    (TRICK) To re-enable skp file preview
    147 Posts 60 Posters 210.3k Views 60 Watching
    • K
      kevsterman
      Do I have to have all my components in the original SU folder, ie, in the programme files? At the moment all my components are in a folder in My Documents for ease of access.
      "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
        sepo
        No..you don't have to. However I am finding on my Vista comp it is reporting error when calling regsvr32 thumbsup.dll. As consequence I have preview of .skb instead of .skp. Quite bizzare.
        • I
          ideas_arte
          @marklas said:
          Hi guys, do you know how you enable this on a Mac?
          Thanks,
          Mark.
          it's not so simple but it's doable... one way is to select custom icon in the 'save as' dialog..
          http://homepage.mac.com/jeffhammond/.Public/scf/customicon.jpg
          ο£Ώ THANK YOU VERY MUCH...! πŸ‘ ο£Ώ
          • K
            kevsterman
            Grr.. I'm still no nearer to solving this problem. Anyone have any other ideas?
            • E
              eullicious
              @pibuz said:
              Hi guys!
              It may sound repetitive, but I've searched a lot in the forum and I hardly found it at last! So I decided to put it here for a more rapid serach (moderators are free to remove this topic if useless).
              This micro-tutorial to explain how to enable the thumbnail preview if it doesn't show up automatically.
              It typically happens when you have two sketchup version installed and you uninstall one of them: once uninstalled, your skp files' thumbnails are gone, and you can only see the standard sketchup.exe icon.
              A solution is obviously to re-install sketchup (repairing the existing installed version), but most of the times it is more practical to re-enable the thumbnails this way:
              Start -> run...
              type "cmd" and then press "return"
              navigate into your sketchup root directory by typing for example:
              "cd C:\program files\google\sketchup 6" and press "return"
              now you're in your sketchup6 root folder. Type:
              "regsvr32 thumbsup.dll" and press "return".
              Done πŸ˜„
              Hope this can help someone
              sorry.may i know where to press 'return' on the keyboard?which key? πŸ‘Š
                http://upload.wikimedia.org/wikipedia/commons/a/a5/Enter.png
                • E
                  eullicious
                  ok done!thx thomthom
                  • GaieusG
                    Yup, "Return" is an "old fashioned" name of the Enter button (does Mac still u7se it BTW?). It comes from mechanic typewriters when that button "returned" the typewriter to the beginning of the next line.
                    (Ehm... I still used these mechanic typewriters at university. In fact, AFAIK I was the first to write my thesis on a computer in WrdPerfect at the whole faculty) πŸ˜’
                    • troyhomeT
                      troyhome
                      [there's an app called GraphicConverter which used to ship with os x... it stopped shipping with macs around the same time they added .skp support to the app πŸ˜„..
                      [/quote]
                      This is EXACTLY what i've been wanting in a .skp viewer/organizer for mac!!! i can move, delete, etc. Brilliant!!! thanks sooo sooo much for showing us this!!!!!
                      😍 πŸ‘ 🀣 πŸ’š πŸ˜„
                      IOviz.com
                      SU Pro 2024 PC
                      • K
                        kwistenbiebel
                        For Vista 64 bit users (the TRICK is only for XP) Xnview works as well.
                        Being able to see the icons in the native explorer would have been better though...
                        • K
                          kevsterman
                          Thanks for that hint Kwist. I've downloaded Xnview and it does the trick, tho as you say, being able to do it in the native explorer would definitly have been better.
                            j40
                            Hey Biebel,
                            I just installed XP Pro 64bit, and the thumbnails don't work from the beginning. I've tried the command you mentioned, but this is what i got.
                            Command on XP x64
                            Top3D Studio
                              j40
                              Is there XP-64 bit users that can see SU's thumbnails? πŸ˜•
                              I can't make it work. The only way to view the skp files that possible for me is the SU browser window in thumbnail view 😞
                              Top3D Studio
                                Don't think there is. The SU preview is a shell extension and 64bit OS need 64bit shell extensions.
                                Though, maybe you can see them in the file dialog of 32bit applications..?
                                  j40
                                  Yes, as I wrote: "The only way to view the skp files that possible for me is with SU browser window in thumbnail view"
                                  via the "open file" Su browser.
                                  Top3D Studio
                                    As I thought, the shell extension only works within 32bit applications that uses the 32-bit shell.
                                    What I think you can do, in WinXP and Vista (not possible in Win7) is run this command:
                                    C:\Windows\SysWOW64\explorer.exe /separate
                                    That should start an 32bit instance of explorer.exe.
                                    Mind you, you might find other issue with that.
                                      j40
                                      Other issues? Can you specify? ❓
                                      I prefer to know before i do it. πŸ€“
                                      Top3D Studio
                                        If you have 64bit extensions for other apps - you might not see them in the 32bit version unless that was also installed.
                                          j40
                                          Thanks Thom,
                                          I entered this command and it poped up a explorer window in which wherever i browsed i could see the thumbnails previews (SU and PDF, yes the the pdfs are also unseen in the thumbnail view).
                                          But if i brows from different/any explorer window the problem remains the same... 😞
                                          Top3D Studio
                                            yes, you have to launch explorer.exe with that command. Make a shortcut on your desktop to it for easy access.
                                            • 2 / 8
