    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.5m Views 329 Watching
      dtrarch
      Hi Chris
      Your magic script will also do a follow and keep and no need to align to the end point.
      Just thought y'all would like to know. โ˜€
      • Chris FullmerC
        Hey, thats a good one! Thanks for all the examples, very useful!
        • W
          watkins
          Dear Dtr,
          Not sure how you have arrived at that. Is the bending done out of plane? Could you be more specific? A brief tut would be good.
          Regards,
          Bob
          • massimoM
            massimo Moderator
            Watkins, the plugin works also out of plane.
              dtrarch
              Watkins
              Reference object and reference line must be on red axis.
              The reference line must also be the same length as the object and offset in plan as you want.
              (in this case it was centered and above one of the elements)
              1-Pick the object
              2-invoke the script
              3-pick the reference line
              4-pick the path and [enter] to create the sweep.
              Done
              dtr
              • W
                watkins
                Dear Dtr,
                Thanks for that. I didn't know the script would bend a group/component around a 3D path. I must pay more attention.
                Kind regards,
                Bob
                  For the fun โ˜€
                  Only problem calculates become more and more longer ๐Ÿ˜„
                  Choose very fine your second curve and some funny surprises will arrive ๐Ÿ’š
                  • P
                    piyanan
                    Hello any one
                    I did install this plugin for my SU-7
                    Lay down plugin clf_shape_benderand clf_shape_bender_loader.rbin my Plugin then try working see at below screenshot
                    http://www.imageupload.samuisketchup.org/images/1er6bvci8bss7pgra53.jpg
                    1 Make group model
                    2 click tools
                    3 click line
                    3 click curve
                    And wait but notthing happen
                    Any one to know this problem ?
                    Thank
                    • Chris FullmerC
                      Hmm, interesting. Does it just stop right there and not keep going? I've never seen it stall like that. So try this.
                      Open the webconsole by going to Window>Web Console.
                      Then run the plugin
                      If there are any errors or any messages that pop up in the web console, copy and paste them into this thread and I'll take a look at it.
                      • G
                        gaucho
                        Hi Chris,
                        I've managed to make it work, actually, is was working already, just for some strange reason, the final bended text was located 15m above the original position...
                        anyway, thank you very much for this plugin.. real time saver!
                        "eat well, stay fit, die anyway..."
                        • Chris FullmerC
                          oh good, glad it works. Hope it keeps working! ๐Ÿ˜„
                            andyboy88
                            Hi, I'm a new member and a cabinetmaker. I'm eager to try Shape Bender but I can't find the link for the script. Every link I try on the blog just takes me back to the forum's discussion page. I may be thick. Can you help?
                            • B
                              BTM
                              The file is on the bottom of the first post of this discussion, page 1.
                              • P
                                piyanan
                                Then run the plugin
                                I did install sketchup 6 it is work but su-7 not work
                                • Chris FullmerC
                                  Did you open the web console and see if it outputs any errors when it fails?
                                  • K
                                    KODA
                                    Hey Im new to this community, but im extremly interested in this plug in, but i dont have the pro version, and im also running a Mac. just wondering if It is possible for it to work for me and how to get it
                                      This plug works also with the free version! โ˜€
                                      • Chris FullmerC
                                        Yup, should work with free version and with the Mac. The .zip file for the plugin is at the bottom of the first post in this thread. Enjoy!
                                        • B
                                          BTM
                                          ... Unless you have Sketchyphysics RC1 X (Or maybe other versions too, but I don't know). Then it only works sometimes, and you can't switch the orientation with up, down, home or end.
                                          ... And this happens a LOT.
                                          • Chris FullmerC
                                            Here's a hint to keep that particular thing from happening so much.
                                            Orient the model so that the solid green axis points away from you (points off into the sunset ๐Ÿ˜„ ). Then always draw your straight line from left to right. THat will elminate that particualr problem, and remove the need to use the down arrow key.
                                            Hope that little tip helps,
                                            PS: I PM'ed Chris Phillips about the SketchyPhysics possible conflict. He never did get back to me. He probably has forgotten all about it now. I'll try to PM him again. Thanks for the reminder!
                                            • 63
                                            • 64
                                            • 8 / 64
