    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 230.7k Views 76 Watching
      AcesHigh
      TIG, very nice plugin... can you improve it to add the option for another rail "edge", thus effectively transforming it into a SWEEP 2 RAILS plugin??
      http://www.kxcad.net/autodesk/Autodesk_VIZ_Help/graphics/il_nurbs_sweep2.jpg
      http://moi3d.com/1.0/docs/screenshots/Sweep9.jpg
      http://moi3d.com/1.0/docs/screenshots/Sweep10.jpg
      http://moi3d.com/1.0/docs/screenshots/Sweep11.jpg
      http://moi3d.com/1.0/docs/screenshots/Sweep12.jpg
      http://moi3d.com/1.0/docs/screenshots/Sweep13.jpg
        It's on the list...
          seems one of the Moi's example above is 3 rails 😉
          • MALAISEM Offline
            MALAISE
            Hi TIG
            May you'll better understand as me that message. I loaded the V1.3, but no results
            I reload the file.rb but get the same result.captured screen using ExtrudeEdge to edge
            Do you have the V1.2 somewhere ? ( It worked )
            MALAISE 👍
              Malaise I've PM'd you about getting the skp sent so I can test it...
              Are the selected just two groups of edges ?
              • JClementsJ Offline
                JClements
                Well TIG, this is a nice script and I hope sweep-two-rails can be done (keeping my fingers crossed 😄 ). It could be a big time saver for doing landscape/topographical, asymetrical surfaces.
                • O Offline
                  orei
                  i hope sooo!!! wonderful script!!!
                  • MALAISEM Offline
                    MALAISE
                    Hi All
                    I have encountered some strange behaviour of TIG' last Plugin. Have you notice that Experimental SketchyPhysic 3X may block ExtrudeEdges ?
                    Using SketchyPhysic 2 , no problem at all .... please let's share your comments
                    MALAISE 😄
                      Don't see where the clash could be [yet] ?
                        chango70
                        @tig said:
                        It's on the list...
                        Drool...
                        • kerabeK Offline
                          kerabe
                          Wow, what a great plugin! Just downloaded it and have been playing around with it and I have had no real problems at all. Had to do some minor clean-up work but nothing unusual. Love it. 😄
                          The CH124: If it isn't leaking, you're out of oil...
                            Version 1.4 is now out... http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
                            1.4 20090707 Triangulation improved [as my recent triangulate.rb]. Rare intersect glitch fixed.
                              Trivial problem 😄
                              if the groups are on the full screen result is out of the screen an no possibity to see it before to reply all the box dialog!
                              So will be cool that an automatic resize exist before process 😉
                              Sure I can zoom out but... 😉
                                mpowell1234567890
                                Help, I cannot get it to work..
                                Plugin seen not to work..
                                Is there a way to fix it?
                                @tig said:
                                EDIT:
                                1.1 20090625
                                Speed improvements - face making time ~halved,
                                typename >> kind_of?, triangulation glitch trapped
                                and orientation improved.
                                1.2 20090625
                                Orientation speed optimised.
                                Glitch on groups erase fixed.
                                1.3 20090626
                                Edges not facing in convoluted shapes trapped.
                                1.4 20090707
                                Triangulation improved. Rare intersect glitch fixed.
                                This is extrudeEdgesByEdges.rb - it does what its name implies...
                                [attachment=2:t7jruxbl]<!-- ia2 -->ExtrudeEdgesByEdgesExample.png<!-- ia2 -->[/attachment:t7jruxbl]
                                [attachment=3:t7jruxbl]<!-- ia3 -->ExtrudeEdgesByEdgesEsamples.skp<!-- ia3 -->[/attachment:t7jruxbl]
                                [attachment=1:t7jruxbl]<!-- ia1 -->extrudeEdgesByEdges.rb<!-- ia1 -->[/attachment:t7jruxbl]
                                  [attachment=0:1yi83ajh]<!-- ia0 -->Plugin error.JPG<!-- ia0 -->[/attachment:1yi83ajh]
                                  On the face of it, it looks like you aren't making a set of edges and grouping them as the 'profile', and also a set of edges and grouping them as the 'path'... Do this, then select the two groups and run the tool... The error message is telling you you haven't selected two groups...
                                  If you have other problems then please expand in your explanation...
                                    Here's v1.5 - It now Zooms to show the new group [at Pilou's request]
                                    • bazB Offline
                                      baz
                                      This is an astounding plugin, I've already found myself using it on lots of 'ordinary' tasks where usually I would have had to stuff around for ages with followme, copypaste, etc.
                                      Thank you very much Tig.
                                      Baz
                                        THX! Very reactive! 😎 👍
                                        Edit 😄
                                        Seems there is something wrong in the "Zoom" 😉
                                        That don't work 😮
                                        zoom out must be made before the first dialog box "Orient faces"
                                        Without that zoom don't work even at the end 😄
                                        (I have of course the 1.5)
                                        zoom.skp
                                          Here's v1.6 http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
                                          It fixes a glitch with large mesh group results not zooming properly so that you can see them all...
                                          The way it works is that it selects the group, 'zooms selected' and then removes group from selection - fine for modest sized meshes BUT if the group is too large SUp hasn't found the selection to 'zoom to' before the selection is cleared... so I've put the 'remove from selection' part after the first dialog so it has time !
                                            JClements
                                            TIG:
                                            Is the result you wanted when erasing coplanar edges?
                                            John
                                            P.S.
                                            JSClements is a temp login until I can get JClements restored.
                                            Is this the result you wanted when deleting coplanar edges.skp
                                            • 4 / 10
