    Render this: Stained glass
    66 Posts 27 Posters 27.5k Views 27 Watching
    • E Offline
      Eulgrand
      Rendered in Kerkythea
      Preset 20 - MLT (BPT), 30 passes.
      Noise removed with NeatImage
      Lit by the sun and an HDR global.
      Just added some procedural Perlin noise as bump map, on an image grabbed on the net. The glass has 5mm thickness, IoR 1.52
        MrWip
        Well done Eulgrand, the scene is missing some materials to me, but the glass is just what it should be. The bump effect create a perfect bad quality glass effect, and the caustics works well.
        I've also give it a try on my scene with Kerky, but with a biased solution and the result was not convincing, so good that you gave your settings, It helps !
        http://www.wip-archi.com
        • honoluludesktopH Offline
          honoluludesktop
          MrWip, (I like that) Any chance of posting your skp so that we can play with it? The design reminds me of a deconstructed(?) FLW design:-)
            MrWip
            Guys, good idea to share it, I will post it... but I just realize that I forgot the file on my office computer so we have to wait till monday 😳 ....
            I will prepare it with different layers, presenting different variation (thickness, type of image, etc...), so we can all refer to the related scenes when we post a render and explain a technic.
            • daleD Offline
              dale
              A first Attempt building on an earlier stained glass piece. Modeled the door windows after Charles Rennie Macintosh's original windows for the Glasgow School of Art. Tried to give it a moonlit ambience for a change. Rendered in Kerkythea, preset 12. Hope I have time to play with it some more.
                Looks promising, Dale. The coloured light spots and even caustics look cool though I have to say that I find the glass (window) itself a bit "dull".
                Also, some (very faint) volumetric light would really enhance this image - I know Kerky can do it.
                All in all, I like it a lot (and all the other contributions - it's very useful, too IMO).
                • daleD Offline
                  dale
                  Thanks Gaieus I tend to agree. At first I liked the moodiness, but I think the glass need more attention. I hope to get some time to fool around with it some more. I'm still really new to this, and each challenge teaches me a lot, both with what others do,and the settings they discuss.
                    d12dozr
                    My first attempt...I'm a rendering noob, and I tried IDX Renditioner Express and Podium, but couldn't get the light cast from the window to be colored. This is with IRender nXt. I really like the edge highlighting setting. It needs a lot more tuning...any tweaking suggestions?
                    Sketchup + IRender nXt, no post-processing
                    http://goo.gl/f7ooYh
                      @dale said:
                      Thanks Gaieus I tend to agree. At first I liked the moodiness, but I think the glass need more attention...
                      I might suspect that in fact there's nothing outside that would "liven up" that glass. Did you solely use the sun for lighting and no other geometry to reflect outside? If so,maybe an intensive hdri background could do the job.
                      Well, to me it still looks much better than anything I could do. 👍
                      • arail1A Offline
                        arail1
                        I especially like the 'watery' quality of the light coming through Eulgrand's window. It makes me think there are trees outside, moving in the wind and the reflections on the wall are in motion. Very convincing to my eye.
                        • david57D Offline
                          david57
                          BubbaLove has the best one. Its Excellent.
                          • EscapeArtistE Offline
                            EscapeArtist
                            Wow, there are some excellent renders here. I better get to work!
                              MrWip
                              Your render is charming d12dozr, IRender give good result on this kind of effect (by the way, maybe you should just add some more segment on the round opening...)
                              Here is my sketchup files, if people want to give it a try!
                              Stained_Glass_Challenge.zip
                              • daleD Offline
                                dale
                                Well I figured Macintosh would probably have made the woodwork white, so I changed this and used an HDRI sky, and a little exposure and Gamma tweak. Still Kerlythea
                                • E Offline
                                  Eulgrand
                                  Thanks Arail1. That's right, there's a global with trees outside. Thte "watery" effect is due to the procedural Perlin noise in the bump channel.
                                  I attach my KT material. Hope this helps.
                                  Vitrail.mat.zip
                                  • soloS Offline
                                    http://img36.imageshack.us/img36/4527/stainglasschallenge100.jpg
                                      dylan
                                      There is some great looking stained glass here.
                                      Is it possible to get this coloured light coming through using Podium?
                                      http://dmdarchitecture.co.uk/
                                        trillium
                                        hi MrWip, thank you for sharing your fabolous model! how did you generate all the individual pieces of glass from the original image? did you trace each piece in Sketchup? or is there an easier way to do that? thanks again!!!
                                          MrWip
                                          Richcat, the first image is a bit too burnt for me, but the church is a great peace of work ! (but is it originally a sketchup model... I guess most of the things are just maps, but it looks great )
                                          Solo, the quality of the glass is really good with a nice bump and interreflexion. To me the picture is missing some contrast, and the caustics looks maybe a bit 'watery'
                                          Trillium, all the glass have been redraw by hand, with the freehand tool (about 30 minutes). I've try the good old photoshop technic : selection --> path --> export to Ai --> DWG ... but the shape was too unprecise, and made of too much edges...
                                          • Al HartA Offline
                                            Al Hart
                                            Thanks for the model WIP. I've been playing with it for a day or so. There are lots of things to play with - like the amount of transparency, translucency, refraction, and daylight processing for the glass. And the lighting outside. Rather than direct sun, I chose a sunset sky HDRi for the sky. It gives an interesting, different effect.
                                            Al Hart
                                            IRender nXt from Render Plus
                                            • 2 / 4
