    [Plugin] Sculpt Tools (help)
    207 Posts 48 Posters 121.7k Views 48 Watching
    • free agentF
      free agent
      will it have pressure sensitivity with a wacom pen and tablet???? 😎
      also would be cool if it made its own geometry??? as to not produce any unnecessary geometry, just a thought
      http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
      • K
        kwistenbiebel
        Sculpt tools! Finally !
        Good luck with dev on this plugin. It is definitely something a lot of us will appreciate.
        • CadFatherC
          CadFather
          wow, BTM.. serious shock.. 😲
          • B
            BTM
            @chris fullmer said:
            Looking great! A few custom "brushes" would be cool. So the user could define different ways to be bulging and sculpting.
            I've added a bit more customizability for the shape of the brush. it now has a strength, hard edge and soft edge. So, if the hard edge was 1m, and the soft was 0.5m, the overall size of the tool would be 1.5m, and the .5m on the outside would be smoothed. if the hard edge was 1m, and no soft edge, it would be have a 1m range, and a hard outer edge. If it had no hard edge, but a 1m soft edge, it would be completely smooth, like in the example video. Makes it a lot easier to sculpt smaller details.
            …I have no Idea how to include that. 😕 Where would you get the info on the pen's pressure from?
            @solo said:
            Zbrush meets sketchup?
            I've never used Zbrush, i'll check it out though, maybe it could give me some more ideas.
            isn't the pull a push with a negative value in streght? because if it is there's no point in keeping the two of them, and so keeping the plugin simpler.
            I might make them both into one tool, push, with Shift or something to make it pull. Same with Bulge and Carve, the only difference between the two is that one has uses a reversed vector of the other.
            It really isn't that complicated at all, especially compared to some of the other scripts out there. 😄
            • MALAISEM
              MALAISE
              Quite promising, BTM, the program you're writing 👍 👍
              It's a different approach of "sand box"
              MALAISE
              • P
                Physicsguy1
                It looks outstanding! I wish I could do that...
                • B
                  BTM
                  O.K., I looked at some features in Zbrush, and kinda copied one 😒
                  The ability to have a kind of gravity effect.
                  • CadFatherC
                    CadFather
                    don't stop!!! 😆
                    • soloS
                      AHA!!!!
                      Gravity is what I need to make cloth effects....you are cooking now!
                      • B
                        BTM
                        @solo said:
                        AHA!!!!
                        … I just like making goop 💚
                        • soloS
                          With a bit of playing, your code will be able to produce this faster than I did using SDS.
                          http://img19.imageshack.us/img19/982/1solocurtain4.png
                          • K
                            kwistenbiebel
                            Wow.. a drape tool as well?
                            This is getting better and better.
                              dacad
                              you teaser...😉
                              I'm really really dying to test your plugin .BTM...
                              Great Work 👍
                              David
                                And soon the Voxels technology of 3d-Coat? 😉
                                • erikBE
                                  erikB
                                  wow !!!
                                  really amazing. Keep it up 😄
                                  erikB
                                  • EarthMoverE
                                    EarthMover
                                    BTM,
                                    One of the things I like about Modo's sculpting tools is that when you have a tool selected, let's say the push tool, when you hold shift and use the tool it then becomes a smooth tool.......when you hold CTRL and use it, it becomes the tool opposite of it, in the case of the push tool, the opposite is the carve tool. It allows for quick sculpting without constantly selecting different tools to make minor adjustments to the mesh. Thought that would be a good idea for you plugin.
                                    Content Creator at Skapeup
                                    • urgenU
                                      urgen
                                      --pupil forever...------
                                      • B
                                        BTM
                                        @earthmover said:
                                        BTM,
                                        Yeah, I've been thinking about having Shift or another key make the tool into the opposite. As for a smooth too, I've been thinking about how to make one, but it seems pretty hard to come up with something that might work.
                                        Also, I'm planning on having the settings, which are used by all the tools, be in a webdialog; then you could change the settings while using any of the tools ( Think of the sketchyphysics UI). My problem is that I have no clue how to make a webdialog. 😒
                                        … Right now, I'm thinking of ways to make the tools run faster when dealing with lots of geometry. They still work fairly well, but definitely not as smooth as in the video, if the polycount is really high. For instance, this model has just over 9000 faces, and the tools worked fairly well on it, but as the framerate drops, the rate of onMouseMove does too.
                                        • B
                                          BTM
                                          Okay, I've sorta got the Shift-to-reverse-tool working. It makes sculpting a lot easier; either that, or I've just gotten a lot better 🤣
                                          Another face, over 9000 polys. I think about a half hour to an hour's worth of work.
                                          … This might turn out to be a pretty good free plugin! 💚
                                          • K
                                            kwistenbiebel
                                            Looks promising....I think we are going to need a UV-unwrapper for texturing stuff like that.
                                            The down side to all this, as BTM states himself, will be the inability of Sketchup to handle a medium high poly count .
                                            • 11
                                            • 1 / 11
