    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 228.7k Views 76 Watching
      Of ourse yes 😉
      The curious was there same size so maybe you have not posted the good version?
        Koosie van Tutte
        thanks a lot!
          AcesHigh
          TIG, very nice plugin... can you improve it to add the option for another rail "edge", thus effectively transforming it into a SWEEP 2 RAILS plugin??
          http://www.kxcad.net/autodesk/Autodesk_VIZ_Help/graphics/il_nurbs_sweep2.jpg
          http://moi3d.com/1.0/docs/screenshots/Sweep9.jpg
          http://moi3d.com/1.0/docs/screenshots/Sweep10.jpg
          http://moi3d.com/1.0/docs/screenshots/Sweep11.jpg
          http://moi3d.com/1.0/docs/screenshots/Sweep12.jpg
          http://moi3d.com/1.0/docs/screenshots/Sweep13.jpg
            It's on the list...
              seems one of the Moi's example above is 3 rails 😉
              • MALAISEM Offline
                MALAISE
                Hi TIG
                May you'll better understand as me that message. I loaded the V1.3, but no results
                I reload the file.rb but get the same result.captured screen using ExtrudeEdge to edge
                Do you have the V1.2 somewhere ? ( It worked )
                MALAISE 👍
                  Malaise I've PM'd you about getting the skp sent so I can test it...
                  Are the selected just two groups of edges ?
                  • JClementsJ Offline
                    JClements
                    Well TIG, this is a nice script and I hope sweep-two-rails can be done (keeping my fingers crossed 😄 ). It could be a big time saver for doing landscape/topographical, asymetrical surfaces.
                    • O Offline
                      orei
                      i hope sooo!!! wonderful script!!!
                      • MALAISEM Offline
                        MALAISE
                        Hi All
                        I have encountered some strange behaviour of TIG' last Plugin. Have you notice that Experimental SketchyPhysic 3X may block ExtrudeEdges ?
                        Using SketchyPhysic 2 , no problem at all .... please let's share your comments
                        MALAISE 😄
                          Don't see where the clash could be [yet] ?
                            chango70
                            @tig said:
                            It's on the list...
                            Drool...
                            • kerabeK Offline
                              kerabe
                              Wow, what a great plugin! Just downloaded it and have been playing around with it and I have had no real problems at all. Had to do some minor clean-up work but nothing unusual. Love it. 😄
                              The CH124: If it isn't leaking, you're out of oil...
                                Version 1.4 is now out... http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
                                1.4 20090707 Triangulation improved [as my recent triangulate.rb]. Rare intersect glitch fixed.
                                  Trivial problem 😄
                                  if the groups are on the full screen result is out of the screen an no possibity to see it before to reply all the box dialog!
                                  So will be cool that an automatic resize exist before process 😉
                                  Sure I can zoom out but... 😉
                                    mpowell1234567890
                                    Help, I cannot get it to work..
                                    Plugin seen not to work..
                                    Is there a way to fix it?
                                    @tig said:
                                    EDIT:
                                    1.1 20090625
                                    Speed improvements - face making time ~halved,
                                    typename >> kind_of?, triangulation glitch trapped
                                    and orientation improved.
                                    1.2 20090625
                                    Orientation speed optimised.
                                    Glitch on groups erase fixed.
                                    1.3 20090626
                                    Edges not facing in convoluted shapes trapped.
                                    1.4 20090707
                                    Triangulation improved. Rare intersect glitch fixed.
                                    This is extrudeEdgesByEdges.rb - it does what its name implies...
                                    [attachment=2:t7jruxbl]<!-- ia2 -->ExtrudeEdgesByEdgesExample.png<!-- ia2 -->[/attachment:t7jruxbl]
                                    [attachment=3:t7jruxbl]<!-- ia3 -->ExtrudeEdgesByEdgesEsamples.skp<!-- ia3 -->[/attachment:t7jruxbl]
                                    [attachment=1:t7jruxbl]<!-- ia1 -->extrudeEdgesByEdges.rb<!-- ia1 -->[/attachment:t7jruxbl]
                                      [attachment=0:1yi83ajh]<!-- ia0 -->Plugin error.JPG<!-- ia0 -->[/attachment:1yi83ajh]
                                      On the face of it, it looks like you aren't making a set of edges and grouping them as the 'profile', and also a set of edges and grouping them as the 'path'... Do this, then select the two groups and run the tool... The error message is telling you you haven't selected two groups...
                                      If you have other problems then please expand in your explanation...
                                        Here's v1.5 - It now Zooms to show the new group [at Pilou's request]
                                        • bazB Offline
                                          baz
                                          This is an astounding plugin, I've already found myself using it on lots of 'ordinary' tasks where usually I would have had to stuff around for ages with followme, copypaste, etc.
                                          Thank you very much Tig.
                                          Baz
                                            THX! Very reactive! 😎 👍
                                            Edit 😄
                                            Seems there is something wrong in the "Zoom" 😉
                                            That don't work 😮
                                            zoom out must be made before the first dialog box "Orient faces"
                                            Without that zoom don't work even at the end 😄
                                            (I have of course the 1.5)
                                            zoom.skp
                                            • 4 / 10
