Particle FX preview
46 Posts 12 Posters 3.8k Views
  • W Offline
    Wacov
    This is a new particle effects system I'm developing. I'm going to be mean, and not post the model, but I assure you all these pics are from a real-time simulation, running happily at around 40FPS. Enjoy!
      chango70
      LOL how cool is that! Can't wait!
        JaViXP
        Wow! Looks awesome, can't wait! 🎉
        "Giving up is way harder than trying"
        JaViXP's Rendering
          BTM
          nice idea 👍
            phy
            Good going wacov. svn?
            Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
              Physicsguy1
              That looks nice 😄. Now we need sparks and such for metal grinding, and some other characteristics.
                phy
                You want to know whats best, it hardly slows the simulation at all since it's not using the physics engine.
                  Physicsguy1
                  I cant wait! Are those bubbles in the water actual moving bubbles, or are they just random, and appear for a jiffy and depart without movement?
                  • W Offline
                    Wacov
                    Glad to see it's popular 😄 ... all the particles move, scale, and fade out. They can be given starting velocity, which will deminish after a few frames, and have some random values attached to keep it all interesting. @Physicsguy, the bubbles are created randomly, but they still move towards the surface.
                    This should all be added into SP in the near future, with a different method system. Until then, here's the demo for you all to try out (Feedback on performance would be great)
                    particle FX demo.skp
                    • W Offline
                      Wacov
                      Okay, just heard about a very slow simulation. Before you run the sim, please open the ruby console (Window/Ruby Console). Play the sim for a bit, reset, and post the last number in the array (after "Fps"). If you can run a normal sim ok, it should be at least 20. Thanks!
                        phy
                        Great 👍
                          phy
                          I got this
                          Inspecting model for errors
                          #<MSketchyPhysics3;;SP3xBodyContext;0x5da3d08>
                          #<MSketchyPhysics3;;SP3xBodyContext;0x5d90b38>
                          #<MSketchyPhysics3;;SP3xBodyContext;0x5d847c0>
                          #<MSketchyPhysics3;;SP3xBodyContext;0x5d78370>
                          #<MSketchyPhysics3;;SP3xBodyContext;0x5d6c3d0>
                          #<MSketchyPhysics3;;SP3xBodyContext;0x5d60418>
                          #<MSketchyPhysics3;;SP3xBodyContext;0x5d59e30>
                          #<MSketchyPhysics3;;SP3xBodyContext;0x5d547f0>
                          #<MSketchyPhysics3;;SP3xBodyContext;0x58268a8>
                          #<MSketchyPhysics3;;SP3xBodyContext;0x5769a28>
                          #<MSketchyPhysics3;;SP3xBodyContext;0x5fb2730>
                          #<MSketchyPhysics3;;SP3xBodyContext;0x5fad078>
                          #<MSketchyPhysics3;;SP3xBodyContext;0x5fa79a8>
                          #<MSketchyPhysics3;;SP3xBodyContext;0x5f8c870>
                          #<MSketchyPhysics3;;SP3xBodyContext;0x5f72c38>
                          #<MSketchyPhysics3;;SP3xBodyContext;0x5f64070>
                          initializing joint controllers
                          ["Time", 2.875, "Frames", 82, "Fps", 28.5217391304348]
                          • W Offline
                            Wacov
                            28 FPS is fine... keep 'em coming guys!
                              JaViXP
                              Here is mine.
                              ["Time", 7.551, "Frames", 72, "Fps", 9.53516090584029]
                              But... Why only 9.5!? 😢
                              JaViXP's Rendering
                                phy
                                Maybe it's vista, what's the specs on your computer Javi?
                                  JaViXP
                                  I don't think it is Vista (Wacov uses Vista as well). Anyway, here we go:
                                  Pentium Dual-Core CPU E5300 @ 2.6 GHz
                                  2GB RAM
                                  ATI Radeon HD 4850
                                  JaViXP's Rendering
                                    phy
                                    2GB RAM
                                    ATI Radeon HD 4850
                                    Yeah but Wacov has a gaming computer. But then with the specs you have it shouldn't be slowing down that much cause I only have 512 MB ram.
                                      JaViXP
                                      Mine is a gaming computer too, (I can run TS3, max quality, no lag). It is 5.2 / 5.9 in Vista's Perfomance Test. It might be SketchUp.
                                      JaViXP's Rendering
                                        phy
                                        I see, I guess I was just going by how much ram you had.
                                        • Roguer1R Offline
                                          Roguer1
                                          Great showcase Wacov!
                                          I am running:
                                          1.86GHz Intel
                                          2GB Ram
                                          358MB Mobile Intel 965 Express Chipset
                                          I get anywhere from 20 - 30FPS with no problem 😄
                                          Find all my models on the [3D Warehouse](https://3dwarehouse.sketchup.com/user/d8bb4d13-3b01-44a0-a007-4a77a32b6433/Ben-B?tab)
                                          • 1 / 3
                                          1 / 3
