    SVG file Import (importing)
    20 Posts 11 Posters 26.2k Views 11 Watching
      Jim
      I have not bee able to get an svg file imported. I think I have the setup right - all the files in the right place. I am able to start the import, an SVG Layer is created, but no geometry - only a lot of errors. I'm not sure at this point if it is the svg.rb file, or the rexml library that's generating the errors. I'm still trying as time permits.
      I've attached what I have so far.
      attachment removed due to conflict with set.rb
      • kenK
        ken
        Jim
        Thanks for the help. I am on my way home after 6 weeks in LA. Will be offline for a couple of days.
        Thanks again for you help
        Ken
        • X
          xavier9
          Hello, I'm french, new here and my english is bad...
          I've seen that bezier.rb is missing in the zip file.
          I've found it on the Didier Bur's site.
          I could open just a few svg files, but the others
          can be converted to SIMPLE svg files with Inkscape.
          It works for me.
          Xavier
            Jim
            It works for me.
            Xavier
            Yes, I forgot to include bezier.rb in the .zip file, I have added it to the .zip. I do have it in my plugins folder. Can you post an example svg file that you were successful in importing?
            • X
              xavier9
              This one is importable
              Xavier
              Importable AFTER decompression!
              • X
                xavier9
                Now, a not importable svg opened with Inkscape and saved as "simple svg"
                It rocks!
                Xavier
                the two versions are included
                • X
                  xavier9
                  Hm...
                  "Simple svg" is a french translation for "Plain svg"
                  So, in Inkscape, choose "Save as Plain svg" to have a file you can open in SU.
                  Xavier
                    Jim
                    Ah yes, it now works. I have Inskscape installed, but I missed the "Save as Plain SVG" Option.
                    Thank you, Xavier.
                    • E
                      Eulgrand
                      Has anyone experienced problems with the sandbox tool after installing SVG import ? I did : no more smoove...
                      • CadFatherC
                        CadFather
                        yes the two don't work together
                        • E
                          Eulgrand
                          Thanks a lot CadFather, I'll deal with it 😉
                            maxim_
                            Hello. I am a newbie and I speak Russian. Translation of Google. I have a problem. When you import an SVG, I receive an error:
                            Error (in script) while reading “D:\Libelle_3-view-SIMPLE.svg”:
                            Exception parsing
                            How to solve this problem?
                            Regards Max.
                              danbig
                              Hi -
                              Has anyone used this scrip in SU8 yet?
                              I get the following error when I try to import:
                              • C
                                Catalyst
                                Hi danbig,
                                You need to open your SVG file with inkscape.
                                1. Go into Inskcape's preferences
                                2. Under "Tools" select "SVG output"
                                3. Under "Path data" - uncheck "Allow relative coordinates"
                                4. Right below that - check "Force repeat commands"
                                Be sure to save the new preferences by hitting the little triangle-in-a-box button in the top right corner of the preferences window.
                                Once you do that, you can save Plain SVG files and import them successfully into Sketchup for further manipulation.
                                • dereiD
                                  derei
                                  Where I can find this SVG importer ? Is it possible to be posted here, on SketchUcation?
                                  Thank you.
                                  DESIGNER AND ARTIST DEREI.UK
                                    http://flightsofideas.net/ seems to be the source of many things SVG...
                                    e.g http://code.google.com/p/sketchup-svg-outline-plugin/downloads/detail?name=sketchup-svg-outlines-plugin-0.99.zip
                                    and for which http://www.sketchucation.com/forums/viewtopic.php?f=323&t=29481 also applies ?
                                    BUT this http://rhin.crai.archi.fr/rld/plugin_details.php?id=435
                                    etc etc...
                                      Majenta
                                      @catalyst said:
                                      Hi danbig,
                                      I HAVE NOT BEEN ABLE TO SUCCESSFULLY IMPORT A PLAIN SVG FILE INTO SKETCHUP MAKE 2014 USING THIS METHOD. IS THERE ANY ADDITIONAL STEPS I NEED? GOAL IS TO INPUT A SVG FILE (THE WORDS "PEACE" "ON" AND 'EARTH" WHICH HAVE BEEN TRACED AND WELDED TOGETHER IN TO THREE INDIVIDUAL SVGS.) OF A WELDED WORD INTO SKETCHUP AND EXTRUDE IT TO MAKE A 3D 'BOX' ABOUT 2" THICK.
