    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.3m Views 329 Watching
      For the fun โ˜€
      Only problem calculates become more and more longer ๐Ÿ˜„
      Choose very fine your second curve and some funny surprises will arrive ๐Ÿ’š
      • P
        piyanan
        Hello any one
        I did install this plugin for my SU-7
        Lay down plugin clf_shape_benderand clf_shape_bender_loader.rbin my Plugin then try working see at below screenshot
        http://www.imageupload.samuisketchup.org/images/1er6bvci8bss7pgra53.jpg
        1 Make group model
        2 click tools
        3 click line
        3 click curve
        And wait but notthing happen
        Any one to know this problem ?
        Thank
        • Chris FullmerC
          Hmm, interesting. Does it just stop right there and not keep going? I've never seen it stall like that. So try this.
          Open the webconsole by going to Window>Web Console.
          Then run the plugin
          If there are any errors or any messages that pop up in the web console, copy and paste them into this thread and I'll take a look at it.
          • G
            gaucho
            Hi Chris,
            I've managed to make it work, actually, is was working already, just for some strange reason, the final bended text was located 15m above the original position...
            anyway, thank you very much for this plugin.. real time saver!
            "eat well, stay fit, die anyway..."
            • Chris FullmerC
              oh good, glad it works. Hope it keeps working! ๐Ÿ˜„
                andyboy88
                Hi, I'm a new member and a cabinetmaker. I'm eager to try Shape Bender but I can't find the link for the script. Every link I try on the blog just takes me back to the forum's discussion page. I may be thick. Can you help?
                • B
                  BTM
                  The file is on the bottom of the first post of this discussion, page 1.
                  • P
                    piyanan
                    Then run the plugin
                    I did install sketchup 6 it is work but su-7 not work
                    • Chris FullmerC
                      Did you open the web console and see if it outputs any errors when it fails?
                      • K
                        KODA
                        Hey Im new to this community, but im extremly interested in this plug in, but i dont have the pro version, and im also running a Mac. just wondering if It is possible for it to work for me and how to get it
                          This plug works also with the free version! โ˜€
                          • Chris FullmerC
                            Yup, should work with free version and with the Mac. The .zip file for the plugin is at the bottom of the first post in this thread. Enjoy!
                            • B
                              BTM
                              ... Unless you have Sketchyphysics RC1 X (Or maybe other versions too, but I don't know). Then it only works sometimes, and you can't switch the orientation with up, down, home or end.
                              ... And this happens a LOT.
                              • Chris FullmerC
                                Here's a hint to keep that particular thing from happening so much.
                                Orient the model so that the solid green axis points away from you (points off into the sunset ๐Ÿ˜„ ). Then always draw your straight line from left to right. THat will elminate that particualr problem, and remove the need to use the down arrow key.
                                Hope that little tip helps,
                                PS: I PM'ed Chris Phillips about the SketchyPhysics possible conflict. He never did get back to me. He probably has forgotten all about it now. I'll try to PM him again. Thanks for the reminder!
                                • Chris FullmerC
                                  Oh, another question BTM. Do you have any other scripts that make use of keyboard strokes during the script? Like Fredo's freescale suite. That uses ctrl, TAB, and probably others. Do those keys work in that script? Don't pay attention to the enter key, it doesn't count. It has its own special way to implement it, and its different than most other keys. So test to see if the tab key works in freescale for example.
                                  • B
                                    BTM
                                    ... The keys in freescale seem to work fine.
                                    • Chris FullmerC
                                      Very interesting. I'll look at freescale and see how he implements them. Perhaps its different than what I am doing.
                                      • Chris FullmerC
                                        Oh my, he hard wires them in for some reason. It seems unneccessarily complex, but perhaps he discovered bugs similar to this that he is working around. bummer for me. I might PM you with a code snippet to run for me to see what it does on your Mac. Thanks BTM,
                                        • C
                                          CPhillips
                                          Yes, it is a problem with SketchyPhysics. And it might be on Mac only.
                                          I'll fix it and release a new version asap.
                                          • Chris FullmerC
                                            Thanks you, thank you, thank you so much for looking into this Chris!
                                            Chris (Fullmer)
                                            • 63
                                            • 64
                                            • 8 / 64
