    1.5k Posts 478 Posters 4.3m Views 478 Watching
      Here's my error message...FredoTraceRoundCorner[1mcube100mmbevel all edgesTIG].txt
      • StinkieS
        Stinkie
        I have tried it, and it works great. This ruby is an enormous time saver. Really happy with it. ☀
        • fredo6F
          @boilingsnow said:
          I tested it just now, it seems this ruby is still not very stable?
          It couses frequently sketchup errors and the program quits automatically everytime. Sometimes even when I was just do simple round corner on two sides, not to mention other more complicated objects. Perhaps that's only my problem due to my PC or some other personal settings? I don't know.
          But fredo I think you can make it better.
          It seems you are one of the users who get a bugsplat with SU7 (even with simple geometry).
          Would you mind to refer to this link http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&st=0&sk=t&sd=a&start=15#p171844, use the modified file and report the txt.
          I am unable to reproduce the bugsplat in my environments (actually I never got a splat when writing and testing teh plugin), so I need users getting it to give me some hints on where it could come from.
          • fredo6F
            @mitcorb said:
            Hi, Fredo:
            This tool looks interesting.
            Would this be complimentary to Bevel and Round Edges by Bezier?
            mitcorb
            RoundCorner includes a Sharp Mode as in RoundeEdges by Bezier. But you can keep both in parallel safely. RoundCorner also does Beveling (the green-gray icon).
            • B
              boilingsnow
              I have not tried this jet, but I am sooooooo exited that I must say something first!
              I've been waiting this for ages.
              Edit
              PS.
              I tested it in sketchup 6 again (just now was in skechup 7), and it works nicely.
              so I can imagine that the ruby still has some conflicts with sketchup 7.
              • mitcorbM
                mitcorb
                We will all be eternally grateful to you, "Mr. Wizard". Thank you again.
                • B
                  boilingsnow
                  Thank you for you reply.
                  hier is the first error report I got.
                  [0.000000 ms] : Sat Jul 11 00:28:24 2009 - RUBY_PLATFORM = i386-mswin32
                  [0.000000 ms] : Preparing geometry
                  [0.000000 ms] : Compute corners 24
                  [0.030000 ms] : Compute edge roundings 36
                  [0.040000 ms] : Compute triangulated 0
                  [0.040000 ms] : End Preparing geometry
                  [0.040000 ms] : Launching the processing of geometry Nbsteps = 277
                  [0.040000 ms] : Scheduler processing: Step = 0 ipos = 0
                  [0.040000 ms] : Processing chunk: Init Step = 0 ipos = 0
                  [0.711000 ms] : Processing chunk: Terminate Step = 0 ipos = 0
                  [0.711000 ms] : Processing chunk: Init Step = 1 ipos = 0
                  [0.731000 ms] : Processing chunk: Terminate Step = 1 ipos = 0
                  [0.731000 ms] : Processing chunk: Init Step = 2 ipos = 0 grptempo = #Sketchup::Group:0x11751360
                  [0.901000 ms] : Processing chunk: Terminate Step = 2 ipos = 0
                  [0.901000 ms] : Processing chunk: Init Step = 3 ipos = 0 grptempo = #Sketchup::Group:0x11751360
                  [0.901000 ms] : Processing chunk: Terminate Step = 3 ipos = 0
                  [0.901000 ms] : Processing chunk: Init Step = 4 ipos = 0 grptempo = #Sketchup::Group:0x11751360
                    sepo
                    Fantastic Fredo....very smart ....Thanks very much.
                    • K
                      Karlfucious
                      Works great, Thank you VERY much.
                      • EscapeArtistE
                        EscapeArtist
                        As always, fantastic job Fredo. SU woudln't be what it is without all these fantastic community-made plugins.
                          Jörg
                          Just amazing!!!!!!! 😍
                          Thank you very, very much, Fredo!!!!!
                          Jörg
                            dylan
                            Has anyone got this to work on a Mac?
                            I cannot get the plugin to show.
                            I have tried installing to the following locations:
                            Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins
                            User/Library/Application Support/Google SketchUp 7/SketchUp/plugins
                            http://dmdarchitecture.co.uk/
                              Splats as before, hourglass appears very briefly before splat-screen.
                              Here's latest report...FredoTraceRoundCorner[TIG-20090711].txt
                              • bagateloB
                                bagatelo
                                With which words I could thank for your work, Fredo6? Simply fantastic.
                                And with me again, in SU 7 bug splat, SU 6, works fine.
                                Thanks again.
                                • N
                                  numerobis
                                  WOW! This is incredible! 😲 😮 😲
                                  Great Work! 😄
                                  Thank You very very much!!!! 😍
                                  the whole skp dev team (if there is one existing - don't know, after seeing v7) should quit developing new functions and concentrate on x64 and highpoly support ...or go home instead.
                                  Sketchup v6.9 "Community Edition" rockz!!! 😎 💚
                                  • fredo6F
                                    I have been trying in SU7 on more complex models. Still does not get a bugsplat.
                                    On 3D letters, RoundCorner gives better results than the old RoundEdge.
                                    Font = Matura MT Script - SU7 file
                                    • bagateloB
                                      bagatelo
                                      I have using SU 7 on Windows Vista x64 SP1 and I have always bug splat.
                                      I have instaled Windows XP SP3 x86 on another HD and until now I don't have Bug Splat.
                                      Maybe the problem is with Windows Vista.
                                      • fredo6F
                                        I doubt this comes from the operating system. I have myself Vista x64 and does not have problem. Did you try with the latest ruby files I posted (2 messages above)?
                                          delarc
                                          This plug in works incredible and very easy to use ... Thank you very much Fredo6...
                                            I don't know what you did exactly to the files BUT all of the options now work perfectly... without a single bugsplat - despite my best [worst] efforts to make one !
                                            Well fixed !!!
                                            [Now all you have to do is stop it writing the 'FredoTraceRoundCorner.txt' file into Plugins and it'll be 'perfect'...]
                                            • 74
                                            • 75
                                            • 2 / 75
