    [Plugin] Sculpt Tools (help)
    207 Posts 48 Posters 112.3k Views 48 Watching
    • mitcorbM
      mitcorb
      Oh boy Oh boy I can see this becoming an excellent tool for fine tuning warped meshes--aside from the straightforward uses you demo in the videos.
      Obviously, you recognize that the mesh has to be well subdivided. Does the brush only work on a smoothed entity?
      Keep up the good work, BTM.
        3eighty
        GREAT TOOL...Now if you can get it to turn metals into GOLD! 😍
        • PixeroP
          Pixero
          One question, isn't the pull a push with a negative value in streght? because if it is there's no point in keeping the two of them, and so keeping the plugin simpler.
          Maybe use the Alt key for push.
            dacad
            WOW!!!! Sculpt Tools?!?! Simple Amazing!!
            If you're looking to more tools to add see about pinch, flatten, and inflate, a little like the blender sculpt tools that aren't has complex has zbrush (i can give you more info on this tools and how they work if you want).
            And i sure hope everyone will help you with this plugin (i'm no coder but i can help in info and design about the tools), because this is seriously useful and needed for sketchup (even for srchviz, imagine detailing a terrain with this...)
            This is really great stuff .BTM. Looking forward to use your plugin.
            Congratulations
            David
            • free agentF
              free agent
              will it have pressure sensitivity with a wacom pen and tablet???? 😎
              also would be cool if it made its own geometry??? as to not produce any unnecessary geometry, just a thought
              http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
              • K
                kwistenbiebel
                Sculpt tools! Finally !
                Good luck with dev on this plugin. It is definitely something a lot of us will appreciate.
                • CadFatherC
                  CadFather
                  wow, BTM.. serious shock.. 😲
                  • B
                    BTM
                    @chris fullmer said:
                    Looking great! A few custom "brushes" would be cool. So the user could define different ways to be bulging and sculpting.
                    I've added a bit more customizability for the shape of the brush. it now has a strength, hard edge and soft edge. So, if the hard edge was 1m, and the soft was 0.5m, the overall size of the tool would be 1.5m, and the .5m on the outside would be smoothed. if the hard edge was 1m, and no soft edge, it would be have a 1m range, and a hard outer edge. If it had no hard edge, but a 1m soft edge, it would be completely smooth, like in the example video. Makes it a lot easier to sculpt smaller details.
                    …I have no Idea how to include that. 😕 Where would you get the info on the pen's pressure from?
                    @solo said:
                    Zbrush meets sketchup?
                    I've never used Zbrush, i'll check it out though, maybe it could give me some more ideas.
                    I might make them both into one tool, push, with Shift or something to make it pull. Same with Bulge and Carve, the only difference between the two is that one has uses a reversed vector of the other.
                    It really isn't that complicated at all, especially compared to some of the other scripts out there. 😄
                    • MALAISEM
                      MALAISE
                      Quite promising, BTM, the program you're writing 👍 👍
                      It's a different approach of "sand box"
                      MALAISE
                      • P
                        Physicsguy1
                        It looks outstanding! I wish I could do that...
                        • B
                          BTM
                          O.K., I looked at some features in Zbrush, and kinda copied one 😒
                          The ability to have a kind of gravity effect.
                          • CadFatherC
                            CadFather
                            don't stop!!! 😆
                            • soloS
                              AHA!!!!
                              Gravity is what I need to make cloth effects....you are cooking now!
                              • B
                                BTM
                                @solo said:
                                AHA!!!!
                                … I just like making goop 💚
                                • soloS
                                  With a bit of playing, your code will be able to produce this faster than I did using SDS.
                                  http://img19.imageshack.us/img19/982/1solocurtain4.png
                                  • K
                                    kwistenbiebel
                                    Wow.. a drape tool as well?
                                    This is getting better and better.
                                      dacad
                                      you teaser...😉
                                      I'm really really dying to test your plugin .BTM...
                                      Great Work 👍
                                      David
                                        And soon the Voxels technology of 3d-Coat? 😉
                                        • erikBE
                                          erikB
                                          wow !!!
                                          really amazing. Keep it up 😄
                                          erikB
                                          • EarthMoverE
                                            EarthMover
                                            BTM,
                                            One of the things I like about Modo's sculpting tools is that when you have a tool selected, let's say the push tool, when you hold shift and use the tool it then becomes a smooth tool.......when you hold CTRL and use it, it becomes the tool opposite of it, in the case of the push tool, the opposite is the carve tool. It allows for quick sculpting without constantly selecting different tools to make minor adjustments to the mesh. Thought that would be a good idea for you plugin.
                                            Content Creator at Skapeup
                                            • 11
                                            • 1 / 11
