    (TRICK) To re-enable skp file preview
    147 Posts 60 Posters 210.3k Views 60 Watching
    • K
      kevsterman
      Thanks for that hint Kwist. I've downloaded Xnview and it does the trick, tho as you say, being able to do it in the native explorer would definitly have been better.
      "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
        j40
        @kwistenbiebel said:
        For Vista 64 bit users (the TRICK is only for XP) Xnview works as well.
        Being able to see the icons in the native explorer would have been better though...
        Hey Biebel,
        I just installed XP Pro 64bit, and the thumbnails don't work from the beginning. I've tried the command you mentioned, but this is what i got.
        Command on XP x64
        Top3D Studio
          j40
          Is there XP-64 bit users that can see SU's thumbnails? πŸ˜•
          I can't make it work. The only way to view the skp files that possible for me is the SU browser window in thumbnail view 😞
          Top3D Studio
            Don't think there is. The SU preview is a shell extension and 64bit OS need 64bit shell extensions.
            Though, maybe you can see them in the file dialog of 32bit applications..?
              j40
              Yes, as I wrote: "The only way to view the skp files that possible for me is with SU browser window in thumbnail view"
              via the "open file" Su browser.
              Top3D Studio
                As I thought, the shell extension only works within 32bit applications that uses the 32-bit shell.
                What I think you can do, in WinXP and Vista (not possible in Win7) is run this command:
                C:\Windows\SysWOW64\explorer.exe /separate
                That should start an 32bit instance of explorer.exe.
                Mind you, you might find other issue with that.
                  j40
                  Other issues? Can you specify? ❓
                  I prefer to know before i do it. πŸ€“
                  Top3D Studio
                    If you have 64bit extensions for other apps - you might not see them in the 32bit version unless that was also installed.
                      j40
                      Thanks Thom,
                      I entered this command and it poped up a explorer window in which wherever i browsed i could see the thumbnails previews (SU and PDF, yes the the pdfs are also unseen in the thumbnail view).
                      But if i brows from different/any explorer window the problem remains the same... 😞
                      Top3D Studio
                        yes, you have to launch explorer.exe with that command. Make a shortcut on your desktop to it for easy access.
                          • Right-click your desktop
                          • New->Shortcut
                          • Enter C:\Windows\SysWOW64\explorer.exe /separate as the program path
                            j40
                            A shortcut would be great πŸ˜„ . Can you please explain how can i make one specifically for this command ?
                            Top3D Studio
                              j40
                              Thanks Thom Works great!
                              Top3D Studio
                              • B
                                BorgMan
                                I have tried the Seperate command with Windows 7, but alas, it doesn't work. Has anyone come up with a solution for this rather annoying problem already?
                                More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
                                You've gotta love Slivers.
                                  Nope. They changed something between the Beta and the RC so explorer.exe always spawn the 64bit version.
                                  • EarthMoverE
                                    EarthMover
                                    Great trick Thomas! Thanks!! I'll just use the shortcut to search through components. At least I'll have a back button that way.
                                    Content Creator at Skapeup
                                    • brodieB
                                      brodie
                                      Great find! Thom's shortcut method is working great for me on Vista 64.
                                      -Brodie
                                      • B
                                        BorgMan
                                        I'm going to bump this topic because I'm really curious as to whether this problem has been solved in the released versions of Windows 7. Hey Google, are you watching this? We want our preview back 😑
                                        • E
                                          Ecuadorian
                                          Another bump from me. I'm in Windows 7 Pro 64-bit.
                                          I know the GSU team is working hard in V8, so I hope they add the much needed 64-bit shell extension for Windows Explorer.
                                          -Miguel Lescano
                                            No - You can't run the 32bit explorer.exe in the final W7 either.
                                            • 2 / 8
