    New API doc - typos and questions
    370 Posts 35 Posters 263.6k Views 35 Watching
      View.pickray
      http://code.google.com/apis/sketchup/docs/ourdoc/view.html#pickray
      The pickray method is used to retrieve a ray passing through a given screen position in the viewing direction.
      Returns:
      ray
      a ray
      The "ray" is a Line; Array [Point3D, Vector3D] and the Point3D is the camera.eye.
      • Chris FullmerC Offline
        I hope Scott stops by soon. He's got a lot of stuff here to pick up πŸ˜„
          Looking back at this thread I can trail the subjects I was looking into while making plugins. Like breadcrumbs. πŸ˜„
            UI.menu lists the valid menus titles, one is 'Create' isn't it 'Draw' ?
            • RunnerPackR Offline
              RunnerPack
              Point3d.offset (http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#offset) Description of the length parameter:
              (optional) the distance to offset. If not provided, the offset is my a distance equal to the vector length.
              Suggestion:
              The (optional) offset distance. If not provided, the point is offset a distance equal to the vector's length.
              You might have noticed... I'm a bit of a ferpectionist.
                Face.mesh
                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#mesh
                The mesh method creates a polygon mesh that represents the face. See the PolygonMesh class for more information.
                Valid flags are:
                * 0: Include PolygonMeshPoints,
                * 1: Include PolygonMeshUVQFront,
                * 2: Include PolygonMeshUVQBack,
                * 4: Include PolygonMeshNormals.
                Add these numbers together to combine flags. A value of 5 will include all flags, for example.
                The example uses 7. Typo or undocumented feature?
                  avariant
                  You can bit-wise OR the options together. 7 means 4 + 2 + 1, so normals, front UV, and back UV.
                    remus
                    For acolor it's always = 255 [100% opaque]... there is a color.alpha= method but it's never ever worked, you must set alpha [transparency] for a material itself not material.color e.g. material.alpha=0.4 for 40% opacity will work but the material.color.alpha still reports 255 [100%], if you try to change it, it just does nothing !
                    So to recap - the fourth item in a SUp material.color array is its alpha [r,g,b,a] but it's not used ! The alpha of the material itself works as a 0 to 1.0, equivalent to % setting of opacity...
                    http://code.google.com/apis/sketchup/do ... color.html
                      UI.inputbox
                      http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#inputbox
                      Returns false, not nil when user cancels.
                        WebDialog.new
                        http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html#new
                        Two last parameters isn't explained.
                          remus
                          BoundingBox.min
                          returns: a Point3d object representing the point where x, y, and z are the maximum in the bounding box.
                          Im guessing it should say minimum.
                            WebDialog.get_element_value
                            http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html#get_element_value
                            The example hasn't escaped the HTML tags - so the HTML sample text is instead interpreted by the browser..
                              Curve.move_vertices
                              http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/curve.html#move_vertices
                              Description says:
                              The vertices method retrieves a collection of all vertices in a curve.
                                Tool.enableVCB?
                                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/tool.html#enableVCB?
                                The enableVCB? method is used to tell SketchUp whether to allow the user to enter text into the VCB (value control box, aka the "measurements" panel). If you do not implement this method, then the vcb is disabled by default.
                                I've never used this method for my Tools. But the VCB has still worked.
                                  Image.size=
                                  http://code.google.com/apis/sketchup/docs/ourdoc/image.html#size=
                                  It appears that the second argument is optional.
                                    Entity.entityID
                                    http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entity.html#entityID
                                    The entityID method is used to retrieve a unique ID assigned to an entity.
                                    The entityID is not persistent between sessions.
                                    Is it persistent within a session? Can it be relied on for the length of one session?
                                      ComponentDefinition.guid
                                      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/componentdefinition.html#guid
                                      Is this value persistent between sessions?
                                        Jim
                                        Sketchup::Color.new
                                        new can accept a hex value (not string) as the parameter: for example 0xFF0000 (undocumented)
                                        But, it reverses the red and blue values. Here is a Console session. (bug)
                                        Sketchup;;Color.new 0xFF0000
                                        Color(  0,   0, 255, 255)
                                        Sketchup;;Color.new 0x0000FF
                                        Color(255,   0,   0, 255)
                                        • scottliningerS Offline
                                          scottlininger
                                          I've got some catching up to do. Thanks for all of the details, guys! πŸ˜‰
                                          • Scott Lininger
                                            SketchUp Software Engineer
                                            Have you visited the Ruby API Docs?
                                            ModelObserver.onDeleteModel vs ModelObserver.onEraseAll
                                            http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onDeleteModel
                                            When does the onDeleteModel event trigger? I don't think I've ever seen it trigger. When I open an existing model or create a new model onEraseAll is triggered.
                                            • 18
                                            • 19
                                            • 2 / 19
