    Render this: Stained glass
    66 Posts 27 Posters 29.8k Views 27 Watching
      @dale said:
      Thanks Gaieus I tend to agree. At first I liked the moodiness, but I think the glass need more attention...
      I might suspect that in fact there's nothing outside that would "liven up" that glass. Did you solely use the sun for lighting and no other geometry to reflect outside? If so,maybe an intensive hdri background could do the job.
      @d12dozr said:
      This is with IRender nXt. I really like the edge highlighting setting. It needs a lot more tuning...any tweaking suggestions?
      Well, to me it still looks much better than anything I could do. 👍
      • arail1A Offline
        arail1
        I especially like the 'watery' quality of the light coming through Eulgrand's window. It makes me think there are trees outside, moving in the wind and the reflections on the wall are in motion. Very convincing to my eye.
        • david57D Offline
          david57
          BubbaLove has the best one. Its Excellent.
          • EscapeArtistE Offline
            EscapeArtist
            Wow, there are some excellent renders here. I better get to work!
              MrWip
              Your render is charming d12dozr, IRender give good result on this kind of effect (by the way, maybe you should just add some more segment on the round opening...)
              Here is my sketchup files, if people want to give it a try!
              Stained_Glass_Challenge.zip
              http://www.wip-archi.com
              • daleD Offline
                dale
                Well I figured Macintosh would probably have made the woodwork white, so I changed this and used an HDRI sky, and a little exposure and Gamma tweak. Still Kerlythea
                • E Offline
                  Eulgrand
                  Thanks Arail1. That's right, there's a global with trees outside. Thte "watery" effect is due to the procedural Perlin noise in the bump channel.
                  I attach my KT material. Hope this helps.
                  Vitrail.mat.zip
                  • soloS Offline
                    http://img36.imageshack.us/img36/4527/stainglasschallenge100.jpg
                      dylan
                      There is some great looking stained glass here.
                      Is it possible to get this coloured light coming through using Podium?
                      http://dmdarchitecture.co.uk/
                        trillium
                        hi MrWip, thank you for sharing your fabolous model! how did you generate all the individual pieces of glass from the original image? did you trace each piece in Sketchup? or is there an easier way to do that? thanks again!!!
                          MrWip
                          Richcat, the first image is a bit too burnt for me, but the church is a great peace of work ! (but is it originally a sketchup model... I guess most of the things are just maps, but it looks great )
                          Solo, the quality of the glass is really good with a nice bump and interreflexion. To me the picture is missing some contrast, and the caustics looks maybe a bit 'watery'
                          Trillium, all the glass have been redraw by hand, with the freehand tool (about 30 minutes). I've try the good old photoshop technic : selection --> path --> export to Ai --> DWG ... but the shape was too unprecise, and made of too much edges...
                          • Al HartA Offline
                            Al Hart
                            Thanks for the model WIP. I've been playing with it for a day or so. There are lots of things to play with - like the amount of transparency, translucency, refraction, and daylight processing for the glass. And the lighting outside. Rather than direct sun, I chose a sunset sky HDRi for the sky. It gives an interesting, different effect.
                            Al Hart
                            IRender nXt from Render Plus
                              EscapeArtist
                              OK, here's my "entry. I'm having no end of trouble with the textures, so this is still a WIP. Maybe I'll get around to finishing it, but I have a real window I need to work on.
                              All SU and Kerky.
                              Edit: I said I was done messing with this but I guess I lied. I couldn't stand leaving it half-finished, so I kept working on it. First shot is the whole thing, the second part is a closeup of the glass - the far view doesn't show the bump mapping. It's all geometry: Window 9' high, 1/4" thick glass, lead cameing is 3/8" and up in thickness. An absurd 800K polys thanks to the lead came. Windowfinal.jpgwindofinalc.jpg
                              • arail1A Offline
                                arail1
                                This should be in the 'Renders I've Failed At' or whatever that thread was called but I can't seem to find it.
                                I'd like some advice on how to get some highlights into the glass itself. I like the brick wall. I like the floor. I like the reflections. But the glass itself is quite dead.
                                Rendered in modo.
                                Also, I'm wondering if Solo would have any interest in offering a 'Master Tutorial' about his last post in this thread? I keep looking at that image and I can't imagine how it was achieved.
                                Any help is appreciated.
                                • soloS Offline
                                  Arail
                                  My last post was done using Vue 7inf. Basically I used a customised atmosphere with no sun, I added one volumetric spotlight with soft shadows, selected accurate caustics in render options, and blended the glass photo texture with a cathedral glass.
                                  • arail1A Offline
                                    arail1
                                    That was Greek you were speaking right? Ancient Greek if I'm not mistaken?
                                    Seriously though, I'm familiar with the terms volumetric spotlight and caustics, although I haven't yet experimented with them - I've been working in modo for about 3 weeks. But what is 'cathedral glass'?
                                      richcat
                                      Thanks Mr WiP for the model
                                      Done with IRendernXt, saved out as HDRI tone mapped and sharpened.
                                      http://nxt.accurender.com/forums/storage/146/10257/stg3.jpg
                                      I also had ago with a model of the Church by Paul Russam - from a while ago. Still needs some work to bring out the chandelier.(feedback from IRender forum)
                                      http://api.ning.com/files/DknHnvZ1HRF*xDUHdP-S9pWZliwI9-jM1A8IOLu9HB63XKNkZWnHijUyp4ZATUyL*1OXPFs5axAd9SjWRyhFUshT8ish77rs/church6a.jpg?width=737&height=382
                                      • Al HartA Offline
                                        Al Hart
                                        I'm making a new post to this thread because I wanted to try out this model with a Volumetric Fog effect:
                                        http://wiki.renderplus.com/images/8/81/Stained_Glass_Challenge2.jpg
                                        Al Hart
                                        • jason_marantoJ Offline
                                          jason_maranto
                                          Here's one from Maxwell Render -- I used a bit of the Maxwell Simulens effect, but no post:
                                          and here's a bit of post:
                                          Best,
                                          Jason.
                                            jason_maranto
                                            Here's a more traditional window type to show off caustics -- Maxwell Render of course, with a little bit of Maxwell Simulens and post.
                                            I'll let it render longer overnight and post an updated version.
                                            Best,
                                            Jason.
                                            • 3 / 4
