    SVG file Import (importing)
    20 Posts 11 Posters 26.1k Views 11 Watching
    • kenK
      ken
      @jim said:
      Ken, I'll try to put rexml and svg.rb plugin together in a package for you. Stay tuned...
      Thank you. I am not even sure what all I was looking for and what all I would need.
      What I wanted to do is to be able to bring back into sketchup the exported SVG files, so I could re-export the drawing into DWG files, without have to go through Visio.
      Ken
        Jim
        I have not bee able to get an svg file imported. I think I have the setup right - all the files in the right place. I am able to start the import, an SVG Layer is created, but no geometry - only a lot of errors. I'm not sure at this point if it is the svg.rb file, or the rexml library that's generating the errors. I'm still trying as time permits.
        I've attached what I have so far.
        attachment removed due to conflict with set.rb
        • kenK
          ken
          Jim
          Thanks for the help. I am on my way home after 6 weeks in LA. Will be offline for a couple of days.
          Thanks again for you help
          Ken
          • X
            xavier9
            Hello, I'm french, new here and my english is bad...
            I've seen that bezier.rb is missing in the zip file.
            I've found it on the Didier Bur's site.
            I could open just a few svg files, but the others
            can be converted to SIMPLE svg files with Inkscape.
            It works for me.
            Xavier
              Jim
              It works for me.
              Xavier
              Yes, I forgot to include bezier.rb in the .zip file, I have added it to the .zip. I do have it in my plugins folder. Can you post an example svg file that you were successful in importing?
              • X
                xavier9
                This one is importable
                Xavier
                Importable AFTER decompression!
                • X
                  xavier9
                  Now, a not importable svg opened with Inkscape and saved as "simple svg"
                  It rocks!
                  Xavier
                  the two versions are included
                  • X
                    xavier9
                    Hm...
                    "Simple svg" is a french translation for "Plain svg"
                    So, in Inkscape, choose "Save as Plain svg" to have a file you can open in SU.
                    Xavier
                      Jim
                      Ah yes, it now works. I have Inskscape installed, but I missed the "Save as Plain SVG" Option.
                      Thank you, Xavier.
                      • E
                        Eulgrand
                        Has anyone experienced problems with the sandbox tool after installing SVG import ? I did : no more smoove...
                        • CadFatherC
                          CadFather
                          yes the two don't work together
                          • E
                            Eulgrand
                            Thanks a lot CadFather, I'll deal with it 😉
                              maxim_
                              Hello. I am a newbie and I speak Russian. Translation of Google. I have a problem. When you import an SVG, I receive an error:
                              Error (in script) while reading “D:\Libelle_3-view-SIMPLE.svg”:
                              Exception parsing
                              How to solve this problem?
                              Regards Max.
                                danbig
                                Hi -
                                Has anyone used this scrip in SU8 yet?
                                I get the following error when I try to import:
                                • C
                                  Catalyst
                                  Hi danbig,
                                  You need to open your SVG file with inkscape.
                                  1. Go into Inskcape's preferences
                                  2. Under "Tools" select "SVG output"
                                  3. Under "Path data" - uncheck "Allow relative coordinates"
                                  4. Right below that - check "Force repeat commands"
                                  Be sure to save the new preferences by hitting the little triangle-in-a-box button in the top right corner of the preferences window.
                                  Once you do that, you can save Plain SVG files and import them successfully into Sketchup for further manipulation.
                                  • dereiD
                                    derei
                                    Where I can find this SVG importer ? Is it possible to be posted here, on SketchUcation?
                                    Thank you.
                                    DESIGNER AND ARTIST DEREI.UK
                                      http://flightsofideas.net/ seems to be the source of many things SVG...
                                      e.g http://code.google.com/p/sketchup-svg-outline-plugin/downloads/detail?name=sketchup-svg-outlines-plugin-0.99.zip
                                      and for which http://www.sketchucation.com/forums/viewtopic.php?f=323&t=29481 also applies ?
                                      BUT this http://rhin.crai.archi.fr/rld/plugin_details.php?id=435
                                      etc etc...
                                        Majenta
                                        @catalyst said:
                                        Hi danbig,
                                        I HAVE NOT BEEN ABLE TO SUCCESSFULLY IMPORT A PLAIN SVG FILE INTO SKETCHUP MAKE 2014 USING THIS METHOD. IS THERE ANY ADDITIONAL STEPS I NEED? GOAL IS TO INPUT A SVG FILE (THE WORDS "PEACE" "ON" AND 'EARTH" WHICH HAVE BEEN TRACED AND WELDED TOGETHER IN TO THREE INDIVIDUAL SVGS.) OF A WELDED WORD INTO SKETCHUP AND EXTRUDE IT TO MAKE A 3D 'BOX' ABOUT 2" THICK.
