Move groups with different measures?
Looking good Pilou!
Instant assembly drawings!This should come in handy.
Instant assembly
Alas for the inverse, that must be more tricky!
Better is use the Undo -
hm... You could store the relative position you move the entities by in and attribute dictionary. Then perform the opposite when you want to reassemble.
though, that will fail if the user moves anything...
Maybe, you could store the original absolute position before you move stuff. Then you can reassemble back to that original position. That would allow the user to move things around as they please. -
Store the original transformation in a dictionary attached to the group/component. Then to unexplode, just re-apply that transformation onto the group. It will go right back where it belongs.
I wrote that crazy scrambler script a while ago that does this and it worked very well.
In theory that must be more easy
Just select that you want and apply a "negative" translation : a deflation
Maybe my next
And the above is not yet perfect! The Pivot Point seems not have the wished result wanted
be continued...Ps When Groups or Components are nested how to process automatically?
A plug for make each components individual is maybe existing?
Edit
one exist for group by TIG Explode2groupsmiss now somethings transform Transform2goups or Explode2Components
@Chris Any chance to see it somewhere?
PS
Edit
one exist for group by TIG Explode2groupsmiss now somethings for components Transform2goups or Explode2Components
take the componentInstance, add it to a group, then explode the component instance.
And I posted my scrambler script here. I'll see if I can find the thread.
@Chris thx for the Info
Fredo6 has inside the FredoScale something who transform any selection of groups or Components in "Unique" groups or componants! (each become individual)
(last icon) -
Some tests
Put the code inside the WebConsole by Jim Foltz
Press "Eval" button and have fun
Veyron model is from 3Dwarehouse!model = Sketchup.active_model entities = model.entities selection = model.selection xp=100 # Pivot Point (as you want) yp=100 zp=100 q=50 # Measure of translation (as you want) selection.each do |e| # update! # Skip all entities that aren't groups or components (replace follow "ComponentInstance" by "Group" if you have groups next unless e.is_a? Sketchup;;ComponentInstance # Now we process the component or group center = e.bounds.center #Center Point of the grouped object xc= center.x yc= center.y zc= center.z xe=xc #End Point of the grouped object ye=yc ze=zc if xc<xp xe =xc - q end if xc>xp xe =xc + q end if yc<yp ye =yc - q end if yc>yp ye =yc + q end if zc<zp ze =zc - q end if zc>zp ze =zc + q end point = Geom;;Point3d.new xe,ye,ze t = Geom;;Transformation.new point # Apply the transformation e.transform!(t) end
Yep!!! THX! Miracle that is working!
Sure I should read the Api document beforeBut I had risked the trick
So my second script was a new speedy success and a big lesson@unknownuser said:
groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup::ComponentInstance)}
groups.each{|ComponentInstance|zeds.push([ComponentInstance.bounds.min.z, index])
Copy my code follow in the Web console from Jim Foltz
(if you have components use the file linked )model = Sketchup.active_model model.start_operation("Move in Z") entities = model.entities selection = model.selection zeds=[] index=0 sorted_groups=[] groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup;;Group)} groups.each{|group|zeds.push([group.bounds.min.z, index]) index+=1 } zeds.sort! zeds.each{|z|sorted_groups.push(groups[z[1]]) } ### sorted_groups is now groups sorted by z z = 0.0 sorted_groups.each do |e| # update! # Now we process the groups t = Geom;;Transformation.new(Geom;;Point3d.new(0,0,z)) # Apply the transformation e.transform!(t) z = z + 100.cm end model.commit_operation return nil
Some help for fun variations
