    [Plugin] HoverSelect - v1.5a - 07 Oct 17
    81 Posts 34 Posters 146.6k Views 34 Watching
    • kenK Offline
      ken
      Fredo6
      Yes, I do get a Bug Splat when I open up your other documentations. I have other problems also, haven't been able to trace those down to any particular scrip or set of scrip’s. Therefore, I will just go about my way, remembering what not to do, and saving or archiving frequently.
      Again thanks for all your effort in these plugins.
      Ken
        jmmad
        @jmmad said:
        Would it be posible to make a ruby that selects multiple endpoints ?
        Do you mean vertices?
        Yes Fredo it would be nice to select multiple vertices instead of lines, so the we can modify them (rotate, scale, move, etc..) all at the same time.
        But i have never seen a ruby that does that. Is it possible?
        Get Upa !
          August
          ... if users draw the selection rectangle from the North West corner to the South East corner of the screen (ie top left to lower right) then all geometry COMPLETELY inside this rectangle is selected.
          If users draw the selection rectangle from the South East corner to the North West corner of the screen (ie lower right to top left) then all geometry INSIDE AND CROSSING this rectangle is selected. ...
          Just to clarify my possibly mistaken understanding of the conversation so far --
          This tool is about ONLY selecting the VISIBLE geometry, right? The above describes what SU already does, selecting ALL geometry inside in the first case, and ALL geometry even partially inside in the second case, including ALL geometry, including parts on the backside of the front object and parts that may be at a great distance.
          Howard Leslie is too modest when he says "An idea might be ..." Using the direction the selection rectangle is drawn as the way to toggle what is included should, of course, echo what SU already does. Anything else would be too confusing.
          August
          “An idea, like a ghost, must be spoken to a little before it will explain itself.”
          [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
          • fredo6F Offline
            New version **HoverSelect 1.1a**available, with some additional features, mainly:
            • Edge selection (and un-selection) via rectangle, by mouse dragging, for visible-only edges (but also for all edges, as in native Sketchup)
            • Configuration of the precision for picking edges
            • Options (modifiers and filter) accessible via a button palette (experimental). There are indeed also accessible via the contextual menu and shortcuts.
            see main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=18916#p155058
              jmmad
              Nice UI update Fredo
              I like that "button palette" that pops up with the command
              Thxs
              Get Upa !
                Daniel S
                This is the next generation of UI in SketchUp!!!
                A lot better, quick, easy and more efficient than the webdialogs (and I assume that is also more compatible for macs).
                I make alternative icons and cursors for this plugin:
                Here you can download them:
                To drop into HOVERSELECT_Dir_11 folder
                Extract into Plugins\HOVERSELECT_Dir_11 and set this ones in "Tools>Fredo6 Collection>HoverSelect>Default Parameters...
                Thank you again Fredo!!
                Daniel S
                PS. The new Edge selection via rectangle dosen´t work inside groups (I mean double click on group to edit and then select the hoverselect).
                • fredo6F Offline
                  I made a try, but if this works and does not create too much interference, I'll try to extend to other scripts.
                  Thanks very much. I will integrate.
                  For the button palette, unfortunately the buttons are not image files, but drawing with primitives. I have not found any method to draw png in the viewport.
                  This is intentional. You can only select at the first level of the active model, as in Sketchup native. Anyway, you would have some problem with the selection, if you selected within a component or group.
                    Daniel S
                    It is difficult to me to explain this in english so i make this gif:
                    The first time the selection is good because selects all at the first level (visible-only / Ray Cast Selection).
                    The second time I´m editing a group, but dosen´t selects what is inside the group but yes what it is outside. This is intentional? In SketchUp if you are editing a group you can select all what is inside the group and nothing outside. In this case it´s not selecting inside the group and yes outside this group.
                    Daniel S
                      l.frisken
                      I have been looking forward to a plugin like this for so long! thankyou so much!
                      • fredo6F Offline
                        Daniel S
                        Daniel,
                        Thanks for signaling. This is simply a big bug which I fixed in 1.1c (actually a lack of attention).
                        • fredo6F Offline
                          New version **HoverSelect 1.1c**available. It fixes a big bug related to selection from within groups and components.
                            Matt666
                            Fredddooooo!! Mais comment fais-tu !!?? Impressionnant, je suis que je suis complètement fan de tes plugins !! Bravo...
                            For those who didn't adopt this incredible new plugin:
                            Frenglish at its best !
                            My scripts
                            • fredo6F Offline
                              New version **HoverSelect 1.1d (23 May 09)**available. It fixes a bug in the 'All Connected' selection mode.
                                [attachment=0:3frmu70t]<!-- ia0 -->Sans titre 2.jpg<!-- ia0 -->[/attachment:3frmu70t]
                                Is that the UI? How on earth is that done??
                                  Matt666
                                  Yes 😲 😲 😲
                                  Awesome...
                                  My scripts
                                    How is it one? 😲 I'm really curious.
                                    • Chris FullmerC Offline
                                      Have you downloaded it and used it Thom? Its an awesome UI!
                                      I think that it is is done with the view.draw type methods. All the draw, draw2d, draw_points, draw_polyline, draw_text. That is my guess.
                                      • fredo6F Offline
                                        Yes, this is actually pure drawing routines in the view. Which is somehow also an issue to capture events when you cascade tools.
                                        So far, this is experimental, but I'll work on it to retrofit in other plugins.
                                          I thought you could only draw lines and text. Not filled shapes. I need to look at the API again.
                                          • massimoM Offline
                                            massimo Moderator
                                            Hi Fredo, i've not tried this plugin yet and maybe it works for my request. But it's possible to add a filter "by distance" to the selection via rectangle? I try to explain: actually when you select by a rectangle you select all edges and faces in the window even if they are very far and that is quite annoying. I have in mind an option with an input for maximum distance selection like, for example, "select all edges and faces in the window as far as 100 cm". Something like "Max Wall Thickness" in Windowizer 4 plugin.
                                            Thank you and sorry if that is a nonsense...
                                            Massimo.
                                            • 2 / 5
