    [Plugin] Sculpt Tools (help)
    188 Posts 46 Posters 89.6k Views 46 Watching
      sepo
      Could actually someone post the one which works...of course with BTMs agreement. At moment this is crazy,
        Thanks, got the small/large icons and tweaked the scripts... now works fine...
          BTM
          @cadfather said:
          because mac is 🤢
          small icons here
          I already made my own small icons, but whatever. Good for the others untill the next one's up.
          Just a simple question, but is anyone willing to make better icons? I don't really like the ones it has right now, but don't know what the new ones should look like…
          Awesome, thanks TIG!
          BTM, I just PM'ed you a copy of the plugin with working icons on the PC, and a pc friendly zip, if you want to update the version here.
          Maybe put the current copy back in the first post? Or maybe it just needs a whole new topic now that its a [Plugin] ? Or maybe you want to wait til the final toolbar oddities get worked out?
          Why does everyone post things when I'm writing my posts/ editing the script myself! 😆
          I'll check my PMs, and yes, I'm planning on making a [Plugin] thread when all the oddities work out. I'll keep the download where it is for now, so that mostly the people downloading it are those who are testing it.
          Tell me about it 😒 👊
            BTM
            The download's been replaced with the one with good icons that Chris edited. My next fix of the mac issue should be up shortly.
              sepo
              BTM ...could you actually post the link for PC or at least say on which page it is. There are couple of download versions. Thanks
                BTM
                The download all link to the one on page 5.
                  Can I suggest a new "[Plugin] Sculpt" thread that has the updated stuff as its first post - it's getting confusing...
                    I've updated: triangulate.rb v1.1 to trap for 3 vertices in line and made a one-step undo http://forums.sketchucation.com/viewtopic.php?p=169956#p169956
                      sepo
                      It is not there anymore..
                        BTM
                        Sorry, I meant 4
                        http://forums.sketchucation.com/download/file.php?id=30086
                          BTM
                          Here's something to play with.
                          This is the template I used to make the face a while ago.
                            Daniel S
                            Thank you BTM!
                            a few ideas/requests:
                            • Is it possible to make a circle (or the shape of the brush) around the cursor? Something like the smoove tool or the circle tool? Something like this:
                              Will make it more "precise"
                            • Be able to change the radius of the brush in the vcb or measurements toolbar (this is possible to make for example with the smoove or circle tool so you don´t have to open the dialog every time you want to change desired size of the radius of the brush):
                              It will be faster to sculpt
                            Also I attach alternate icons. I take them from a mudbox tutorial... I only change the colors.
                            Alternate Sculpt Icons.zip
                            Daniel S
                              BTM
                              @daniel s said:
                              Thank you BTM!
                              http://forums.sketchucation.com/download/file.php?id=30091
                              http://forums.sketchucation.com/download/file.php?id=30092
                              http://forums.sketchucation.com/download/file.php?id=30093
                              Daniel S
                              First of all, I DO plan on adding visuals eventually, which include a soft radius circle, hard radius circle, and a direction line for the bulge tool. As for the radius in the VCB, I could do it, but I'd need to know who wants what setting to appear there (probably soft radius). For icons, those do give me some ideas.
                                BTM
                                Not yet, I'm hoping to get the plugin past all the problems first; I couldn't test it on windows myself though, so I guess you guys are the testers. 😄
                                • CadFatherC Offline
                                  CadFather
                                  Hi BTM - just to say this ruby is a jewel!!! Thank You in advance for all those easy sculps i shall be drawing!
                                    BTM
                                    … I've been messing around with view.draw lately, and have to say that its confusing. View only updates when the view changes, and in order to get it to update on mouse move, requires a lot of confusing things that I don't understand yet. I'll figure it out sooner or later…
                                      Jim
                                      calling view.invalidate forces a refresh. Hope that helps.
                                      • Chris FullmerC Offline
                                        When you figure it out, let me know 😄
                                        I've also had difficulty with it. I eventually get it to work, but I never feel confident I've implemented how it is supposed to be implemented.
                                          BTM
                                          That much I do know, but my problem is where to put it, and when to do it. 😕
                                          • mitcorbM Offline
                                            mitcorb
                                            Nice concatenation there, Majid.
                                            • 5 / 10
