    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 215.4k Views 76 Watching
      Here's an update...
      Version 1.2 20090625
      Orientation speed optimised.
      Glitch on groups erase fixed.
      Get it here... http://forums.sketchucation.com/viewtopic.php?p=166780#p166780 ...
      • I Offline
        ideas_arte
        Wow...!
        Many thank you very much ...!
        Excellent tool, thank you very much again and a hug from Central America ...! ๐Ÿ˜„
        • massimoM Offline
          massimo Moderator
          Hi TIG and many thanks. I've tried both "intersect with self" or not, but nothing changed. A little problem...
            Massimo
            Have you tried the latest version v1.2 ? I've just tried to reproduce your path/profile and I get all faces made - no gaps - Any edge that can get a face should get a face ? Your faces aren't reversed are they, so look 'gappped' ?
            The only problem I have was because of the convoluted result some faces orient wrongly [inside out] - both in the script AND within SUp later - the only fix is to reverse the problem faces manually ...
            I had to guess your model's details - I could test it better with the real thing - if after trying with the latest version it still gaps please PM me with the model attached, so I can see if I get the same problem...
              Can you subsequently get the face made if you redraw an edge ? If so then EEbyE should have made that face...
              I haven't managed to reproduce it, can one of you PM me a [small] model with the problem ?
                I have same result but seems normal as this function is not adapted to this!
                As the profil stay parallel ๐Ÿ˜’
                At each "rotation" there are creation of an external or internal horizontal face ๐Ÿ˜„
                For ovoid that make just an half circle ๐Ÿ˜‰
                And a mirror after ๐Ÿ˜‰
                But even with this there some gaps ๐Ÿ˜‰
                  file of the mirror above ๐Ÿ˜‰
                  gap.skp
                    I get no loose edges with either of your skp's... There is orientation weirdness as sometimes threes faces share as edge as it's convoluted in on itself when a circle... to be on the safe side I am adjusting the script to trap any edges without faces... Look out for update...
                      Here's v1.3 ...
                      It's been trapped for rare unfaced edges - it either forces the edge to have a face, or erases the edge if it's not possible to add a face ...
                        Have you tried this latest version ?
                          There is always no possible to close some faces (my gap file above) ๐Ÿ˜‰
                          The curious is this is a "big face" ๐Ÿ˜ฎ
                          Maybe because angle is too flat?
                          Not so a big deal to close it by hand ๐Ÿ˜‰
                            Did you still get unfaced edges ?
                              yes the same than on my image above! (orange pale one)
                              After Auto self convoluted stay 2 "big faces" (second of the revolution, and second of the profil)
                              AND I have this one " 1.3 20090626 Edges not facing in convoluted shapes trapped."
                                Of ourse yes ๐Ÿ˜‰
                                The curious was there same size so maybe you have not posted the good version?
                                  Koosie van Tutte
                                  thanks a lot!
                                    AcesHigh
                                    TIG, very nice plugin... can you improve it to add the option for another rail "edge", thus effectively transforming it into a SWEEP 2 RAILS plugin??
                                    http://www.kxcad.net/autodesk/Autodesk_VIZ_Help/graphics/il_nurbs_sweep2.jpg
                                    http://moi3d.com/1.0/docs/screenshots/Sweep9.jpg
                                    http://moi3d.com/1.0/docs/screenshots/Sweep10.jpg
                                    http://moi3d.com/1.0/docs/screenshots/Sweep11.jpg
                                    http://moi3d.com/1.0/docs/screenshots/Sweep12.jpg
                                    http://moi3d.com/1.0/docs/screenshots/Sweep13.jpg
                                      It's on the list...
                                        seems one of the Moi's example above is 3 rails ๐Ÿ˜‰
                                        • MALAISEM Offline
                                          MALAISE
                                          Hi TIG
                                          May you'll better understand as me that message. I loaded the V1.3, but no results
                                          I reload the file.rb but get the same result.captured screen using ExtrudeEdge to edge
                                          Do you have the V1.2 somewhere ? ( It worked )
                                          MALAISE ๐Ÿ‘
                                          La Connaissance n'a de valeur que partagรฉe
                                            Malaise I've PM'd you about getting the skp sent so I can test it...
                                            Are the selected just two groups of edges ?
                                            • 9 / 10
