    Render this: Stained glass
    66 Posts 27 Posters 28.2k Views 27 Watching
    • daleD Offline
      dale
      Well I figured Macintosh would probably have made the woodwork white, so I changed this and used an HDRI sky, and a little exposure and Gamma tweak. Still Kerlythea
      • E Offline
        Eulgrand
        @arail1 said:
        I especially like the 'watery' quality of the light coming through Eulgrand's window. It makes me think there are trees outside, moving in the wind and the reflections on the wall are in motion. Very convincing to my eye.
        Thanks Arail1. That's right, there's a global with trees outside. Thte "watery" effect is due to the procedural Perlin noise in the bump channel.
        I attach my KT material. Hope this helps.
        Vitrail.mat.zip
        • soloS Offline
          http://img36.imageshack.us/img36/4527/stainglasschallenge100.jpg
            dylan
            There is some great looking stained glass here.
            Is it possible to get this coloured light coming through using Podium?
            http://dmdarchitecture.co.uk/
              trillium
              hi MrWip, thank you for sharing your fabolous model! how did you generate all the individual pieces of glass from the original image? did you trace each piece in Sketchup? or is there an easier way to do that? thanks again!!!
                MrWip
                Richcat, the first image is a bit too burnt for me, but the church is a great peace of work ! (but is it originally a sketchup model... I guess most of the things are just maps, but it looks great )
                Solo, the quality of the glass is really good with a nice bump and interreflexion. To me the picture is missing some contrast, and the caustics looks maybe a bit 'watery'
                Trillium, all the glass have been redraw by hand, with the freehand tool (about 30 minutes). I've try the good old photoshop technic : selection --> path --> export to Ai --> DWG ... but the shape was too unprecise, and made of too much edges...
                http://www.wip-archi.com
                • Al HartA Offline
                  Al Hart
                  Thanks for the model WIP. I've been playing with it for a day or so. There are lots of things to play with - like the amount of transparency, translucency, refraction, and daylight processing for the glass. And the lighting outside. Rather than direct sun, I chose a sunset sky HDRi for the sky. It gives an interesting, different effect.
                  Al Hart
                  IRender nXt from Render Plus
                  • EscapeArtistE Offline
                    EscapeArtist
                    OK, here's my "entry. I'm having no end of trouble with the textures, so this is still a WIP. Maybe I'll get around to finishing it, but I have a real window I need to work on.
                    All SU and Kerky.
                    Edit: I said I was done messing with this but I guess I lied. I couldn't stand leaving it half-finished, so I kept working on it. First shot is the whole thing, the second part is a closeup of the glass - the far view doesn't show the bump mapping. It's all geometry: Window 9' high, 1/4" thick glass, lead cameing is 3/8" and up in thickness. An absurd 800K polys thanks to the lead came. Windowfinal.jpgwindofinalc.jpg
                    • arail1A Offline
                      arail1
                      This should be in the 'Renders I've Failed At' or whatever that thread was called but I can't seem to find it.
                      I'd like some advice on how to get some highlights into the glass itself. I like the brick wall. I like the floor. I like the reflections. But the glass itself is quite dead.
                      Rendered in modo.
                      Also, I'm wondering if Solo would have any interest in offering a 'Master Tutorial' about his last post in this thread? I keep looking at that image and I can't imagine how it was achieved.
                      Any help is appreciated.
                      • soloS Offline
                        Arail
                        My last post was done using Vue 7inf. Basically I used a customised atmosphere with no sun, I added one volumetric spotlight with soft shadows, selected accurate caustics in render options, and blended the glass photo texture with a cathedral glass.
                        • arail1A Offline
                          arail1
                          That was Greek you were speaking right? Ancient Greek if I'm not mistaken?
                          Seriously though, I'm familiar with the terms volumetric spotlight and caustics, although I haven't yet experimented with them - I've been working in modo for about 3 weeks. But what is 'cathedral glass'?
                            richcat
                            Thanks Mr WiP for the model
                            Done with IRendernXt, saved out as HDRI tone mapped and sharpened.
                            http://nxt.accurender.com/forums/storage/146/10257/stg3.jpg
                            I also had ago with a model of the Church by Paul Russam - from a while ago. Still needs some work to bring out the chandelier.(feedback from IRender forum)
                            http://api.ning.com/files/DknHnvZ1HRF*xDUHdP-S9pWZliwI9-jM1A8IOLu9HB63XKNkZWnHijUyp4ZATUyL*1OXPFs5axAd9SjWRyhFUshT8ish77rs/church6a.jpg?width=737&height=382
                            • Al HartA Offline
                              Al Hart
                              I'm making a new post to this thread because I wanted to try out this model with a Volumetric Fog effect:
                              http://wiki.renderplus.com/images/8/81/Stained_Glass_Challenge2.jpg
                              Al Hart
                              • jason_marantoJ Offline
                                jason_maranto
                                Here's one from Maxwell Render -- I used a bit of the Maxwell Simulens effect, but no post:
                                and here's a bit of post:
                                Best,
                                Jason.
                                  jason_maranto
                                  Here's a more traditional window type to show off caustics -- Maxwell Render of course, with a little bit of Maxwell Simulens and post.
                                  I'll let it render longer overnight and post an updated version.
                                  Best,
                                  Jason.
                                    jason_maranto
                                    I added a bit of sss to the colors in MrWip's file that were labeled "translucent" and let it render all night -- this has a tiny bit of Maxwell Simulens but no post work:Maxwell Render - 15 hours
                                    Best,
                                    Jason.
                                    • soloS Offline
                                      I thought I'd give it a play with this morning. I used a standard photo for a window, used the image as a transmittive layer on thick glass material.
                                      • FrederikF Offline
                                        Frederik
                                        Looks great, Solo... Crisp and very clean... 👍
                                        What render app did you use and how long time did it take to render...?
                                        Cheers
                                        Kim Frederik
                                        • soloS Offline
                                          Thanks.
                                          Thea render as usual (love that app), I ran it with TR1 for around 2 hours.
                                          • zdesaynZ Offline
                                            zdesayn
                                            very nice disperse...good job.
                                            http://zdesignviz.blogspot.com/
                                            • 3 / 4
