    (TRICK) To re-enable skp file preview
    147 Posts 60 Posters 204.4k Views 60 Watching
      j40
      Is there XP-64 bit users that can see SU's thumbnails? πŸ˜•
      I can't make it work. The only way to view the skp files that possible for me is the SU browser window in thumbnail view 😞
      Top3D Studio
        Don't think there is. The SU preview is a shell extension and 64bit OS need 64bit shell extensions.
        Though, maybe you can see them in the file dialog of 32bit applications..?
          j40
          Yes, as I wrote: "The only way to view the skp files that possible for me is with SU browser window in thumbnail view"
          via the "open file" Su browser.
          Top3D Studio
            As I thought, the shell extension only works within 32bit applications that uses the 32-bit shell.
            What I think you can do, in WinXP and Vista (not possible in Win7) is run this command:
            C:\Windows\SysWOW64\explorer.exe /separate
            That should start an 32bit instance of explorer.exe.
            Mind you, you might find other issue with that.
              j40
              Other issues? Can you specify? ❓
              I prefer to know before i do it. πŸ€“
              Top3D Studio
                If you have 64bit extensions for other apps - you might not see them in the 32bit version unless that was also installed.
                  j40
                  Thanks Thom,
                  I entered this command and it poped up a explorer window in which wherever i browsed i could see the thumbnails previews (SU and PDF, yes the the pdfs are also unseen in the thumbnail view).
                  But if i brows from different/any explorer window the problem remains the same... 😞
                  Top3D Studio
                    yes, you have to launch explorer.exe with that command. Make a shortcut on your desktop to it for easy access.
                      • Right-click your desktop
                      • New->Shortcut
                      • Enter C:\Windows\SysWOW64\explorer.exe /separate as the program path
                        j40
                        A shortcut would be great πŸ˜„ . Can you please explain how can i make one specifically for this command ?
                        Top3D Studio
                          j40
                          Thanks Thom Works great!
                          Top3D Studio
                          • B
                            BorgMan
                            I have tried the Seperate command with Windows 7, but alas, it doesn't work. Has anyone come up with a solution for this rather annoying problem already?
                            More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
                            You've gotta love Slivers.
                              Nope. They changed something between the Beta and the RC so explorer.exe always spawn the 64bit version.
                              • EarthMoverE
                                EarthMover
                                Great trick Thomas! Thanks!! I'll just use the shortcut to search through components. At least I'll have a back button that way.
                                Content Creator at Skapeup
                                • brodieB
                                  brodie
                                  Great find! Thom's shortcut method is working great for me on Vista 64.
                                  -Brodie
                                  • B
                                    BorgMan
                                    I'm going to bump this topic because I'm really curious as to whether this problem has been solved in the released versions of Windows 7. Hey Google, are you watching this? We want our preview back 😑
                                    • E
                                      Ecuadorian
                                      Another bump from me. I'm in Windows 7 Pro 64-bit.
                                      I know the GSU team is working hard in V8, so I hope they add the much needed 64-bit shell extension for Windows Explorer.
                                      -Miguel Lescano
                                        No - You can't run the 32bit explorer.exe in the final W7 either.
                                        • EddyNLE
                                          EddyNL
                                          Hi guys,
                                          I'm using Win 7 64 bit and my previews are also lost.
                                          Is there a workaround / solution?
                                          Kind regards,
                                          Ward
                                          viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
                                          • Y
                                            ye136577267
                                            • 2 / 8
