    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.5m Views 329 Watching
      @rem_s said:
      I try to use the shape bender but nothing happen. When I open the ruby console I saw an error message :
      Error: #<NoMethodError: undefined method /' for nil:NilClass> C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_shape_bender/clf_shape_bender.rb:671:in draw'
      Do you have an old version of Component Spray installed?
        rem_s
        Yes but it still not work
        • Chris FullmerC
          Thom asked if you had an old version installed, because the old version causes my script to break. Try updating to the new component spray hee:
          http://forums.sketchucation.com/viewtopic.php?f=180&t=11746
          Funny thing is, compspray causes ANY script that uses the progressbar to break (including MakeFaces!). But seems like people only notice it on my script 😞
          Anyhow, update it and see if that helps.
          • charly2008C
            charly2008
            Hi Chris,
            i had the same problem. I installed the compo spray version you mentioned above. But the problem was not solved. i had to remove the compo spray from the plugins folder, than shape bender worked fine.
            Karlheinz
            • Chris FullmerC
              That really shouldn't be the case though. The new compo spray no longer intereferes with the other scripts. So if you installed the new compo spray correctly, it will fix the issue.
              I don't want people to think that there is a problem with compo spray, because it works well.
              • H
                hasan
                Chris,
                I am really impressed by what you achieved. This is a master transformation
                I played a little bit with it, and I think you got the essentials. The rest is just about adjustments in UI and options. And indeed to extend it to embedded components.
                Well done!
                • Chris FullmerC
                  Did you ever get it working Hasan?
                  • T
                    tomot
                    Wow! great tool. It looks like it would not be to hard to change the code to create orientated text for a Catenary curve? Which is not possible in the present version. 😢
                    my plugins
                    tomot
                    • Chris FullmerC
                      Hi Tomot, sure it can do a catenary curve. You just have to be able to draw one on your own, which I suppose is the hard part. This script will bend a shape to match any supplied line/curve. So if you can draw the catenary curve, it will certainly bend to match it.
                      • T
                        tomot
                        yes I know, but as my pic shows I would like the text oriented so that I don't have to read it upside down
                        my plugins
                        tomot
                        • T
                          tomot
                          I just discovered that the first implementation of Shape bender will influence a second implementation, in the same file. however I can combine one with cutting and pasting from another file.
                          my plugins
                          tomot
                          • Chris FullmerC
                            Hey, thats it! That is something that has come up but I could never quite put a finger on what was going on. There has always been a bug where often the 2nd time you bend a shape, it does not work as expected. I think I am carrying overy information between shape bender uses.
                            As for your text, just turn it upside before you bend the bottom one. That will doe the trick.
                              JesperWille
                              Consider this: - I (shamefully!) haven't kept up on plugins for a while, and this is pretty much the first new one I've tried in, well, a year or more... now ask me if my mind is in anyway blown.
                              Excellent piece of software there, Chris, and thank you a thousand times for sharing it!
                              I am currently running it with the latest 7.1 beta, I'll be sure to let you know if anything comes up - so far, flawless.
                              Thanks again mate!
                              Jesper W.
                              http://www.jesperwille.com
                              • EarthMoverE
                                EarthMover
                                It's great isn't it jesper!? I just wanted to say thanks again as well to Chris. I use this tool on every project and I'm really thankful to have it in my repertoire! It's been a real blessing!
                                Content Creator at Skapeup
                                • K
                                  kwistenbiebel
                                  Jesper is right.
                                  All these new rubies are wonderful. We should not take them for granted.
                                  Thanks plugin developers!
                                  • olisheaO
                                    olishea
                                    great tool, thank you. very easy to use as well.
                                    oli
                                    • Chris FullmerC
                                      Thanks for all the encouragement and kind words everyone. Great to see you on here Jesper! Its been a long time.
                                      This is one of my favorite plugins, but it also has the most bugs. So its fun, but also frustrating. This is one on my list of things to do - get this thing re-written. I'm currently updating a few of my other scripts, but they are all small and simple compared to this beast. So once I finish moving in to my new house (just moved with last weekened), I'll try to make this script one of my priorities. I think I need to tidy up my existing scripts before I tackle anything new.
                                      So again, thanks for the comments. It definitely helps the motivation.
                                      • C
                                        CYS
                                        I've downloaded progressbar and shape bender into my plugins folder and restarted sketchup but there is no "Chris Fullmer tools" in my plugins menu. I do seem to have all of the appropriate files in my plugins folder.
                                        I'm using SU7pro with a Mac- OSX 10.5.8
                                        I have been using a few other plugins with no problem (not component spray) but there are also a few that don't come up in any drop down menus nor display any icons. What I am I missing here? Thanks
                                        • H
                                          hasan
                                          :thumb:[attachment=0:3v20wngf]<!-- ia0 -->20090408134624_9s.jpg<!-- ia0 -->[/attachment:3v20wngf]
                                          Thanks again mate!
                                          Jesper W.
                                          • david_hD
                                            david_h
                                            bender-futurama.png 👍
                                            I heartily endorse this Plugin. . . .Bender
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 63
                                            • 64
                                            • 12 / 64
