    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 160.2k Views 83 Watching
    • fredo6F Offline
      @daniel s said:
      ๐Ÿ˜ฎ ๐Ÿ˜ฎ
      I donยดt know if Fredo put that image too see what Pico mean or if he is showing the next version of round edge????
      Daniel S
      This is in the making, but I hardly find time to progress.
        I'll be looking forwards to this. Rounding the edges in that manner is a must to model and render a realistic product model.
          Pico
          @pico said:
          Has the pointy corner problem been solved?
          Thanx ๐Ÿ˜„
          Do you mean this?
          [attachment=0:ktbcwyt8]<!-- ia0 -->RoudnCorner.jpg<!-- ia0 -->[/attachment:ktbcwyt8]
          Yes!
          How much longer?
            It's a great plugin even with the pointy edges but this would definitely take it to a "next level". ๐Ÿ‘
            Just take your time, Fredo, we are not impatient
            (not impatient... not impatient ๐ŸŽ‰ )
              Daniel S
              Just to know that youยดre behind a new version makes me happy ๐Ÿ˜ ๐Ÿ˜
              Iยดm not impatient too.. but I just make alternative icons for the future plugin ๐ŸŽ‰
              Daniel S ๐ŸŽ‰
              alternative icons.zip
              • fredo6F Offline
                Daniel,
                Thanks very much for the icons.
                If you don't mind, I will make them the primary icons, because mine were really ugly.
                  craigslist.men
                  is there any way i can round the edge only bit like a 1/16 or even less?
                    Daniel S
                    Daniel,
                    Of course you can, and thanks again for working in this plugin.
                    A workaround is to scale the model. For example with my units you canยดt round less than 0,5 cm. So if you need to round 0,4 cm you can scale up the model 10 times and round 4 cm. Then you scale down (0,1) and you have the rounded edges in 0,4 cm.
                    If you need less you can scale 100 times larger or even more, and scale down when done.
                    Daniel S
                    • plot-parisP Offline
                      plot-paris
                      oooh, I am so looking forward to this new version! I guess there is a whole community eagerly awaiting your next breakthrough.
                      so no pressure there, fredo ๐Ÿ˜„
                        TeamSDA
                        We also want to Chime in and agree that a professional grade tool for bullnosing and filletting is much needed.
                        Team SDA
                          magpie
                          Many thanks Fredo for your elegant plugin.
                          As a new user to all this, it has worked like a dream! Very useful and easy to incorporate into sketchup...thanks too to the icon-maker! Looks good!
                          • CarrozzaC Offline
                            Carrozza
                            Go Fredo Go!!!
                            • N Offline
                              NawaGK
                              Thank +++
                                Jebimasta
                                Thanks, Fredo, for your brilliant plugin!
                                unfortunatly the model I needed to use it on includes instances where concave meets convex.
                                Obviously this is a problem ๐Ÿ˜› Any headway on solving this issue?
                                Thanks again ๐Ÿ˜„
                                • fredo6F Offline
                                  Jebimasta,
                                  Then you should look at a more recent plugin, RoundCorner 2.0
                                  Download, doc and video is at http://forums.sketchucation.com/viewtopic.php?f=180&t=20485#p171721
                                  • N Offline
                                    novice
                                    Cool Fredo!
                                    Thank you!
                                      burgerlord
                                      thanks friend. cool plugin. XD
                                      nature sings in the ears of the world.. be GREEN!
                                        darkme
                                        hello
                                        dose it work on os x?
                                        • fredo6F Offline
                                          @darkme said:
                                          does it work on os x?
                                          Probably, but you should consider the more rcenet version RoundCorner that handles 'real' round edges.
                                          See http://forums.sketchucation.com/viewtopic.php?f=323&t=20485&hilit=plugin#p171721
                                            Fredo: do we need these old versions around? I see several times people refering to these older versions without being aware of the newer ones. Can't we just shut them down and direct to the latest?
                                            • 4 / 9
