    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.2m Views 329 Watching
      rem_s
      I try to use the shape bender but nothing happen. When I open the ruby console I saw an error message :
      Error: #<NoMethodError: undefined method /' for nil:NilClass> C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_shape_bender/clf_shape_bender.rb:671:in draw'
        Do you have an old version of Component Spray installed?
          rem_s
          Yes but it still not work
          • Chris FullmerC Offline
            Thom asked if you had an old version installed, because the old version causes my script to break. Try updating to the new component spray hee:
            404 Not Found
            (forums.sketchucation.com)
            Funny thing is, compspray causes ANY script that uses the progressbar to break (including MakeFaces!). But seems like people only notice it on my script 😞
            Anyhow, update it and see if that helps.
            • charly2008C Offline
              charly2008
              Hi Chris,
              i had the same problem. I installed the compo spray version you mentioned above. But the problem was not solved. i had to remove the compo spray from the plugins folder, than shape bender worked fine.
              Karlheinz
                That really shouldn't be the case though. The new compo spray no longer intereferes with the other scripts. So if you installed the new compo spray correctly, it will fix the issue.
                I don't want people to think that there is a problem with compo spray, because it works well.
                • H Offline
                  hasan
                  Chris,
                  I am really impressed by what you achieved. This is a master transformation
                  I played a little bit with it, and I think you got the essentials. The rest is just about adjustments in UI and options. And indeed to extend it to embedded components.
                  Well done!
                    Did you ever get it working Hasan?
                      tomot
                      Wow! great tool. It looks like it would not be to hard to change the code to create orientated text for a Catenary curve? Which is not possible in the present version. 😢
                      my plugins
                      tomot
                        Hi Tomot, sure it can do a catenary curve. You just have to be able to draw one on your own, which I suppose is the hard part. This script will bend a shape to match any supplied line/curve. So if you can draw the catenary curve, it will certainly bend to match it.
                          tomot
                          yes I know, but as my pic shows I would like the text oriented so that I don't have to read it upside down
                          my plugins
                          tomot
                            tomot
                            I just discovered that the first implementation of Shape bender will influence a second implementation, in the same file. however I can combine one with cutting and pasting from another file.
                            my plugins
                            tomot
                              Hey, thats it! That is something that has come up but I could never quite put a finger on what was going on. There has always been a bug where often the 2nd time you bend a shape, it does not work as expected. I think I am carrying overy information between shape bender uses.
                              As for your text, just turn it upside before you bend the bottom one. That will doe the trick.
                                JesperWille
                                Consider this: - I (shamefully!) haven't kept up on plugins for a while, and this is pretty much the first new one I've tried in, well, a year or more... now ask me if my mind is in anyway blown.
                                Excellent piece of software there, Chris, and thank you a thousand times for sharing it!
                                I am currently running it with the latest 7.1 beta, I'll be sure to let you know if anything comes up - so far, flawless.
                                Thanks again mate!
                                Jesper W.
                                http://www.jesperwille.com
                                • EarthMoverE Offline
                                  EarthMover
                                  It's great isn't it jesper!? I just wanted to say thanks again as well to Chris. I use this tool on every project and I'm really thankful to have it in my repertoire! It's been a real blessing!
                                  Content Creator at Skapeup
                                    kwistenbiebel
                                    Jesper is right.
                                    All these new rubies are wonderful. We should not take them for granted.
                                    Thanks plugin developers!
                                    • olisheaO Offline
                                      olishea
                                      great tool, thank you. very easy to use as well.
                                      oli
                                        Thanks for all the encouragement and kind words everyone. Great to see you on here Jesper! Its been a long time.
                                        This is one of my favorite plugins, but it also has the most bugs. So its fun, but also frustrating. This is one on my list of things to do - get this thing re-written. I'm currently updating a few of my other scripts, but they are all small and simple compared to this beast. So once I finish moving in to my new house (just moved with last weekened), I'll try to make this script one of my priorities. I think I need to tidy up my existing scripts before I tackle anything new.
                                        So again, thanks for the comments. It definitely helps the motivation.
                                          CYS
                                          I've downloaded progressbar and shape bender into my plugins folder and restarted sketchup but there is no "Chris Fullmer tools" in my plugins menu. I do seem to have all of the appropriate files in my plugins folder.
                                          I'm using SU7pro with a Mac- OSX 10.5.8
                                          I have been using a few other plugins with no problem (not component spray) but there are also a few that don't come up in any drop down menus nor display any icons. What I am I missing here? Thanks
                                          • H Offline
                                            hasan
                                            :thumb:[attachment=0:3v20wngf]<!-- ia0 -->20090408134624_9s.jpg<!-- ia0 -->[/attachment:3v20wngf]
                                            Thanks again mate!
                                            Jesper W.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 63
                                            • 64
                                            • 12 / 64
