    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 242.4k Views 76 Watching
      I get no loose edges with either of your skp's... There is orientation weirdness as sometimes threes faces share as edge as it's convoluted in on itself when a circle... to be on the safe side I am adjusting the script to trap any edges without faces... Look out for update...
        Here's v1.3 ...
        http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
        It's been trapped for rare unfaced edges - it either forces the edge to have a face, or erases the edge if it's not possible to add a face ...
          Have you tried this latest version ?
            There is always no possible to close some faces (my gap file above) 😉
            The curious is this is a "big face" 😮
            Maybe because angle is too flat?
            Not so a big deal to close it by hand 😉
              Did you still get unfaced edges ?
                yes the same than on my image above! (orange pale one)
                After Auto self convoluted stay 2 "big faces" (second of the revolution, and second of the profil)
                AND I have this one " 1.3 20090626 Edges not facing in convoluted shapes trapped."
                  Of ourse yes 😉
                  The curious was there same size so maybe you have not posted the good version?
                  • K
                    Koosie van Tutte
                    thanks a lot!
                      AcesHigh
                      TIG, very nice plugin... can you improve it to add the option for another rail "edge", thus effectively transforming it into a SWEEP 2 RAILS plugin??
                      http://www.kxcad.net/autodesk/Autodesk_VIZ_Help/graphics/il_nurbs_sweep2.jpg
                      http://moi3d.com/1.0/docs/screenshots/Sweep9.jpg
                      http://moi3d.com/1.0/docs/screenshots/Sweep10.jpg
                      http://moi3d.com/1.0/docs/screenshots/Sweep11.jpg
                      http://moi3d.com/1.0/docs/screenshots/Sweep12.jpg
                      http://moi3d.com/1.0/docs/screenshots/Sweep13.jpg
                        It's on the list...
                          seems one of the Moi's example above is 3 rails 😉
                          • MALAISEM
                            MALAISE
                            Hi TIG
                            May you'll better understand as me that message. I loaded the V1.3, but no results
                            I reload the file.rb but get the same result.captured screen using ExtrudeEdge to edge
                            Do you have the V1.2 somewhere ? ( It worked )
                            MALAISE 👍
                              Malaise I've PM'd you about getting the skp sent so I can test it...
                              Are the selected just two groups of edges ?
                              • JClementsJ
                                JClements
                                Well TIG, this is a nice script and I hope sweep-two-rails can be done (keeping my fingers crossed 😄 ). It could be a big time saver for doing landscape/topographical, asymetrical surfaces.
                                • O
                                  orei
                                  i hope sooo!!! wonderful script!!!
                                  • MALAISEM
                                    MALAISE
                                    Hi All
                                    I have encountered some strange behaviour of TIG' last Plugin. Have you notice that Experimental SketchyPhysic 3X may block ExtrudeEdges ?
                                    Using SketchyPhysic 2 , no problem at all .... please let's share your comments
                                    MALAISE 😄
                                      Don't see where the clash could be [yet] ?
                                      • C
                                        chango70
                                        @tig said:
                                        It's on the list...
                                        Drool...
                                        • kerabeK
                                          kerabe
                                          Wow, what a great plugin! Just downloaded it and have been playing around with it and I have had no real problems at all. Had to do some minor clean-up work but nothing unusual. Love it. 😄
                                          The CH124: If it isn't leaking, you're out of oil...
                                            Version 1.4 is now out... http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
                                            1.4 20090707 Triangulation improved [as my recent triangulate.rb]. Rare intersect glitch fixed.
                                            • 4 / 10
