k Views 12 Watching
      BTM
      nice idea 👍
        phy
        Good going wacov. svn?
        Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
          Physicsguy1
          That looks nice 😄. Now we need sparks and such for metal grinding, and some other characteristics.
            phy
            You want to know whats best, it hardly slows the simulation at all since it's not using the physics engine.
              Physicsguy1
              I cant wait! Are those bubbles in the water actual moving bubbles, or are they just random, and appear for a jiffy and depart without movement?
              • W Offline
                Wacov
                Glad to see it's popular 😄 ... all the particles move, scale, and fade out. They can be given starting velocity, which will deminish after a few frames, and have some random values attached to keep it all interesting. @Physicsguy, the bubbles are created randomly, but they still move towards the surface.
                This should all be added into SP in the near future, with a different method system. Until then, here's the demo for you all to try out (Feedback on performance would be great)
                particle FX demo.skp
                • W Offline
                  Wacov
                  Okay, just heard about a very slow simulation. Before you run the sim, please open the ruby console (Window/Ruby Console). Play the sim for a bit, reset, and post the last number in the array (after "Fps"). If you can run a normal sim ok, it should be at least 20. Thanks!
                    phy
                    Great 👍
                      phy
                      I got this
                      Inspecting model for errors
                      #<MSketchyPhysics3;;SP3xBodyContext;0x5da3d08>
                      #<MSketchyPhysics3;;SP3xBodyContext;0x5d90b38>
                      #<MSketchyPhysics3;;SP3xBodyContext;0x5d847c0>
                      #<MSketchyPhysics3;;SP3xBodyContext;0x5d78370>
                      #<MSketchyPhysics3;;SP3xBodyContext;0x5d6c3d0>
                      #<MSketchyPhysics3;;SP3xBodyContext;0x5d60418>
                      #<MSketchyPhysics3;;SP3xBodyContext;0x5d59e30>
                      #<MSketchyPhysics3;;SP3xBodyContext;0x5d547f0>
                      #<MSketchyPhysics3;;SP3xBodyContext;0x58268a8>
                      #<MSketchyPhysics3;;SP3xBodyContext;0x5769a28>
                      #<MSketchyPhysics3;;SP3xBodyContext;0x5fb2730>
                      #<MSketchyPhysics3;;SP3xBodyContext;0x5fad078>
                      #<MSketchyPhysics3;;SP3xBodyContext;0x5fa79a8>
                      #<MSketchyPhysics3;;SP3xBodyContext;0x5f8c870>
                      #<MSketchyPhysics3;;SP3xBodyContext;0x5f72c38>
                      #<MSketchyPhysics3;;SP3xBodyContext;0x5f64070>
                      initializing joint controllers
                      ["Time", 2.875, "Frames", 82, "Fps", 28.5217391304348]
                      • W Offline
                        Wacov
                        28 FPS is fine... keep 'em coming guys!
                          JaViXP
                          Here is mine.
                          ["Time", 7.551, "Frames", 72, "Fps", 9.53516090584029]
                          But... Why only 9.5!? 😢
                          "Giving up is way harder than trying"
                          JaViXP's Rendering
                            phy
                            Maybe it's vista, what's the specs on your computer Javi?
                              JaViXP
                              I don't think it is Vista (Wacov uses Vista as well). Anyway, here we go:
                              Pentium Dual-Core CPU E5300 @ 2.6 GHz
                              2GB RAM
                              ATI Radeon HD 4850
                              JaViXP's Rendering
                                phy
                                2GB RAM
                                ATI Radeon HD 4850
                                Yeah but Wacov has a gaming computer. But then with the specs you have it shouldn't be slowing down that much cause I only have 512 MB ram.
                                  JaViXP
                                  Mine is a gaming computer too, (I can run TS3, max quality, no lag). It is 5.2 / 5.9 in Vista's Perfomance Test. It might be SketchUp.
                                  JaViXP's Rendering
                                    phy
                                    I see, I guess I was just going by how much ram you had.
                                    • Roguer1R Offline
                                      Roguer1
                                      Great showcase Wacov!
                                      I am running:
                                      1.86GHz Intel
                                      2GB Ram
                                      358MB Mobile Intel 965 Express Chipset
                                      I get anywhere from 20 - 30FPS with no problem 😄
                                      Find all my models on the 3D Warehouse
                                        phy
                                        I'm running
                                        1.8 ghz. AMD
                                        512 MB. ram
                                        212(something like that)MB NVIDIA
                                        But I have XP so it runs fast.
                                        it might be sketchup or another plugin.
                                          Sgt.A.Johnson
                                          Im running vista on a laptop with: 2ghz single core pentium celeron, 3gb RAM, 358MB Mobile Intel 965 Express Chipset. overall windows experience=3.1 on graphics. gaming graphics 3.3, processor 4.2, RAM 4.5, hard disk 5.2
                                          • W Offline
                                            Wacov
                                            Uhh, I need the FPS 😄
                                            Anyway, from the looks of it, only Jav is having a problem (sorry mate). The particle system should work fine for most users!
                                            • 1 / 3
