    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] HoverSelect - v1.5a - 07 Oct 17
    81 Posts 34 Posters 126.1k Views 34 Watching
      Daniel S
      This is the next generation of UI in SketchUp!!!
      A lot better, quick, easy and more efficient than the webdialogs (and I assume that is also more compatible for macs).
      I make alternative icons and cursors for this plugin:
      Here you can download them:
      To drop into HOVERSELECT_Dir_11 folder
      Extract into Plugins\HOVERSELECT_Dir_11 and set this ones in "Tools>Fredo6 Collection>HoverSelect>Default Parameters...
      Thank you again Fredo!!
      Daniel S
      PS. The new Edge selection via rectangle dosen“t work inside groups (I mean double click on group to edit and then select the hoverselect).
      • fredo6F Offline
        I made a try, but if this works and does not create too much interference, I'll try to extend to other scripts.
        Thanks very much. I will integrate.
        For the button palette, unfortunately the buttons are not image files, but drawing with primitives. I have not found any method to draw png in the viewport.
        This is intentional. You can only select at the first level of the active model, as in Sketchup native. Anyway, you would have some problem with the selection, if you selected within a component or group.
          Daniel S
          It is difficult to me to explain this in english so i make this gif:
          The first time the selection is good because selects all at the first level (visible-only / Ray Cast Selection).
          The second time I“m editing a group, but dosen“t selects what is inside the group but yes what it is outside. This is intentional? In SketchUp if you are editing a group you can select all what is inside the group and nothing outside. In this case it“s not selecting inside the group and yes outside this group.
          Daniel S
            l.frisken
            I have been looking forward to a plugin like this for so long! thankyou so much!
            • fredo6F Offline
              Daniel S
              Daniel,
              Thanks for signaling. This is simply a big bug which I fixed in 1.1c (actually a lack of attention).
              • fredo6F Offline
                New version **HoverSelect 1.1c**available. It fixes a big bug related to selection from within groups and components.
                see main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=18916#p155058
                  Matt666
                  Fredddooooo!! Mais comment fais-tu !!?? Impressionnant, je suis que je suis complĆØtement fan de tes plugins !! Bravo...
                  For those who didn't adopt this incredible new plugin:
                  Frenglish at its best !
                  My scripts
                  • fredo6F Offline
                    New version **HoverSelect 1.1d (23 May 09)**available. It fixes a bug in the 'All Connected' selection mode.
                      [attachment=0:3frmu70t]<!-- ia0 -->Sans titre 2.jpg<!-- ia0 -->[/attachment:3frmu70t]
                      Is that the UI? How on earth is that done??
                        Matt666
                        Yes 😲 😲 😲
                        Awesome...
                        My scripts
                          How is it one? 😲 I'm really curious.
                          • Chris FullmerC Offline
                            Have you downloaded it and used it Thom? Its an awesome UI!
                            I think that it is is done with the view.draw type methods. All the draw, draw2d, draw_points, draw_polyline, draw_text. That is my guess.
                            • fredo6F Offline
                              Yes, this is actually pure drawing routines in the view. Which is somehow also an issue to capture events when you cascade tools.
                              So far, this is experimental, but I'll work on it to retrofit in other plugins.
                                I thought you could only draw lines and text. Not filled shapes. I need to look at the API again.
                                • massimoM Offline
                                  massimo Moderator
                                  Hi Fredo, i've not tried this plugin yet and maybe it works for my request. But it's possible to add a filter "by distance" to the selection via rectangle? I try to explain: actually when you select by a rectangle you select all edges and faces in the window even if they are very far and that is quite annoying. I have in mind an option with an input for maximum distance selection like, for example, "select all edges and faces in the window as far as 100 cm". Something like "Max Wall Thickness" in Windowizer 4 plugin.
                                  Thank you and sorry if that is a nonsense...
                                  Massimo.
                                  • fredo6F Offline
                                    Massimo,
                                    This make perfect sense.
                                    And after all, the tool is there to comply with requests from users.
                                    I'll do something in a next version.
                                    Thanks for the idea.
                                    • mitcorbM Offline
                                      mitcorb
                                      Fredo:
                                      This would be the variable falloff "brush" available in some other modelers.
                                      Sure would be nice to have this capability.
                                        pichuneke
                                        Working on the spanish translation (very busy these days...)
                                        Forgive my spanglish...
                                        • EarthMoverE Offline
                                          EarthMover
                                          I've grown to use this plugin as much or more than any other. I've actually added it as the shortcut Shift + Spacebar and I'll use in place of the standard selection tool.
                                          It is perfect except for one or two things.
                                          Fredo,
                                          In the next version can you change the way that hitting shift will toggle the "select all connected lines" on? Can it be set that when you let go of shift, the command goes back to standard selection mode? I often have to move and pan around the scene while selecting lines and anytime I pan using shift, it turns on the select all connected lines and I have to turn it back off to keep hover selecting the additional lines. A minor headache, but one nonetheless.
                                          Also the select all connected lines is very inconsistent for me. A lot of times it will register that there are connected lines and the arrow will change color and the plus sign will appear, but it will not select anything at all. Then I go to a parallel set of lines that form the same structure and it has no problem. It is an issue with intersecting hidden or softened lines touch the line I want to select continuously?
                                          Thanks again Fredo for all your great time saving tools!!!!
                                          Content Creator at Skapeup
                                            How do you actually draw filled shapes to the viewport?
                                            • 4 / 5
