    Render this: Stained glass
    66 Posts 27 Posters 28.2k Views 27 Watching
    • E Offline
      Eulgrand
      @arail1 said:
      I especially like the 'watery' quality of the light coming through Eulgrand's window. It makes me think there are trees outside, moving in the wind and the reflections on the wall are in motion. Very convincing to my eye.
      Thanks Arail1. That's right, there's a global with trees outside. Thte "watery" effect is due to the procedural Perlin noise in the bump channel.
      I attach my KT material. Hope this helps.
      Vitrail.mat.zip
      • soloS Offline
        http://img36.imageshack.us/img36/4527/stainglasschallenge100.jpg
          dylan
          There is some great looking stained glass here.
          Is it possible to get this coloured light coming through using Podium?
          http://dmdarchitecture.co.uk/
            trillium
            hi MrWip, thank you for sharing your fabolous model! how did you generate all the individual pieces of glass from the original image? did you trace each piece in Sketchup? or is there an easier way to do that? thanks again!!!
              MrWip
              Richcat, the first image is a bit too burnt for me, but the church is a great peace of work ! (but is it originally a sketchup model... I guess most of the things are just maps, but it looks great )
              Solo, the quality of the glass is really good with a nice bump and interreflexion. To me the picture is missing some contrast, and the caustics looks maybe a bit 'watery'
              Trillium, all the glass have been redraw by hand, with the freehand tool (about 30 minutes). I've try the good old photoshop technic : selection --> path --> export to Ai --> DWG ... but the shape was too unprecise, and made of too much edges...
              http://www.wip-archi.com
              • Al HartA Offline
                Al Hart
                Thanks for the model WIP. I've been playing with it for a day or so. There are lots of things to play with - like the amount of transparency, translucency, refraction, and daylight processing for the glass. And the lighting outside. Rather than direct sun, I chose a sunset sky HDRi for the sky. It gives an interesting, different effect.
                Al Hart
                IRender nXt from Render Plus
                • EscapeArtistE Offline
                  EscapeArtist
                  OK, here's my "entry. I'm having no end of trouble with the textures, so this is still a WIP. Maybe I'll get around to finishing it, but I have a real window I need to work on.
                  All SU and Kerky.
                  Edit: I said I was done messing with this but I guess I lied. I couldn't stand leaving it half-finished, so I kept working on it. First shot is the whole thing, the second part is a closeup of the glass - the far view doesn't show the bump mapping. It's all geometry: Window 9' high, 1/4" thick glass, lead cameing is 3/8" and up in thickness. An absurd 800K polys thanks to the lead came. Windowfinal.jpgwindofinalc.jpg
                  • arail1A Offline
                    arail1
                    This should be in the 'Renders I've Failed At' or whatever that thread was called but I can't seem to find it.
                    I'd like some advice on how to get some highlights into the glass itself. I like the brick wall. I like the floor. I like the reflections. But the glass itself is quite dead.
                    Rendered in modo.
                    Also, I'm wondering if Solo would have any interest in offering a 'Master Tutorial' about his last post in this thread? I keep looking at that image and I can't imagine how it was achieved.
                    Any help is appreciated.
                    • soloS Offline
                      Arail
                      My last post was done using Vue 7inf. Basically I used a customised atmosphere with no sun, I added one volumetric spotlight with soft shadows, selected accurate caustics in render options, and blended the glass photo texture with a cathedral glass.
                      • arail1A Offline
                        arail1
                        That was Greek you were speaking right? Ancient Greek if I'm not mistaken?
                        Seriously though, I'm familiar with the terms volumetric spotlight and caustics, although I haven't yet experimented with them - I've been working in modo for about 3 weeks. But what is 'cathedral glass'?
                          richcat
                          Thanks Mr WiP for the model
                          Done with IRendernXt, saved out as HDRI tone mapped and sharpened.
                          http://nxt.accurender.com/forums/storage/146/10257/stg3.jpg
                          I also had ago with a model of the Church by Paul Russam - from a while ago. Still needs some work to bring out the chandelier.(feedback from IRender forum)
                          http://api.ning.com/files/DknHnvZ1HRF*xDUHdP-S9pWZliwI9-jM1A8IOLu9HB63XKNkZWnHijUyp4ZATUyL*1OXPFs5axAd9SjWRyhFUshT8ish77rs/church6a.jpg?width=737&height=382
                          • Al HartA Offline
                            Al Hart
                            I'm making a new post to this thread because I wanted to try out this model with a Volumetric Fog effect:
                            http://wiki.renderplus.com/images/8/81/Stained_Glass_Challenge2.jpg
                            Al Hart
                            • jason_marantoJ Offline
                              jason_maranto
                              Here's one from Maxwell Render -- I used a bit of the Maxwell Simulens effect, but no post:
                              and here's a bit of post:
                              Best,
                              Jason.
                                jason_maranto
                                Here's a more traditional window type to show off caustics -- Maxwell Render of course, with a little bit of Maxwell Simulens and post.
                                I'll let it render longer overnight and post an updated version.
                                Best,
                                Jason.
                                  jason_maranto
                                  I added a bit of sss to the colors in MrWip's file that were labeled "translucent" and let it render all night -- this has a tiny bit of Maxwell Simulens but no post work:Maxwell Render - 15 hours
                                  Best,
                                  Jason.
                                  • soloS Offline
                                    I thought I'd give it a play with this morning. I used a standard photo for a window, used the image as a transmittive layer on thick glass material.
                                    • FrederikF Offline
                                      Frederik
                                      Looks great, Solo... Crisp and very clean... 👍
                                      What render app did you use and how long time did it take to render...?
                                      Cheers
                                      Kim Frederik
                                      • soloS Offline
                                        Thanks.
                                        Thea render as usual (love that app), I ran it with TR1 for around 2 hours.
                                        • zdesaynZ Offline
                                          zdesayn
                                          very nice disperse...good job.
                                          http://zdesignviz.blogspot.com/
                                          • andybotA Offline
                                            andybot
                                            Thanks to Solo for pointing out this thread from the vray forum. Pretty cool stuff! The vray output left me a little unsatisfied, so I played around with the material and found that it needs the map to be put into a refraction slot. Here is the result. I could play around bumps and caustic, but thought this is a good start.
                                            Andy
                                            • 3 / 4
