    1.5k Posts 478 Posters 4.3m Views 478 Watching
    • fredo6F
      Yep with little measures that splatting soon as Enter!
      Beginning to see the time scroll barr... then plaffffffffff! 😄
      Something like these measures for first tool!
      Pilou,
      First, this does not seem to me to be 'little measures' but more just a normal case (5 cm on 3m).
      Second, are you sure the attached file is the one corresponding to the bugsplat. Its content indicates the operation terminated normally.
      • mitcorbM
        mitcorb
        Hi, Fredo:
        This tool looks interesting.
        Would this be complimentary to Bevel and Round Edges by Bezier?
        mitcorb
          Here's my error message...FredoTraceRoundCorner[1mcube100mmbevel all edgesTIG].txt
          • StinkieS
            Stinkie
            I have tried it, and it works great. This ruby is an enormous time saver. Really happy with it. ☀
            • fredo6F
              @boilingsnow said:
              I tested it just now, it seems this ruby is still not very stable?
              It couses frequently sketchup errors and the program quits automatically everytime. Sometimes even when I was just do simple round corner on two sides, not to mention other more complicated objects. Perhaps that's only my problem due to my PC or some other personal settings? I don't know.
              But fredo I think you can make it better.
              It seems you are one of the users who get a bugsplat with SU7 (even with simple geometry).
              Would you mind to refer to this link http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&st=0&sk=t&sd=a&start=15#p171844, use the modified file and report the txt.
              I am unable to reproduce the bugsplat in my environments (actually I never got a splat when writing and testing teh plugin), so I need users getting it to give me some hints on where it could come from.
              • fredo6F
                @mitcorb said:
                Hi, Fredo:
                mitcorb
                RoundCorner includes a Sharp Mode as in RoundeEdges by Bezier. But you can keep both in parallel safely. RoundCorner also does Beveling (the green-gray icon).
                • B
                  boilingsnow
                  I have not tried this jet, but I am sooooooo exited that I must say something first!
                  I've been waiting this for ages.
                  Edit
                  PS.
                  I tested it in sketchup 6 again (just now was in skechup 7), and it works nicely.
                  so I can imagine that the ruby still has some conflicts with sketchup 7.
                  • mitcorbM
                    mitcorb
                    We will all be eternally grateful to you, "Mr. Wizard". Thank you again.
                    • B
                      boilingsnow
                      Thank you for you reply.
                      hier is the first error report I got.
                      [0.000000 ms] : Sat Jul 11 00:28:24 2009 - RUBY_PLATFORM = i386-mswin32
                      [0.000000 ms] : Preparing geometry
                      [0.000000 ms] : Compute corners 24
                      [0.030000 ms] : Compute edge roundings 36
                      [0.040000 ms] : Compute triangulated 0
                      [0.040000 ms] : End Preparing geometry
                      [0.040000 ms] : Launching the processing of geometry Nbsteps = 277
                      [0.040000 ms] : Scheduler processing: Step = 0 ipos = 0
                      [0.040000 ms] : Processing chunk: Init Step = 0 ipos = 0
                      [0.711000 ms] : Processing chunk: Terminate Step = 0 ipos = 0
                      [0.711000 ms] : Processing chunk: Init Step = 1 ipos = 0
                      [0.731000 ms] : Processing chunk: Terminate Step = 1 ipos = 0
                      [0.731000 ms] : Processing chunk: Init Step = 2 ipos = 0 grptempo = #Sketchup::Group:0x11751360
                      [0.901000 ms] : Processing chunk: Terminate Step = 2 ipos = 0
                      [0.901000 ms] : Processing chunk: Init Step = 3 ipos = 0 grptempo = #Sketchup::Group:0x11751360
                      [0.901000 ms] : Processing chunk: Terminate Step = 3 ipos = 0
                      [0.901000 ms] : Processing chunk: Init Step = 4 ipos = 0 grptempo = #Sketchup::Group:0x11751360
                        sepo
                        Fantastic Fredo....very smart ....Thanks very much.
                        • K
                          Karlfucious
                          Works great, Thank you VERY much.
                          • EscapeArtistE
                            EscapeArtist
                            As always, fantastic job Fredo. SU woudln't be what it is without all these fantastic community-made plugins.
                              Jörg
                              Just amazing!!!!!!! 😍
                              Thank you very, very much, Fredo!!!!!
                              Jörg
                                dylan
                                Has anyone got this to work on a Mac?
                                I cannot get the plugin to show.
                                I have tried installing to the following locations:
                                Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins
                                User/Library/Application Support/Google SketchUp 7/SketchUp/plugins
                                http://dmdarchitecture.co.uk/
                                  Splats as before, hourglass appears very briefly before splat-screen.
                                  Here's latest report...FredoTraceRoundCorner[TIG-20090711].txt
                                  • bagateloB
                                    bagatelo
                                    With which words I could thank for your work, Fredo6? Simply fantastic.
                                    And with me again, in SU 7 bug splat, SU 6, works fine.
                                    Thanks again.
                                    • N
                                      numerobis
                                      WOW! This is incredible! 😲 😮 😲
                                      Great Work! 😄
                                      Thank You very very much!!!! 😍
                                      the whole skp dev team (if there is one existing - don't know, after seeing v7) should quit developing new functions and concentrate on x64 and highpoly support ...or go home instead.
                                      Sketchup v6.9 "Community Edition" rockz!!! 😎 💚
                                      • fredo6F
                                        I have been trying in SU7 on more complex models. Still does not get a bugsplat.
                                        On 3D letters, RoundCorner gives better results than the old RoundEdge.
                                        Font = Matura MT Script - SU7 file
                                        • bagateloB
                                          bagatelo
                                          I have using SU 7 on Windows Vista x64 SP1 and I have always bug splat.
                                          I have instaled Windows XP SP3 x86 on another HD and until now I don't have Bug Splat.
                                          Maybe the problem is with Windows Vista.
                                          • fredo6F
                                            I doubt this comes from the operating system. I have myself Vista x64 and does not have problem. Did you try with the latest ruby files I posted (2 messages above)?
                                            • 74
                                            • 75
                                            • 2 / 75
