    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.5m Views 329 Watching
    • Chris FullmerC
      oh good, glad it works. Hope it keeps working! πŸ˜„
        andyboy88
        Hi, I'm a new member and a cabinetmaker. I'm eager to try Shape Bender but I can't find the link for the script. Every link I try on the blog just takes me back to the forum's discussion page. I may be thick. Can you help?
        • B
          BTM
          The file is on the bottom of the first post of this discussion, page 1.
          • P
            piyanan
            @chris fullmer said:
            Hmm, interesting. Does it just stop right there and not keep going? I've never seen it stall like that. So try this.
            Open the webconsole by going to Window>Web Console.
            Then run the plugin
            If there are any errors or any messages that pop up in the web console, copy and paste them into this thread and I'll take a look at it.
            I did install sketchup 6 it is work but su-7 not work
            • Chris FullmerC
              Did you open the web console and see if it outputs any errors when it fails?
              • K
                KODA
                Hey Im new to this community, but im extremly interested in this plug in, but i dont have the pro version, and im also running a Mac. just wondering if It is possible for it to work for me and how to get it
                  This plug works also with the free version! β˜€
                  • Chris FullmerC
                    Yup, should work with free version and with the Mac. The .zip file for the plugin is at the bottom of the first post in this thread. Enjoy!
                    • B
                      BTM
                      ... Unless you have Sketchyphysics RC1 X (Or maybe other versions too, but I don't know). Then it only works sometimes, and you can't switch the orientation with up, down, home or end.
                      ... And this happens a LOT.
                      • Chris FullmerC
                        Here's a hint to keep that particular thing from happening so much.
                        Orient the model so that the solid green axis points away from you (points off into the sunset πŸ˜„ ). Then always draw your straight line from left to right. THat will elminate that particualr problem, and remove the need to use the down arrow key.
                        Hope that little tip helps,
                        PS: I PM'ed Chris Phillips about the SketchyPhysics possible conflict. He never did get back to me. He probably has forgotten all about it now. I'll try to PM him again. Thanks for the reminder!
                        • Chris FullmerC
                          Oh, another question BTM. Do you have any other scripts that make use of keyboard strokes during the script? Like Fredo's freescale suite. That uses ctrl, TAB, and probably others. Do those keys work in that script? Don't pay attention to the enter key, it doesn't count. It has its own special way to implement it, and its different than most other keys. So test to see if the tab key works in freescale for example.
                          • B
                            BTM
                            ... The keys in freescale seem to work fine.
                            • Chris FullmerC
                              Very interesting. I'll look at freescale and see how he implements them. Perhaps its different than what I am doing.
                              • Chris FullmerC
                                Oh my, he hard wires them in for some reason. It seems unneccessarily complex, but perhaps he discovered bugs similar to this that he is working around. bummer for me. I might PM you with a code snippet to run for me to see what it does on your Mac. Thanks BTM,
                                • C
                                  CPhillips
                                  Yes, it is a problem with SketchyPhysics. And it might be on Mac only.
                                  I'll fix it and release a new version asap.
                                  • Chris FullmerC
                                    Thanks you, thank you, thank you so much for looking into this Chris!
                                    Chris (Fullmer)
                                      August
                                      Hi Chris,
                                      Thanks for an amazing tool!
                                      I have not read through the entire 163 (so far) posts on this subject, so please forgive me if this has been mentioned before.
                                      Version: 0.2 Beta - Special release to Sketchucation only.
                                      Does that mean that we are prohibited from mentioning this outside of SketchUcation, e.g. in personal blogs or on the Google SketchUp Group?
                                      August
                                      β€œAn idea, like a ghost, must be spoken to a little before it will explain itself.”
                                      [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                                      • Chris FullmerC
                                        Heh, good question! I don't really remember what I had in mind when I wrote that. I think I was just saying that I'm only releaseing it here, instead of on Smustard or anywhere else.
                                        So please, feel free to blog about it, post links back to this thread, etc. Just don't host the file anywhere else is all. But please, links back here are very welcome! Thanks for checking it out August,
                                        For the record though, I'll probably release it on Smustard when I feel like I've ironed out all the bugs and I'm ready to release a non beta version. I feel bad putting my scripts on there because I'm always afraid I'll break someone's computer with one of my scripts, and I don't want Smustard to kick me out πŸ˜†
                                          driven
                                          Hi Chris, I see your visiting,
                                          does this run on macs yet??
                                          I was looking for the latest progressbar.rb and came across ShapeBender, so now I want both, do you have the links?
                                            sepo
                                            Hi Chris
                                            Would it be possible to make the path which branches. When I try it it seems to highlight it but does not do anything. Usage could be from road layouts to making trees.
                                            • 63
                                            • 64
                                            • 8 / 64
