    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.3m Views 329 Watching
    • simon le bonS
      simon le bon
      Bonjour Chris,
      What a plugin! I enjoy the originality of the approach, I am surprise by it great power, and I applaud to it accomplishment 👍 👍
      I had made some studies with it and here are some of the results
      ShapeBender Basics Studies:
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BasicStudies_640.jpg
      Basic Studies SlideShow(Adobe PhotoExpress)
      ShapeBender_Wrap Test
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/WrapTest_640.jpg
      Wrap Test SlideShow >>or the album (Picasa Album/Slideshow)
      (I noticed some difficulties, but I'll tell you later)
      simon
        does it possible to have the result with the same number of groups than the start?
        see this post 😉
        • C
          Coronel
          @darkphysics said:
          @chris fullmer said:
          The problem is with the compspray.rb
          Update it from here:
          404 Not Found
          (forums.sketchucation.com)
          Didier had a bug in it that was breaking the progressbar, but he fixed it nicely. So just update that, then it should work.
          Let me know if that does not help.
          It didn't work with new compspray, but I removed it and it worked!
          It's working fine again after compspray removing too on Mac
          • Chris FullmerC
            Oh good, glad its working Coronel. There is a new version of component spary that you can download and safely install. Didier fixed it up so it doesn't conflict with anything.
              rem_s
              I try to use the shape bender but nothing happen. When I open the ruby console I saw an error message :
              Error: #<NoMethodError: undefined method /' for nil:NilClass> C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_shape_bender/clf_shape_bender.rb:671:in draw'
                Do you have an old version of Component Spray installed?
                  rem_s
                  Yes but it still not work
                  • Chris FullmerC
                    Thom asked if you had an old version installed, because the old version causes my script to break. Try updating to the new component spray hee:
                    404 Not Found
                    Funny thing is, compspray causes ANY script that uses the progressbar to break (including MakeFaces!). But seems like people only notice it on my script 😞
                    Anyhow, update it and see if that helps.
                    • charly2008C
                      charly2008
                      Hi Chris,
                      i had the same problem. I installed the compo spray version you mentioned above. But the problem was not solved. i had to remove the compo spray from the plugins folder, than shape bender worked fine.
                      Karlheinz
                      • Chris FullmerC
                        That really shouldn't be the case though. The new compo spray no longer intereferes with the other scripts. So if you installed the new compo spray correctly, it will fix the issue.
                        I don't want people to think that there is a problem with compo spray, because it works well.
                        • H
                          hasan
                          Chris,
                          I am really impressed by what you achieved. This is a master transformation
                          I played a little bit with it, and I think you got the essentials. The rest is just about adjustments in UI and options. And indeed to extend it to embedded components.
                          Well done!
                          • Chris FullmerC
                            Did you ever get it working Hasan?
                            • T
                              tomot
                              Wow! great tool. It looks like it would not be to hard to change the code to create orientated text for a Catenary curve? Which is not possible in the present version. 😢
                              my plugins
                              tomot
                              • Chris FullmerC
                                Hi Tomot, sure it can do a catenary curve. You just have to be able to draw one on your own, which I suppose is the hard part. This script will bend a shape to match any supplied line/curve. So if you can draw the catenary curve, it will certainly bend to match it.
                                • T
                                  tomot
                                  yes I know, but as my pic shows I would like the text oriented so that I don't have to read it upside down
                                  my plugins
                                  tomot
                                  • T
                                    tomot
                                    I just discovered that the first implementation of Shape bender will influence a second implementation, in the same file. however I can combine one with cutting and pasting from another file.
                                    my plugins
                                    tomot
                                    • Chris FullmerC
                                      Hey, thats it! That is something that has come up but I could never quite put a finger on what was going on. There has always been a bug where often the 2nd time you bend a shape, it does not work as expected. I think I am carrying overy information between shape bender uses.
                                      As for your text, just turn it upside before you bend the bottom one. That will doe the trick.
                                        JesperWille
                                        Consider this: - I (shamefully!) haven't kept up on plugins for a while, and this is pretty much the first new one I've tried in, well, a year or more... now ask me if my mind is in anyway blown.
                                        Excellent piece of software there, Chris, and thank you a thousand times for sharing it!
                                        I am currently running it with the latest 7.1 beta, I'll be sure to let you know if anything comes up - so far, flawless.
                                        Thanks again mate!
                                        Jesper W.
                                        http://www.jesperwille.com
                                        • EarthMoverE
                                          EarthMover
                                          It's great isn't it jesper!? I just wanted to say thanks again as well to Chris. I use this tool on every project and I'm really thankful to have it in my repertoire! It's been a real blessing!
                                          Content Creator at Skapeup
                                          • K
                                            kwistenbiebel
                                            Jesper is right.
                                            All these new rubies are wonderful. We should not take them for granted.
                                            Thanks plugin developers!
                                            • 11
                                            • 12
                                            • 13
                                            • 63
                                            • 64
                                            • 11 / 64
