    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
      lexmonteiro
      Hi Chris, It is possible to the texture bend with the model?
      • Chris FullmerC Offline
        Hi Lex, that is a good question. I think someone else had also asked about that previously. I'm not sure how easy or hard it will be to do. I pretty much never use textures and I've never touched them using Ruby yet, so its possible it might be pretty straightforward.
        When I re-work this script, I'll see if I can get it to treat textures better.
          lexmonteiro
          Thanks for the quick answer, I was searching for some plugin that help me to create a road, and ajust the texture to fit in the curves. This could be a very good tool
          Anyway, thank you very much for this plugin!
          Cheers
          Alexandre
            @chris fullmer said:
            Hi Lex, that is a good question. I think someone else had also asked about that previously...
            That was me. And I'm still looking forward to that. 🎉
            Did I say I'm looking forward to it? 😒
            • SwissmountainS Offline
              Swissmountain
              Thanks for the Plugin, nice work! 👍
              Cogito ergo dum-di-dum
              • simon le bonS Offline
                simon le bon
                Bonjour Chris,
                What a plugin! I enjoy the originality of the approach, I am surprise by it great power, and I applaud to it accomplishment 👍 👍
                I had made some studies with it and here are some of the results
                ShapeBender Basics Studies:
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BasicStudies_640.jpg
                Basic Studies SlideShow(Adobe PhotoExpress)
                ShapeBender_Wrap Test
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/WrapTest_640.jpg
                Wrap Test SlideShow >>or the album (Picasa Album/Slideshow)
                (I noticed some difficulties, but I'll tell you later)
                simon
                  does it possible to have the result with the same number of groups than the start?
                  see this post 😉
                    Coronel
                    The problem is with the compspray.rb
                    Update it from here:
                    http://forums.sketchucation.com/viewtopic.php?f=180&t=11746
                    Didier had a bug in it that was breaking the progressbar, but he fixed it nicely. So just update that, then it should work.
                    Let me know if that does not help.
                    It didn't work with new compspray, but I removed it and it worked!
                    It's working fine again after compspray removing too on Mac
                      Oh good, glad its working Coronel. There is a new version of component spary that you can download and safely install. Didier fixed it up so it doesn't conflict with anything.
                        rem_s
                        I try to use the shape bender but nothing happen. When I open the ruby console I saw an error message :
                        Error: #<NoMethodError: undefined method /' for nil:NilClass> C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_shape_bender/clf_shape_bender.rb:671:in draw'
                          Do you have an old version of Component Spray installed?
                            rem_s
                            Yes but it still not work
                              Thom asked if you had an old version installed, because the old version causes my script to break. Try updating to the new component spray hee:
                              Funny thing is, compspray causes ANY script that uses the progressbar to break (including MakeFaces!). But seems like people only notice it on my script 😞
                              Anyhow, update it and see if that helps.
                              • charly2008C Offline
                                charly2008
                                Hi Chris,
                                i had the same problem. I installed the compo spray version you mentioned above. But the problem was not solved. i had to remove the compo spray from the plugins folder, than shape bender worked fine.
                                Karlheinz
                                  That really shouldn't be the case though. The new compo spray no longer intereferes with the other scripts. So if you installed the new compo spray correctly, it will fix the issue.
                                  I don't want people to think that there is a problem with compo spray, because it works well.
                                  • H Offline
                                    hasan
                                    Chris,
                                    I am really impressed by what you achieved. This is a master transformation
                                    I played a little bit with it, and I think you got the essentials. The rest is just about adjustments in UI and options. And indeed to extend it to embedded components.
                                    Well done!
                                      Did you ever get it working Hasan?
                                        tomot
                                        Wow! great tool. It looks like it would not be to hard to change the code to create orientated text for a Catenary curve? Which is not possible in the present version. 😢
                                        my plugins
                                        tomot
                                          Hi Tomot, sure it can do a catenary curve. You just have to be able to draw one on your own, which I suppose is the hard part. This script will bend a shape to match any supplied line/curve. So if you can draw the catenary curve, it will certainly bend to match it.
                                            tomot
                                            yes I know, but as my pic shows I would like the text oriented so that I don't have to read it upside down
                                            my plugins
                                            tomot
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 63
                                            • 64
                                            • 30 / 64
