    New API doc - typos and questions
    370 Posts 35 Posters 293.3k Views 35 Watching
      Jim
      @thomthom said:
      So this is a ruby thing? That the = is part of the method name? What about other operations where you use * - + / etc?
      (I'm used to languages such as Javascript, PHP, VB, C# - still getting to grips with Ruby.)
      Yes, those are all methods. also [] and []= are methods. You can define them for you own classes, as well as modify them for existing classes.
      class Array
        def [](index)
          return self[-index] # ha ha.
        MarkBergaas
        Behavior.snapto
        I see two problems with the documentation of this method (I would like to call it a property, but that is probably my C# habit talking):
        The "Returns:" section says it returns true or false, but it actually returns one of the 4 values listed in the description above "Returns:" (the default seems to be SnapTo_Arbitrary). The first sentence of the description ("The snapto method is used to verify the status of a component's "snap to" behavior.") also implies that the return value is a status, not the actual "snap to" selection.
        It would be very helpful if the documentation of this method would make it clear that the value of Behavior.snapto works in conjunction with the value of Behavior.is2d to set the "glue to" behavior. If is2d equals false, the component will not glue to anything, no matter what value snapto returns. If is2d equals true, the component will glue to faces matching the snapto value.
        I don’t think it is at all clear that these two (snapto and is2d) are related. It would be helpful to include a reference to snapto in the description of is2d, also.
        This second issue applies equally, if not more, to the snapto= and is2d= methods.
          Jim
          Pages.add should contain some of this information about the meaning of the flags argument.
          [ and also, Pages.add returns a Page object, not nil. ]
          # The Page Constants
          Object.constants.grep /^pag/i
          ["PAGE_USE_SECTION_PLANES", "PAGE_USE_ALL", "PAGE_NO_CAMERA", "PAGE_USE_CAMERA", "PAGE_USE_RENDERING_OPTIONS", "PAGE_USE_SHADOWINFO", "PAGE_USE_SKETCHCS", "PAGE_USE_HIDDEN", "PAGE_USE_LAYER_VISIBILITY"]
          model = Sketchup.active_model
          pages = model.pages
          index = 0
          page = pages.add("New Page", PAGE_USE_ALL, index)
          If you want to pick and choose which options, bitwise OR ( | ) the options together:
          pages = model.pages
          index = 0
          page = pages.add("New Page", (PAGE_USE_HIDDEN|PAGE_USE_CAMERA), index)
            Jim
            View.write_image
            From my tests, write_image will accept several common image formats - .jpg, .bmp, .png at least. There is no mention of this in the docu. Just include the extension in the filename - as in "path/to/my_image.png"
            If you do not provide the optional width or height, the image uses the View Size for the written image.
            write_image returns true on success or false on failure, not nil (from my experience.)
              Entities.add_arc
              http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#add_arc
              Returns:
              arccurve
              an ArcCurve object if successful
              It returns an array of edges instead.
                avariant
                PolygonMesh.uv_at
                Arguments;
                index    The index for the texture coordinate.
                Doesn't include the second argument, which is true for front face coordinates, false for back face.
                PolygonMesh.uvs
                Doesn't include the required argument, true for front face coordinates, false for back face.
                  Camera.set
                  http://code.google.com/apis/sketchup/docs/ourdoc/camera.html#set
                  The initialize method is deprecated. It essentially does the same thing as Camera.set.
                  Camera.set does what Camera.set does? ... "Spider Pig! Spider Pig! Does whatever piderpigs does."
                    View.pickray
                    http://code.google.com/apis/sketchup/docs/ourdoc/view.html#pickray
                    The pickray method is used to retrieve a ray passing through a given screen position in the viewing direction.
                    Returns:
                    ray
                    a ray
                    The "ray" is a Line; Array [Point3D, Vector3D] and the Point3D is the camera.eye.
                    • Chris FullmerC Offline
                      I hope Scott stops by soon. He's got a lot of stuff here to pick up 😄
                        Looking back at this thread I can trail the subjects I was looking into while making plugins. Like breadcrumbs. 😄
                          UI.menu lists the valid menus titles, one is 'Create' isn't it 'Draw' ?
                          • RunnerPackR Offline
                            RunnerPack
                            Point3d.offset (http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#offset) Description of the length parameter:
                            (optional) the distance to offset. If not provided, the offset is my a distance equal to the vector length.
                            Suggestion:
                            The (optional) offset distance. If not provided, the point is offset a distance equal to the vector's length.
                            You might have noticed... I'm a bit of a ferpectionist.
                              Face.mesh
                              http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#mesh
                              The mesh method creates a polygon mesh that represents the face. See the PolygonMesh class for more information.
                              Valid flags are:
                              * 0: Include PolygonMeshPoints,
                              * 1: Include PolygonMeshUVQFront,
                              * 2: Include PolygonMeshUVQBack,
                              * 4: Include PolygonMeshNormals.
                              Add these numbers together to combine flags. A value of 5 will include all flags, for example.
                              The example uses 7. Typo or undocumented feature?
                                avariant
                                You can bit-wise OR the options together. 7 means 4 + 2 + 1, so normals, front UV, and back UV.
                                  remus
                                  For acolor it's always = 255 [100% opaque]... there is a color.alpha= method but it's never ever worked, you must set alpha [transparency] for a material itself not material.color e.g. material.alpha=0.4 for 40% opacity will work but the material.color.alpha still reports 255 [100%], if you try to change it, it just does nothing !
                                  So to recap - the fourth item in a SUp material.color array is its alpha [r,g,b,a] but it's not used ! The alpha of the material itself works as a 0 to 1.0, equivalent to % setting of opacity...
                                  http://code.google.com/apis/sketchup/do ... color.html
                                    UI.inputbox
                                    http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#inputbox
                                    Returns false, not nil when user cancels.
                                      WebDialog.new
                                      http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html#new
                                      Two last parameters isn't explained.
                                        remus
                                        BoundingBox.min
                                        returns: a Point3d object representing the point where x, y, and z are the maximum in the bounding box.
                                        Im guessing it should say minimum.
                                          WebDialog.get_element_value
                                          http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html#get_element_value
                                          The example hasn't escaped the HTML tags - so the HTML sample text is instead interpreted by the browser..
                                            Curve.move_vertices
                                            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/curve.html#move_vertices
                                            Description says:
                                            The vertices method retrieves a collection of all vertices in a curve.
                                            • 18
                                            • 19
                                            • 6 / 19
